Question about Minka Aire Ceiling Fan
My minkaAire/Delano11 will not turn on. The green light is now blue. What does this mean
    New Friend:
Hi folks,
I have a blade less-fan, it doesn't oscillate and also has a flashing blue light.
I tried to reset it as advised on this site however in my case it did not work.
Now here it is friends...Unplug power cord and wait till blue light dims out. Get an insulated screwdriver and short out the all the power plug pins (must be unplugged from power) Turn it on and the fan works.
Have not worked out how to get it to oscillate again and any tips would be great. (Yes I am into electronics)
Also I would like to say that the Dyson fans have been far too expensive and that is why people buy the Chinese ones.
May I also say that this is a wonderful site to help people solve problems and would just like to thank the originator.
Thanks
Paul...Syd Australia
Posted on Apr 21, 2016
    New Friend:
    Problem Solver:
  • 7 Answers
OKAY I HAVE A POSSIBLE SOLUTION! THERE SHOULD BE A GREEN LIGHT AT THE TOP OF THE REMOTE AND A BLUE LIGHT AT THE BOTTOM. YOU NEED TO TURN OFF THE BOTTOM SWITCH, WHERE THE BLUE LIGHT IS, FOR 5 SECONDS THEN BACK ON. THEN HOLD THE CENTER STOP BUTTON FOR 5 SECONDS AS WELL. THIS WILL ALLOW FAN AND REMOTE TO RESYNCHRONIZE, IF BLUE AND GREEN LIGHTS BLINK TWICE THEN U HAVE SUCCESSFULLY RESET BOTH FAN AND REMOTE. IF THIS DOESN'T WORK CALL MINKA AIRE TECH SUPPORT 1-800-221-7977. GOOD LUCK!
Posted on Dec 10, 2013
WHERE IS THE FUSE BOX IN THE REMOTE FOR MINKAaIRE
Why are you yelling, typing in all caps is yelling. What articles, news papers, magazines, do you read that are all caps, none. Also, all caps is more difficult to read.
Nov 30, 2014 | MinkaAire F510-BS 3 Blade 26" Flush Mount...
Tip
Trailer Wiring Cheat Sheet
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, grd is white, +12vdc is black, etc), this is for you.
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are: Color, Function, Mark on the plug.
Seven wire Trailer plugs:
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
on Sep 23, 2009 | 1998 Ford Explorer
Tip
Hello all,
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 19, 2009 | 1987 Jeep Wrangler
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Tip
Trailer Wiring Standards (Color Codes/Plug Marks)
Hello all,
Columns are Color, Function, Mark on the plug.
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 09, 2009 | 1981 Ford F 150
The light does not turn completely off, it turns on then only half way off.
Please check your wiring inside the connection box.... this sounds like a hot ground to me.
White should be connected to all the whites. Green or bare copper should be connected to all the green or bare and the frame of the fan. Black should connect to a black and/or red and/or blue wire. You may have some hot leg wire barely touching a ground too. If that is the case, it is not popping the breaker because there are loose grounds involved somewhere.
Look at it carefully. Proceed wsith caution. Good luck and let me know whaat happens.
a
Oct 19, 2009 | MinkaAire Artemis in Mahogany with...
Red light goes green but no blue light
the blu light means it is accessing a game/ blu ray
May 03, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Minka Aire Ceiling Fan Logo
519 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
