Question about Nikon Coolpix 4300 Digital Camera
Nikon 4300 wont turn off
My camera recently refuses to switch off even while the switch besides the shutter is turned to off mode It shuts for a sec and restarts even in off-state Please help
  • 1 more comment
  • Sheila Herndon
    Sheila Herndon May 23, 2008
    my camera is doing the same thing, lens going in and out and wont shut off.
  • Anonymous Jan 16, 2009
    I have same problem. Help me please!
  • dgiegler Jan 31, 2009
    coolpix 4300 will not turn off. also in the off or on position it will focus and show on the screen what is being viewed. can also look at already taken pictures but cannot take any pix in any mode.have a warning that says mode dial is not in proper position when selected to ">" when in setup mode and menu is pressed warning message no menu in auto mode. please use another mode. also the above message appears when in "m", "scene", or "A" modes and the menu button is depressed.
    please help
WARNING!!
This CF card cannot be read
Posted on Oct 26, 2007
SOURCE:
Why does my Coolpix overexpose images when zoomed in?
If you zoom in then press the shutter down halfway. If you zoom with the shutter pressed half way you can get an over exposed image.
Aug 04, 2014 | Nikon Coolpix 4300 Digital Camera
I have a 500mm telephoto w/ 2X adapter get ms. 'no lens attached'
You need to shoot in the Manual mode by turning the mode dial to "M". You have to set the shutter speed and aperture yourself, without any help from the camera's light meter. You can review the photo afterward and adjust the exposure accordingly. The histogram will help in this.
Oh, and you also have to focus manually.
Dec 17, 2013 | Nikon D3000 Digital Camera
Nikon D3100 shutter "problem"?
Are your pictures properly exposed and are they sharp or are your pictures degraded? Is that 1/3-second you describe a delay between the time you push the shutter release and the time the picture is taken or somthing else? Check to make sure you're in the proper shutter release mode (slider switch to right of the mode dial). Also, your self-timer may be turned on. Your camera allows you to set a 2 or 10 second delay from the menus. If it is set to 2 seconds and turned on, it might seem like a 1/3-second delay. If that doesn't help, you camera is covered by Nikon's warranty. Contact Nikon Service at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday.
Aug 27, 2012 | Nikon D3100 Digital Camera
How to adjest shutter speed of nikon p90
In the P, S, and M modes, turn the command dial on the back of the camera. In the A mode, turning the command dial changes the aperture and the camera will change the shutter speed to compensate.
In the point&shoot modes the camera will set the shutter speed on its own.
Apr 27, 2012 | Nikon COOLPIX P90 Digital Camera
It doesn't show images in the monitor and at the same time it doesn't take pictures. thanks and more power!!!
your question is not clear. I see technical point of view. you first should disable flash mode (flash off mode), many case the flash circuit continuously force powering on whenever camera switch on and user can not use momentarily. But you can use only in day light condition if the problem condition. If not, it is shutter unit is effective that can work properly. The shutter unit is inner lens unit assemble. You should then consult to local camera tech. Thank and best regard!
May 21, 2011 | Nikon Coolpix 4300 Digital Camera
How do you turn flash off on nikon 4300
With the Auto mode, there are 12 other programmed scene modes. Out of them, one is Flash off mode.
I hope I have answered your query.
Regards
Kanu
Sep 09, 2009 | Nikon Coolpix 4300 Digital Camera
How do you turn off the flash on the 4300
There is a button beside "menu" that has a lightning bolt and an eye under it. Press it. Top-right corner of your screen, you'll be able to scroll through the settings.
Aug 21, 2009 | Nikon Coolpix 4300 Digital Camera
Nikon 50mm 1.8 lens error message
The 50mm lens is fairly old and uses a different system to the later lenses. On the D90 and other later cameras you should rotate the ring to 22 and lock it there using the lock just above the aperture ring.
To adjust the aperture you use the front dial by the on/of switch.
Try it out in A mode. Rotate the mode dial on the top left of the camera to A (Aperture Priority mode) then lightly press the shutter button to turn the meter on. Then rotate the front dial and you will see the aperture reading changing.
The older Nikons changed their apertures using the ring but the later Nikons use the camera controls.
Jun 25, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon D80
Your question is not much clear. When the camera shut off?? eg, after pressing shutter, etc. Did you use original battery?? What is your camera age?
PROBABILITY :
Your camera might be have on/off button problem.
EXPLANATION :
I had experience this with my coolpix 8xxx (could not remember exact model). The problem is with nikon on/off switch and shutter design. After a few years of usage, then the on/off switch with start losen a bit. These will cause autofocus activated without you pressing the shutter yet, and it will shut off without warning.
SOLUTION.
There is no DIY solution for this problem. For temporary, try your luck with pressing the on/off swith a bit harder. But that is for temporary + a bit of luck. Best solution is to send the camera to Nikon Centre.
Oct 24, 2008 | Nikon D80 Digital Camera with 18-135mm...
Manual Exposure mode Nikon F80
1) turn the mode switch/knob on the left of the camera to M ( manual mode ) 2) turn your lens to the highest f-stop ( 22 or 16 depending on your lens ) 3) in front of shutter release button you have control for your aperture : turn until the desired aperture is displayed ( view finder or the LCD monitor on the top ) 4) your shutter speed setting is controlled with your thumb with the control situated next to the strap lug on the right hand side of the camera. 5) press shutter release half way and look through viewfinder and see light meter reading and adjust either shutter speeds or the aperture as explained being guided by the l.meter.
Sep 23, 2007 | Nikon F80D 35mm SLR Camera
Nikon Coolpix 4300 Digital Camera Logo
276 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
