Question about Samsung WF328AA Front Load Washer
I am getting a d5 error on my samsung front load washer
All the water does not drain after the wash cycle, so it won't advance to the next stage. I tested the drainage pump and it works fine. The hose from the drum to the water level sensor is not clogged, and I cleaned the filter.
    Problem Solver:
  • 5 Answers
One common error with these machines Is that the water level sensor pipework has a small hole. The pipe is connected to the drum, and as the unit rotates it will cause the rubber tubing to be degraded. If a small tear appears it will cause the sensor to malfunction - when there is no negative pressure as the water drains (or vacuum) it assumes the water is still there/. Either find the tear and repair with bicyle repair kit, or if the tear is near to the sensor connector - cut off and reattach slightly shorter tube.
Posted on Nov 22, 2013
57 varieties
  • 1653 Answers
SOURCE: Samsung Front Load washer has odour
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Posted on Sep 10, 2009
SOURCE: i have a samsung J1043 7kg washing machine, apon
3E means the motor is running below or above the programming RPM's, this is a real problem. hold down the two left buttons while pressing the power button. this will present you with the testing system. Press the temp button and T1 will appear. press the start button on the machine will move through the phases in 3 second bursts. if your drum doesn;t move your motos shot. Good luck
Posted on Jan 31, 2010
SOURCE: My Samsung WF218ANW/XAA front load washer will not
lefever352, I am currently trying to solve this same issue on the identical model. I removed , cleaned, and re-assembled all the water tubes and the entire pump assembly. The pump works but for some reason it is not priming into the drain tube. The pump assembly appears to have a diaphram over the outlet opening and it it looks like this might be the problem. I am still hunting the solution, BUT so far the above actions have to resolve our issue. I hope perhaps Fixya can help.
Posted on Jan 22, 2011
KevinWhite
  • 1902 Answers
SOURCE: Samsung front-load washer won't drain. I did
Hello & Welcome to FixYa
Please check this service manual for your Samsung front load washer. You will have to check the drain hose and pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Posted on Aug 30, 2011
KevinWhite
  • 1902 Answers
SOURCE: Samsung WF209ANW front load washer
ND error in your Samsung Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Posted on Sep 25, 2011
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
Samsung front load washer code d5
The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. the problem is related to faulty door locking assembly.There is a switch in back of door, if this fails it wont work. God-Bless!
Nov 06, 2015 | Samsung Washing Machines
D5 error
Error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly. But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem.
Hope helps.
Jul 28, 2011 | Samsung WF337AA Front Load Washer
Won't drain or spin
Hi jm irons - most washer will not spin as long as the water remains inside, first thing is to check why the drain pump has not operated, water levels are controlled by the pressure switch or laymans term water level control, when water drains it closes a built in switch and enables the spin cycle circuit and machine advances to next stage of program.
Jun 18, 2011 | Washing Machines
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool AWM1200 washing machine wont advance at certain stages
there is a little motor in the selector switch that moves the dial around.  This little motor is defective and needs replacement.  Sometimes it's sold separately and sometimes you need the whole timer.
Apr 01, 2009 | Whirlpool AWM6120 Front Load Washer
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Error Code d5
It sound like a loose or a broken lid switch issue. The lid switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Good luck!
Aug 21, 2007 | Maytag Neptune MAH9700 Front Load Washer
Samsung WF328AA Front Load Washer Logo
448 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
