Question about Vizio Vp322hdtv10a Digital Video Pteax42752001 vsc
I have picture, but no sound. Has the Vizio 3832-0012-0137 Audio Assembly gone bad?
What else could it be? There is no sound output from digital optical or RCA or TV.
oldnovii
  • 667 Answers
SOURCE: TV ranking
Hi. You could look up reviews. I personally usually never offer advice on choices, because what I like, may not be what you like..its a matter of personal preference. But in this particular case, I'd go for Panasonic. Why? Better features, better service, easier availability of parts, and better resolution.Plus some nice features. If this answers your question, PLEASE don't forget to rate as fixed. I'd really appreciate it. Enjoy your new tube!!!
Jeff
Posted on May 17, 2008
SOURCE: vizio tv has audio but no picture
My vizio has the same problem, no picture with only sounds. I tried calling vizio for help but their customer service and or tech support REALLY **** big time! They tossed me around to here and there with no solutions. My only suggestion to you is that, tell everyone related to you or your friends to not ever buy vizio again. Too many people is having problems with these sucky tvs. I'm still not sure what I am going to do with mine. Maybe I'll just let it fly down from a three story building!
Posted on Aug 05, 2008
  • 73 Answers
SOURCE: how to hook up my 32" vizio lcd hdtv to my sanyo home theater
If your audio system doesn't have optical inputs you're going to have to use RCA (red and white) jacks.
I would suggest upgrading to a system in the future that does have optical inputs if at all possible. Excellent sound.
Posted on Jun 29, 2009
SOURCE: Vizio SV470XVT will not output Dolby 5.1 from optical out..
TV's only will output 5.1 from HD stations. If you have a DVD player, XBOX 360, etc connected through HDMI, then the TV will only send stereo PCM through the optical out.
Posted on Jul 10, 2009
rulds2008
  • 3866 Answers
SOURCE: I need an adapter to
Hello, Thanks for allowing fixya.com to help you.
Yes it can be done you need a optical out to RCA converter. One would just by a reciever with optical inputs but here is what your looking for.
rulds2008_35.jpg There about $30 bucks and you can find them HERE
Posted on Jan 26, 2011
TV has no picture, no sound just the VIZIO logo light is on the screen.
Did you check out the power supply for proper operation since both the audio and video are gone? If PS is good then the problem may very well be on main board.
May 03, 2016 | Vizio E421VA 42 in. LCD TV
How do you connect tv audio from vizio wv26l through panasonic saht 680 surround sound?
The SAHT680 only has RCA analog audio inputs. I don't know the WV26l. However, there are a couple of possibilities based on other Vizio models. 1) The audio out is a headphone jack. Use a 3.5 mm M to RCA F/F adapter and then an RCA audio cable to the surround sound system. (You can also use a cable that has the 3.5 mm M and RCA M/M ends or a 3.5 mm F and RCA M/M adapter with a 3.5 mm audio cable.)
2) The audio output is a digital audio out. In that case, you need a digital to analog audio converter. There are a number of models available. One example is here: http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10423&cs_id=1042302&p_id=6884&seq=1&format=2 . You will also need the correct digital audio cable between the TV and the converter and the RCA audio cable between the converter and your SAHT680.
The manual for the SAHT680 is available from Panasonic here: service.us.panasonic.com/OPERMANPDF/SAHT680.pdf . See page 25 for the picture of the audio inputs.
I hope this helps.
(The only other option is to upgrade the main unit of the surround sound system to one with digital audio inputs if your TV only has digital audio out.)
Nov 19, 2012 | Audio Players & Recorders
Vizio 19 inch no picture no sound
That capacitor could possibly be the cause. On some sets, the 12V supplies both the video and audio circuits. I would recommend replacing the cap and checking power supply outputs especially the 12vdc supply.
Sep 09, 2012 | Vizio VA19LHDTV10T 19 in. LCD TV
I have an L37HDTV10A that i just replaced the main board...i get picture but no sound...everything looks connected inside...also, what remote do i need?...will a universal work?
Go into ur tv Menu goto OPTION go down to Output Select,press enter make sure selection on (Fixed).This fixed selection will pick for the tv out put to tv speaker.Tv should have sound now on it speakers.Try website like Remotes.com to buy the tv original remote work for the best used for to reajustment setting and setting on the tv Menu.
Jul 29, 2011 | Vizio L37 Television
How to connect a vizio lcd hdtv to my 1976 kenwood KVA 503. My Vizio has no speaker outputs except a digital optical audio. I had it hooked up before and then moved and now I can't get it back...
Obviously the digital optical connector was never connected to the vintage Kenwood.
It sounds like your Vizio is NOT the actual root SOURCE of the TV audio but it's coming from a Cable Box which DOES have various audio outputs. Connect it as you would any other analog audio source (except don't use the PHONO input).
Jun 30, 2011 | Audio Players & Recorders
My Vizio blu ray won't play through my Pioneer receiver. The picture cycles in and out so I have it hooked up properly but something is not right (could the wi-fi be the culprit?). I had a different...
I'm not sure of your exact setup but I will try to help. The Blu ray player probably has a couple of options as far as output. Two I would have to figure being; HDMI out and a DIgital optical out. I'm assuming you are going into the receiver input then out to tv because you have multiple inputs to tv. If you don't have multiple outputs to tv you could get video straight from blu ray to tv and audio out to reciever then out to tv. HDMI would be your best bet because it handles video and sound. To do this, you would have to have a HDMI in/out on your receiver and a HDMI in on your tv. If you can't do HDMI for audio then there should be a Digital optical output on your Blu ray which could go to your receiver, providing you have the input. If you could provde the model numbers for the units. I could probably be of morre assisiiance.
Mar 10, 2011 | Audio Players & Recorders
I did not find Audio out for installation of additional sound system (external)
The VO47LF has two output options: a SPDIF Digital Optical and a tradition stereo audio out port.
The following site has instructions and pictures on locating the two options.
http://www.televisioninfo.com/content/Vizio-VO47L-LCD-HDTV-Review-598/Connectivity.htm
Thanks
Dustin
Jan 12, 2011 | Vizio VO47L 47 in. LCD TV
I don't get sound from Vizio Sound Bar, need connection instructions.
You have a red and white composite audio cable the simplest way is to hook that to your audio output on your tv then obviously the other end goes into the soundbar. Make sure its an OUTPUT not input on the tv, if you hook it up this way everything that plays on your tv will then play through the soundbar.Some tv's do not have an audio output if this is the case then you will have to hook it up to an output of another source such as DVD player or cable box. There are two other possible audio outs on your tv they are fiber optic audio and digital coaxil audio but usually not the case as they are usually only inputs. One other thing some tv's(very rare) require you to go to menu to enable audio out. There is one other possibity and that is HDMI which carries picture and sound but again TV's rarely have this output.
Dec 13, 2010 | Vizio Televison & Video
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
I need a digital audio cable to connect to my surround sound amplifier from vizio HDTV (digital audio output connection)
yes and no. most set top boxes have a optical output that can go to the vizio, but you can also connect a regular right and left audio cable too. Now from your set top box or cable box or sat box you can go to receiver in digital cable. that is the better way to go.
Apr 01, 2008 | Audio Players & Recorders
Vizio Vp322hdtv10a Digital Video Pteax42752001 vsc Logo
27 people viewed this question
Top Vizio Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Vizio Audio Player and Recorder Expert? Answer questions, earn points and help others
