I have an itt grinnelloverhead garage heater the pilot goes out gas shuts off the fan comes on and runs cotinuosly until i shut off the power . the instruction plate says that if the pilot extinguises then i need to replace a econ safety switch in the fan cage. can u help me ? Leonard
  • 14 Answers
SOURCE: Williams Model 435FXR Serial GO222436 Forced air pilot keeps going out
BY THERMISTOR, ARE YOU MEANING THERMOCOUPLE, I.E. WHAT YOUR PILOT LIGHT IS HEATING? IF SO, COULD BE WEAK AND NOT GENERATING ENOUGH VOLTAGE TO STAY OPEN, SHOULD BE BETWEEN 10-25 MILLIVOLTS DC, WHICH CAN BE TESTED AT THE INTERRUPTER LEADS. YOU CAN ALSO BYPASS THE LIMIT DISC TEMPORARILY TO SEE IF THE UNIT STAYS LIT, REPLACE IT IF THE UNIT RUNS.
Posted on Jan 29, 2008
SOURCE: How to reset Tilt Switch in LASKO Ceramic Heater 5540?
I don't have manual, it's a borrowed one. Several days later, I pushed the botton at the bottom several times, looks it solved my problem.
Posted on Feb 15, 2009
SOURCE: pro comm natural gas heater, pilot keeps going out
The problem is likely to be either the thermal-couple (easily replaced) or a clogged gas orrifice. The clogged orrifice would require a bit more know-how then the thermal-couple and with gas appliances it would be best to hire someone who knows what they are doing.
Posted on Mar 21, 2009
  • 9 Answers
SOURCE: Heater Burner ignites but main blower motor will not turn on.
it sound like the blower motor may be seizing up. try spining the blade by hand to see if it feels free or not. the motor could be trying to turn but can then tripping itself out on overload. (most motors have built in safety overloads which will trip during an overcurrant event. aka too many amps.) you may have to replace blower motor
Posted on Mar 22, 2009
  • 588 Answers
SOURCE: My honeywell gas suspended garage heater will not
The pilot light has to be lit before gas valve will operate. That's a safety feature so the valve won't open and fill the garage with gas and possibly cause an explosion or fire. If you have a standing pilot and can't get pilot to stay lit, it's usually the thermocouple and it will need to be replaced. Once the pilot is lit, the gas valve comes on and heats the combustion chamber up to approx. 100° to 125° a thermostat controlled fan switch will close and bring the blower on.
Posted on Sep 10, 2009
I have a reznor heater in my garage I have to keep lighting the pilot it wont stay lit.
i have an ole reznor in my garage been workiing for ten + years no problems , mine is gas , the pilot light does go out after it switches to main burner like ten seconds later , but does light back up when thermostat shuts main off ( i had to go look to make sure) not a real big flame maybe like an inch or so , has a spoon shaped air shield around it , maybe yoours is missing ?
Mar 02, 2015 | Heating & Cooling
Why does the flame shut off before a hot to warm temperature can be achieved
I would question the Thermo couple. It pretty much runs the whole show. Inexpensive quick fix. It's the small tubing that is connected to the gas valve. The other end is a bulb that sits over the pilot flame.. Remove the old and match it up at the hardware store. Install new coupler ensuring bulb is directly over the pilot flame Common iten. The thermocoupler alks to the gas valve. If the pilot flame extinguishes (goes out) the bulb cools and shuts down the gas valve so the pilot gas feed doesn't permit raw gas to accumulate, avoiding the need emergency Services. . You will not get the heater to fire until the bulb is good and hot. The red push button ,when depressed will allow the pilot flame to be lit. Hold it down until the heater fires, indicating the T-coupler has reached its operating temp.Good Luck-Ned
Sep 10, 2014 | Bosch AquaStar Indoor Natural Gas Tankless...
Pilot light keeps going out
pilot light keeps going out! more then likely its the thermal coupling doing this. if bad it shut all gas to heater for a safety measure. just shut power off, then turn gas off and replace it. then you should be ready to go. to relight heater hold down on gas vavle knob in the pilot position, hold down and light it at the coupling where gas comes out. when it is lit, continue to hold down for 60 seconds. release knob very slow. then if its lit, turn to the run position. if flme goes out, wait at least 5 minutes to expel the gas fumes and turn to pilot and try again. good-day !
Mar 31, 2012 | Water Heaters
I have a Rheem Power Vent propane water heater model3 21VP4OE-1P that is acting up. The pilot lights and then the burner lights, but goes off after 5 - 10 seconds. It cycles like this 2 or 3 times, then...
check the thermal coupling for the pilot light. if it goes out it will shut down gas supply, its a safety feature to put out pilot light if the thermal coupling is bad. to prevent gas from leaking and causeing a fire. check coupling.
Aug 12, 2010 | Water Heaters
Garage furnace (standing Pilot) pilot stops after 30 mins.
it sounds like the afc the fan control not working could be dust on the afc
Jan 10, 2010 | Dayton Gas Furnace Heater
VN18TB PILOT LITE GOES OUT STAY LITE TILL HEATER COMES ON AFTER THE HEAT RUNS AND TURNS OFF THE PILOT LITE SHUTS OFF NATURAL GAS VANGUARD
Sounds like a weak thermocouple. With the extra heat of the main burner running it can keep the pilot solenoid open...without it it fails shut. Try replacing the thermocouple. (small rod the pilot flame burns against with a skinny copper tube going to gas valve).
Jan 04, 2010 | Heating & Cooling
HEATER BURNING OK, UNTIL IT SHUTS OFF AND PILOT GOES OUT
gas valve bad or its getting too hot and shutting the gas off. must have air movement
Dec 24, 2009 | Heating & Cooling
My dayton NG heater fan will not shut off properly
Sounds like a bad fan switch. The switch is located on the heat exchanger and is 110 volt bi-metal switch. Follow the wires from the blower going back to the heatexchanger. Graingers can get you a new switch if you give them your model number. www.grainger.com.
Dec 12, 2009 | Dayton Heating & Cooling
My honeywell gas suspended garage heater will not come on when the t'stat calls for heat. It is a heat only unit and neither the fan nor the blower motor will come on. The Heater is getting power to it...
Sep 08, 2009 | Mr. Heater Suspended Garage Heater
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
