Feeding tub aulssers - Computers & Internet
Why is the top spray arm not turning
All of the water coming to the upper spray arm comes through the feed tube. If the feed tube is blocked or the probe flapper is hung open, water will not flow properly to the upper spray arm. Be sure that when you push in the upper rack the manifold probe is in position in the feed tube. Try adding more water in the tub to see if the upper spray arm starts rotating. Other possibilities; low water charge, cracked spray arm & poor wash pump performance.
Jul 28, 2016 | Dishwashers
How does pressure switch work in ge top load washer? pulled hose off at box mounted on tub and blew and can hear contacts close, but water still fills
You will find the Pressure bottle or hose is at fault, perhaps hole in hose or dirt in the bottle feeding it from the tub....
Feb 10, 2011 | General Electric Washing Machines
When using the tub water comes out of the shower head
if the pipe feeding the tub spout is pex, cpvc or poly then it needs to be replaced with a pipe with a larger i.d. like copper or galvanized or reduce the pressure to the house.
Dec 01, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Cold water trickles in tub. Hot water fine.
remove the cold water hose from the machine that is your service line feeding into it.
a screen in the inlet were the hose attaches to is probably clogged up
May 28, 2010 | Washing Machines
I just installed a series 13/14 single valve tub/shower faucet. When I try to turn on just the tub spout, the shower comes on as well. What could be causing this?
most likely problem is to much pressure in water lines if u have shut off valves on to feed lines turn them down a little will decrease pressure to the valve other problem the spout {tub} diverted is partially engaged, loose,debris or defective if u can reremove the spout and observe the valve for proper function
Feb 13, 2010 | Delta Monitor 13 Series Chrome Trim...
Our Kitchenaid isn't cleaning the dishes, especially the top rack.
check that the upper rack water feed tube is inserting properly to tube inlet.you can verify this by observing under the top rack near the rear of unit closest to the back wall of tub....chances are the manifold is going "beside'the tube instead of properly enclosing tube so water will feed into spray arm vs shooting at the door
Nov 27, 2009 | Kitchen Ranges
I don't get enough hot water, temp is too cold
This sound like you need to reduce the inlet pressure of the cold feed to the mixer. If there is no 'non return valve' fitted and the cold feed pressure is too great, i can in effect push back the hot water feed and reduce the temp. So how to fix?? trace back the direct water feed to the shower faucet/outlet feed and simply reduce its pressure by 1/4 turning the 'in-line' stop valve the plumber should of fitted if he was any good at his working standards.
Hope this Helps
AndystUK
Nov 08, 2009 | Moen & One Handle Tub & Shower Faucet
Cold water feed into tub seems somewhat pluged.
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 05, 2009 | Kenmore Washing Machines
Dishwasher leak
must need a new air tube or worse still the air chamber has a split in it
clean machine out in w/shop and with sides off check out with a light to see where the leak is realy comming from it may be leaking from the top wash feed pipe leaking around pipe to tub
these do fracture there and water running down to base
if so replace feed pipe
Jan 21, 2008 | Hotpoint 24 in. HDA2000Z Built-in...
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
