Question about Canon P200-DHIII Calculator
Setting Time & Date Canon P200-DH III
Setting Time and Date
SOURCE: Settting up tax rate on Canon P1-DH III
push CA
hold TAX+ button until tax% starts flashing on the display
put in the required rate
push CA
should now be set
Posted on Mar 04, 2009
SOURCE: need free download for a user manual
hi ..its frankyman go to www.eserviceinfo.com
Posted on May 20, 2009
  • 3 Answers
SOURCE: How to reset the clock?
Push the button with the clock and calendar, this is directly over the 'cost' button, to display the date or time. Then use the 'Time set' button (this is the one for Memory - Plus - Equal). Hold the 'Time set' button down until the first figure blinks then release it. Use the number buttons to change the setting. When you have gotten the correct date or time entered oress the 'Time Set' button again.
Although it is only printed with 'Time Set' the button works for the date just as well.
Posted on May 05, 2010
Testimonial: "Just what I needed to know! Thank you"
vinzen
  • 217 Answers
SOURCE: Calculator still functions, but printer is not
Try pulling batteries/power /out/off.look for reset hole usually a very small hole on back. push in with pin.reinstall batteries (check they are good)or use new,if power adapter plug in turn on try to print.These instructions are genetic not specifically for your model. The printing issue you describe is typically a glitch in the program.
Posted on Jan 04, 2011
SOURCE: Canon P200-DH calculator ... the
Look at the rubber numbers inside the machine. They are probably clogged with ink (at least mine was). I researched and could not find a specific answer, finally I asked how to remove ink from your hands. Everyone said use bleach. I tried clorax 2 bleach on the rubber numbers wiped it clean and let it air dry. Worked like a charm!!! This might not be the proper way but it's working.
Posted on Jul 04, 2011
Calculator still functions, but printer is not printing anything but nonsensical giberish. Canon P200-DH III
Jan 04, 2011 | Canon P200-DHIII Calculator
How do you program clock and date on a Canon P200 DHIII? Where do I get or how do I refill Ink pad?
Below are the steps to assist you in
setting the Date and Time on your calculator.
NOTE: The "Time Set", "AM/PM", "12/24" and "Format" associated keys are
on the faceplate above the respective key. Position the calculator so
that you can look directly over the keypad to see the notations.
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first
digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should
stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press
the AM/PM accordingly.
stop blinking and the time is then set. The seconds will again be
displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To
return to either the TIME or DATE, press the CALENDAR/CLOCK key to
toggle between them.
Sep 26, 2010 | Canon P200-DHIII Calculator
Mar 30, 2010 | Canon P23-DH Calculator
Canon P200 DHIII calculator needs to be changed the date. Can you tell me how?
Setting the date:
Setting the time:
displayed.
Jan 22, 2010 | Canon P200-DHIII Calculator
How do you set the date & time on a canon P23-dh?
Press and hold the ClockDate Set button for three seconds until the display shows the date with the first digit blinking. Enter a two-digit month, a two-digit date, and a four-digit year, followed by the ClockDate Set button.
Press and release the ClockDate Set button. Press and hold it for three seconds until the display shows the time with the first digit blinking. Enter a four-digit time, press AM/PM as appropriate, then press the ClockDate Set button. Press CE/C to finish and return to calculation mode.
You can download a manual from http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=346&modelid=15431
Oct 03, 2009 | Canon P23-DH Calculator
Need free download for a user manual
May 20, 2009 | Canon P200-DHIII Calculator
Canon P170-DH Calculator
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
Jan 10, 2009 | Canon P170-DH Calculator
Setting the date and time
download the user manual (P23-DH III) from here:
http://rapidshare.com/files/181603396/P23DHIII.PDF.html
Jan 08, 2009 | Canon P23-DHIII Calculator
Can't set date
Download the user manual (P23-DH III) from here:
Nov 15, 2008 | Canon P23-DH Calculator
Canon P23-DH
I don't think the P23-DH has a calendar/clock mode. I have found the instructions for setting date and time for the P23-DH V. If your calculator does not have [Calendar/Clock], [Time Set], and [AM/PM] keys, you cannot set the date and time.
To set date:
1. Press the [Calendar/Clock] key once
2. Press and hold the [Time Set] key for three seconds
3. Enter the date in MMDDYYYY format
4. Press the [Time Set] key
5. Press the [C/CE] key
To set time:
1. Press the [Calendar/Clock] key twice
3. Enter the date in HHMM format, press [AM/PM] key if necessary
Aug 27, 2008 | Canon P23-DH Calculator
Canon P200-DHIII Calculator Logo
256 people viewed this question
old marine
old marine
