I have a acer aspire one d270-1824. I have just replaced the screen with a lcd screen. After replacing the screen i turn on the computer but the screen stays white. Computer will wirk will desktop monitor. I have also tried f6 and f8. I also have messed withe contrast and the screen will get darker or brighter but still stay white. Do i need to replace the cable that connects to the lcd screen?
  • 3,530 Answers
Hi Andrew,
Is the issue happening on windows only? Have you tried going to the BIOS of the computer and see if the issue is present there. If the issue is present on the BIOS then its a LCD problem or it might be a connection on the inside is loose. If you can access the bios without having any issue then the problem is only widows, you might need to reinstall the operating system to resolve the issue.
Hope this helps. Let me know if you have further questions.
Posted on Nov 19, 2013
4 Suggested Answers
Arius
  • 446 Answers
SOURCE: help
Step 1
Shutdown your computer and look at the rear of the case to determine the type of video connections that your machine has. Nearly all computers will have the standard 15-pin VGA output port. In addition, you may also find that your computer has an S-video port, an RCA composite video port, a set of three component RCA video outputs or perhaps even an HDMI output port.
Step 2Determine the types of video inputs that are available on your plasma TV. There should be a standard RCA composite input, a three-jack RCA component input and an S-video input. In addition, you may also find a 15-pin VGA input, a DVI input or an HDMI input. Step 3 Select which type of connection you will use. HDMI and DVI represent the highest-quality connections, followed by VGA, Component, S-video, and composite. If your computer has only a VGA output and you will not using it solely to drive the plasma TV, you may want to invest in a video card upgrade. Most new video cards will offer dual monitor connections and possibly a separate TV connection. The first monitor connection is intended for the main computer monitor, and the second monitor connection, or the TV output, can be used for either a second monitor or a TV. Depending on the card, the TV output may be DVI, HDMI, component, S-video or composite. Step 4Purchase a video cable long enough to reach from your PC’s video output to your plasma TV. If the distance is over ten feet, you may want to invest in high-quality cables to ensure that the plasma TV receives a clean signal for the best possible picture. Cables over thirty feet in length, depending on the connection type, may result in poor video performance. Step 5Set your computer’s screen resolution to something that your plasma TV can accept, using the “Display” settings in the “Control Panel” in Windows. Refer to the owner’s manual of your plasma TV for the supported resolution and refresh rate. If you are using the S-video, composite or component outputs on your computer, this step may not be necessary. Step 6Connect your PC to your plasma TV using the appropriate cable. Start the computer up and it should recognize the attached display. In the “Display” settings, you will need to configure how the plasma TV is used if it is attached a second display. Most video cards support “Clone” or “Mirror” mode, which displays the same content on both displays. In addition, there is the “Extended” mode, where the second display will operate independently, and windows can be dragged from one screen to the other. If your plasma TV is the only monitor for the computer, you will not to configure the multiple display modes. Step 7Connect a cable from the sound output of your PC to your plasma TV using the appropriate audio adapters. Then relax on the couch and enjoy your videos on the big screen.
Posted on Aug 09, 2008
SOURCE: No LCD connectivity
Hello, I am using a Viewsonic lcd projector with my new Acer Aspire One. I did not have connectivity off the bat. Here's what I did: 1. Downloaded driver (unsigned, not the signed version worked - ie not os-specific) for the lcd projector to the Acer. Restart Acer. 2. With lcd projector connected to Acer, toggle function key & F5. But then, continue holding down the function key. A screen pops up with icons for laptop, laptop/monitor, dual monitor, and lcd projector. You continue to hold down the function key and then press the F5 key to move to the desired device. I had to repeat the same process to restore my Acer screen to the original proportion when not using lcd projector. I'm not sure if both steps 1 and 2 are necessary, but I did it simultaneously, so I'm not sure of the origin of success.
Posted on Jun 09, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Toggle Between Laptop and Monitor
Fn + F5 toggles the display output, the trick here to wait each time you hit this combination because it goes through several options. Hit it once and it may want to go to just the external, then both the laptop screen and the external. etc. Now Fn + F6 turns the backlight bulb off on the internal monitor to save energy. Now I am giving up the link to your service manual, it is in PDF format so you can make a copy for yourself and keep on the laptop, print it or save it to a flash so you can reference it later. I believe if you take the keyboard off and disconnect the video lead on the left side where the display plugs into the motherboard, then when you power the laptop back up it will default to the external cord and you can use the laptop without any switching. That is what I am doing with an Aspire 5920 that I am rebuilding. Good luck, ParrotHead PC Repair
Just copy and paste the link below to you internet address bar and hit enter.
http://tim.id.au/laptops/acer/aspire%203680%205570%205580.pdf
Posted on Sep 05, 2009
Will a replacement screen for an acer aspire part #5733-6607 work in an emachines e525 series
https://www.laptopscreen.com/English/model/Acer/ASPIRE%205733-6607/
http://www.lcdscreen.com/eMachinesModel_eMachines_E525.htm
First of all the eMachines E525 has to use LED backlighting.
Does it?
If so there is one requirement that is crossed off.
No? Then the answer is No.
Next, you really need to look at the manufacturer ID info on the back of the Acer's LCD screen, and the same info on the back of the eMachines LCD screen, to be SURE.
Example,
http://www.insidemylaptop.com/replace-screen-on-acer-aspire-4830-series-laptop/
Scroll down to the bottom of the page, look at the last photo.
THAT, manufacturer information.
'Armed' with the Acer's LCD screen manufacturer info, then check to see what all laptops it will work on.
And/or if it works on the E525.
THIS, is the theory.............
The LCD screen of course, isn't manufactured by Acer.
Neither is the eMachines LCD screen.
(In fact the Acer laptop isn't made by them.
Neither is the eMachines.
One of three main companies made it for them.
Quanta Computer, Compal Electronics, or Wistron Corporation)
LG, Hitachi, Sharp, NEC, Chi-Mei, HannStar, Philips, and Samsung; are just a few LCD screen manufacturers for laptops.
If you give me the Acer LCD screen manufacturer into, and the eMachines LCD screen manufacturer into, let me see if I can find out.
Post back in a Comment.
http://www.youtube.com/watch?v=G2zGopPM7AM
http://www.youtube.com/watch?v=16zVct3M13E
Regards,
joecoolvette
Feb 27, 2013 | eMachines Computers & Internet
I have an Acer Aspire 5515 laptop. My computer will turn on but it shows a black screen. I've tried turning it off and back on again. Removing the battery but it hasn't helped. Any suggestions??
Wow this is tuff,
Setting from keyboard, possibly.
Software, not likely.
Video Card, possibly.
LCD Screen, very likey.
But with no screen you options at home are limited.
There is a setting on laptops that allow you to send the video output to an overhead projector and cuts the laptop screen off. However, when you re-boot it usually defaults to the screen.
I betting on a screen failure. You may want to take it to a PC Repair shop. Or, buy one here,
http://www.hootoo.com/154-inchs-acer-aspire-5515-laptop-lcd-screen-panel-p-11162.html
http://www.amazon.com/ASPIRE-LAPTOP-SCREEN-SUBSTITUTE-REPLACEMENT/dp/B003XHDARC
Good Luck
Aug 12, 2011 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
Acer Aspire One Netbook screen does not come on when computer is turned on.
There is a LCD inverter (tiny circuit board) that connects the screen to the motherboard, try replacing it.
Apr 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
Replaced the broken screen in my Acer Aspire One D150 (10 inch). It seems to work fine, except when the computer is powered off. The screen remains ON and completely white when the computer is turned off....
Sounds like your "Backlight" is not powering off.
Are you sure it is an exact replacement?
Check ALL your connections again, perhaps ya have a bad one...?
Have you got the latest drivers?
Jan 18, 2010 | Acer Aspire One D150-1587 Netbook
My screen on my toshiba laptop screen is going in and out do I need to buy a new scren/
Most likely your issue is caused by a failing LCD Inverter. You will need to have this replaced. Part is available here: http://cgi.ebay.com/Acer-Aspire-One-A110-A150-LCD-Screen-Inverter-B089AW01_W0QQitemZ190363835846QQcmdZViewItemQQptZUK_Computing_LaptopAccess_RL?hash=item2c52919dc6
This site explains the process for an Aspire 5100 which can also can be used as a reference for your Aspire One model http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Jan 14, 2010 | Acer Aspire One PC Notebook
I have acer aspire one with a crack screen laptop
I read your question as,
"I have an Acer Aspire One with a cracked LCD screen. How much to replace it?"
It depends on what area you are in, (Country to country, city to city, town to town), but a general guideline is,
1.$75 to $125 for labor is a general guideline for most competent computer repair shops.
2.$50 to $100 for the LCD screen is a general average.
Sep 24, 2009 | Acer Aspire One PC Notebook
Replacement screen
Hi
If you are in the USA, you can order one from here http://www.screentekinc.com/search-lcd-screen.shtml?lcds_product=acer%20aspire%205570%20screen&source=google&gclid=CJbb87iUgpUCFR4sagodADPHqQ
I would recommend that you go on www.ebay.com and buy any fault laptop that takes a 14.1" screen ( assuming ur screen is that side) and either replacing it if u know how to or get a techincian to do it for you
http://cgi.ebay.com/NEW-ACER-ASPIRE-5570Z-14.1%22-WXGA-LCD-SCREEN-GLOSSY_W0QQitemZ260266787803QQcmdZViewItem?IMSfp=TL0807251125r187
hope this helps
Cheers
Aug 10, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer 3610 LCD Screen
KiMar, The inverter board (changes DC to AC to keep the backlight on) in your Acer is going bad. It needs to be replaced.
Jan 18, 2008 | Acer Aspire 3610 Notebook
Computers & Internet Logo
David Payne
David Payne
