Question about Amana AEW4630DDS Electric Double Oven
Upper oven does not heat up past 300 degrees - Amana AEW4630DDS Electric Double Oven
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
300c proberly max temp
Posted on Nov 22, 2013
Why won't the fan switch of after the oven is switch off
Not sure what fan your question refers to, but the fan that removes the heat from above the oven is controlled by a thermostat. It normally does not come on until the air temperature above the oven space is about 300 degrees and does not turn off until it is below 300 degrees.
Feb 25, 2015 | Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
It takes 28 minutes for the oven to reach temperature of 375 degrees. The ready buzzer goes off in about 15 minutes. The temperature is 300 degrees. Is there any adjustments to be made.
what is your oven if is gas or electric, if is gas easy to preheat by using lower heating element, if electric? that your unit have convection? or not? coz some probelm of the oven is, 1 if the oven is no convection or your oven is single heating in upper element,if your oven have a timer and cut off in 15minute? dont use timer,use a manual timer by it your self,if you want to reach the degrees that you want check your oven if der a lower and upper heating element with convection function,that the one is the most easy way to reach the degree that you want to reach.
Dec 17, 2010 | Ovens
Heating element in upper oven heats to about 300 degrees and temperature will not increase.
That seems to me like it could be an issue with the sensor. Ohm it out. It should be around 1100 ohms if it is any good. Check for shorts from each wire of the oven sensor to ground. I have a manual and a TIP I wrote about these Thermadors.
Thermador 301/302 wall oven repair manual
Sep 28, 2010 | Thermador SC302T Electric Double Oven
Both upper and lower oven elements won't heat beyond warm (100 degrees) Jenn-Air Model# SVD48600P
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 15, 2010 | Ovens
My oven burns everything.
Use a 'oven thermometer' in the oven and determine the 'actual temperature' in the oven. Your knob setting is off (not calibrated) and the oven is hotter than the control knob setting.
Sep 16, 2009 | Ovens
Why won't my Maytag electric oven heat past 210 degrees?
Hello could be oven thermostat,when you are sure of the part you need check out www.appliancepartssolutions.com cheep parts!
good luck
Apr 08, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
Oven will not heat past 300 degrees
300 far. or cels if its celcius its to high they should run at about 260 or the high temp sensor will shut it down how fast is your belt running it should be 6.30 to 7.00
Jan 28, 2009 | Lincoln Conveyor Oven - 1133-000-A
Magic Chef oven won't heat up past 200 degrees
You obviously have one or more elements not working, you need to test same, and replace as req'd.
Dec 12, 2008 | Magic Chef Ovens
Amana AEW4630DDS Electric Double Oven Logo
Top Amana Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Ismael Rodriguez...
Are you an Amana Oven Expert? Answer questions, earn points and help others
