Question about Roland JUNO-Gi 61-Key Mobile Synthesizer with Digital Recorder
Some keys of my Juno Di got Out of tuned :( pls help
Please Help.. some keys of my JunoDi got out of tuned. (1-3 keys per octave) maybe because of the incident last nightt, (my friend accidentally throw some liquid at my keys) but no so sure if that's the cause... WHAT SHALL I DO??..PLEASE HELP
    New Friend:
  • 21 Answers
Un screw your DI and remove the rubber pads under the keys and gently whip any liquid under it and on the key on it .the liquid is acting as resistance to result in de tune.
Posted on Nov 22, 2013
3 Suggested Answers
  • 5603 Answers
SOURCE: Some keys on my roland
The key contacts need to be cleaned. They are usually conductive rubber pills in silicone domes that get pressed onto circuitboard traces by the keys. Disassemble to get at the contacts. clean ONLY with 99% isoprophyl alocohol and Q tips. Clean both the pills AND the circuit traces they contact.
Be very careful of cables when opening the unit. Document where all the screws go and their length and threads.
Posted on Nov 15, 2010
  • 5603 Answers
SOURCE: Volume of some keys (one
Take it in for repair. There may be a broken line for the velocity sensing of that octave of keys that is causing the velocity to be sensed low. The repair is NOT DIY if this is the case.
Posted on Sep 02, 2011
How do i fix a Yamaha P95 that sounds Es with Fs and Bb with Bs across all the octaves?
Whether it happens to all of the key?
If yes, transpose setting may have changed. Change the setting to normal (0).
If the normal transpose, but tuning is still not standardized, check Pitch Setting.
To Restore Standard Pitch setting:
Hold down the A-1, B-1, C0 and C # 0 keys simultaneously and press any key between C3 and B3.
View image :
fix-yamaha-p95-sounds-es-fs-bb-bs-across-vzw3qjj2ajjzgyoqcmqtppa4-4-0.jpgfix-yamaha-p95-sounds-es-fs-bb-bs-across-vzw3qjj2ajjzgyoqcmqtppa4-4-1.jpg
If the above procedure is still no effect, try resetting the factory settings / Initialize overall: :
This is the steps:
Initializing the Settings
When you initialize the settings, all backup data stored to this instrument will be initialized and reset to the factory default settings.
Turn off the power to the instrument. Then, simultaneously hold down the C7 key (right-most key on the keyboard) and turn the power on again.
NOTICE
Do not turn off the power to this instrument while it is initializing the data in its internal memory (that is, while the button indicators are flashing).
View image:
Notes:
If this instrument somehow becomes disabled or malfunctions, turn off the power to the instrument, then perform the initialization procedure.
Sep 07, 2015 | Yamaha Music
How to tune 12 string acoustic with ga40
Unfortunately, the manual on
http://www.korg.com/us/products/tuners/ga_40/
indicates that 12 string is not supported.
The owners manual can be downloaded at
http://i.korg.com/uploads/Support/GA40_EFG1_633661472559800000.pdf
The YouTube tutorial is at
https://www.youtube.com/watch?v=Of4CRajvq0E
with a 12 string, you can often tune the octave until the tuner sees the matching note. It won't see the correct string number, but an A note is an A note, whether or not it's an octave higher.
Hope that this helps.
Nov 15, 2014 | Korg Ga40 Guitar Bass Tuner W Batteries
3 key notes not working and can't write my savings to the banks..
Hi, You can reset your whole keyboard by holding down the top C ( highest key ) whilst turning on.
This is unlikely to clear 3 non working keys. My guess is that the contacts under the rubber switches have worn or dust is under the contacts. You could try cleaning first under the rubber contacts if this fails replace the contacts ( 1 per octave ) Part WF212202 contact me if you need more information
Pictures attached may help 0482dd26-e9cb-4b61-b47e-f97d90aa782c.jpg 42e5c956-fedc-40b9-ae04-8bf3e98b22a2.jpg
Mar 28, 2014 | Yamaha DGX-640 Portable Grand Piano...
Volume of some keys (one octave) are lower than rest of the keyboard, any advise please ?
Sep 02, 2011 | Roland Juno-D
Some keys on my roland juno d wont sound. How do i fix this problem? Please help.
Nov 13, 2010 | Roland Juno-D
I have a 6 month old keyboard and have found that middle octave A and lower octave note C are sounding really off when played together. What could be the problem? The store where I purchased it has...
Thisis hard to troubleshoot... The keyboard insynths are usually scanned as a matrix... If a disconnect diode has failed, then wrong notes can be triggered. There is USUALLY rows of the diodes on the circuit board where the keys hit. There are usually TWO contacts per key in order to sense key velocity. The lkey contacts are usually conductive rubber pills pressed against circuit traces under the keys. One sometimes needs to clean these contacts using 99% isoprophyl alcohol and Q tips.
I would do further testing of ALL combinations of notes played together to see if possibly any others show up as that could point to a particular failure.
Oct 27, 2010 | Casio Ctk574 61 Key FullSize Portable...
Faurite buttons bushed there is a quarter note gap in sound in juno di how can i solve
Not sure what you mean by "buttons". IF you are trying to change voices, a lag between sounding of the old and new voice can be expected as the generators within the synth are reconfigured for the new voice. This is a lower-end synth and as a result doesn't haved the performance of some of the newer ones.
If the lag is just between notes that are being keyed using the same voice, that is too much delay and something is probably set wrong.
Oct 15, 2010 | Roland JUNO-D Synthesizer
Im having issues with my roland juno-d. there are 3 keys that are not sounding properly, they are generally quiet and slower to respond. the board and reubber have both been cleaned with alchol
The next step gets very complicated without test equipment.
It is important to realize how these keyboards work. ( I assumed you cleaned the black rubber dot that forms the contact.)
The keys are "scanned" by the electronics. Usually 12 bits are read at a time and the computer scans through the banks of keys that are usually 1 octave at a time and two per bank to enabling reading the velocity as the contacts for a key close one slightly behiund the other.
If there is any deformation of the contact bearing dome, that will cause a velocity sensing problem.
The keys are scanned as a matrix. To avoid current going backward through keys in other octaves, there are disconnect diodes that prevent coupling of one octave with another and between the two sets of contacts (for velocity sensing) within a single octave.
Do verrify that you cleaned the board and the black rubber dots with 99% isoprophyl alcohol and NOT rubbing alcohol as the latter contains an oil that worsens the problem.
Jan 29, 2010 | Music
Yamaha Electronic Piano- certain notes malfunctioning
Either the first or second closure matrix line for the "A" keys is bad.
This may be a cracked or shorted circuit board.
A bank of diodes is used to prevent sneak electrical path if more than one octave has notes pressed.
First thing is to clean ALL the key contact areas and the conductive rubber pills with 99% isoprophyl alcohol.
This involves dis-assembly of the key area. If you are not competent in electronics, best left to a pro shop.
The keys are scanned in a matrix, two contacts per key and all the individual notes are in common (all the "A;s", "B's"...) And each octave is strobed for the first set of contacts and then for the second set of contacts. an the whole octave is read in parallel.
The reason for two contacts is one closes first and then the other as a key is lowered. The time between these is measured and is the note VELOCITY which for a piano controls the loadness of the note. IF ONE of the two fail, the loudness will vary as yours does.
Nov 24, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Roland Juno D Keyboard Keys not sounding
The problem of the Juno-D is de rubber strips inside under the keysthere are 5 strips, you have to clean this rubber strips with alcohol and clean the board too, this will resolve your problem if you leave the Juno-D without playing for a long period you will get the same problem again. this is a very poor keyboard it,s a pitty that Roland Make so poor keyboard!!!!
Dec 16, 2008 | Music
Roland JUNO-Gi 61-Key Mobile Synthesizer with Digital Recorder Logo
71 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
