Question about PANDIGITAL (DPF802) Digital Picture Frame
Dark screen Very dark screen. Can not lighten it enough to see photos
Dark picture..not bright picture
The whole point of a webcam is to be able to see the person you are speaking with, and let them see you. When the image broadcasted by your camera is too dark, the person on the viewing end won't see anything but shadows and dark shapes. Learn how to brighten your webcam image so the people you chat with can see you.
Place lamps behind and to the side of the webcam. This casts a light on your face, but the lamps will not wash out the image because they are behind the camera. Turn off lamps that are behind you. You have trouble seeing things when you are looking in the direction of the sun or a light bulb. Your webcam has the same problems. Don't make it stare at a bright light. Open up a white screen on your computer to brighten your face. The white screen will create the brightest possible light from you computer screen and help lighten your webcam image. This option is best when lamps are not available. Open up an empty tab in your Internet browser, or a blank Notepad document, and expand it to the full of your screen. Adjust your webcam settings. The settings available to you will depend on your webcam, but many of them offer a "Brightness" setting that you can increase to lighten your webcam. Open the program that came with your webcam, then look for a "Settings" or "Options" menu. Increase the "Brightness" setting until it has lightened your webcam enough.
b>
Feb 08, 2013 | Gear Head Computers & Internet
To whom it may concern, The screen is very dark. How can I fix it? Also, how can I change the brightness? thank you for your time!
To adjust the screen contrast (to lighten screen or to darken it)
  1. Press the [2nd] key and RELEASE it.
  2. Press and HOLD the UP Arrow to darken screen, or
  3. Press and HOLD the DOWN Arrow to lighten it.
Keep pressing the UP or Down arrows (whichever you need to press) until the screen contrast is adequate.
In your case, the screen is too dark, so you must press the DOWN arrow to lighten it.
Aug 12, 2010 | Texas Instruments TI-83 Plus Calculator
I turn on the calculator and the screen just shows me this like big dark box that fills the screen and thats all it does.
After you change battery the screen contrast often changes: it can become too light or too dark (your case).
To lighten screen
  1. Press 2nd key and RELEASE IT.
  2. Press and HOLD the downArrow.
  3. Keep pressing the arrow until the screen is light enough.
Jan 13, 2010 | Texas Instruments TI-83 Plus Calculator
A90f dark dark screen
Use brighten controls on monitor to lighten
Dec 22, 2009 | ViewSonic A90f+ 19" CRT Monitor
My texas instruments ti-86 is dark all the time, help me please
After changing the batteries the calculator is restored to factory defaults, but the screen contrast may change. The screen may be too light to see anything or., as in your case too dark.
To lighten screen
Press [2nd] key and release it.
Press and hold [DownArrow] until screen is light enough.
To darken screen
Press and hold [UpArrow] until screen is dark enough.
Hope it helps.
Thank You for using FixYa and for rating the solution.
Dec 04, 2009 | Texas Instruments TI-86 Calculator
Won't power on even though i've installed new batteries. There is no corrosion on the battery terminals.
Check that the terminals in the battery compartment are clean and shiny. Remove any powder left after battery leakage. Insert fresh batteries in calculator. Make sure you respect the polarity diagram. +-+- (Many malfunctions come from incorrectly placed batteries).
After replacing batteries, calculator is restored to defaults and screen display may be too loght or too dark
To adjust the screen: Darken or lighten display
To darken screen
To lighten screen
Hope it helps.
Nov 14, 2009 | Texas Instruments TI-86 Calculator
2nd up
To increase the contrast of the screen you press [2nd] key and release it. Then you press and HOLD arrow Up, till screen is dark enough.
To lighten a dark screen you press [2nd] key and release it; you press and hold the down arrow.
Hope it gets your calculator up and running.
Oct 19, 2009 | Texas Instruments TI-84 Plus Silver...
Dark photos
Check your custom settings in the Lexmark printer utility. I have a different model but mine allows for lightening and darkening of output. Variations in ink density and paper differences make this almost a necessity.
Jan 08, 2009 | Lexmark Wireless X4850 All-In-One Inkjet...
Scans slides too dark.
maybe the slides are too dark, in other words, the pictures you took didn't have enough exposure therefore you it shows up dark.. You could always use photoshop or someother photo manipulation software to lighten the scan, same thing happens with my hp scanner with slide adapter, if it slides just show up dark, lightening it with software will help, unless it is unsaturated/shadows too dark, etc..
Hope this helps.
Nov 11, 2008 | Konica Minolta Dimage Scan Dual IV Film...
PANDIGITAL (DPF802) Digital Picture Frame Logo
48 people viewed this question
Top PANDIGITAL Photography Experts
Gareth Cockram
Gareth Cockram
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
