Question about 1995-1998 VW Golf 4 Cylinder with ABS Front Wheel Hub Pair
Car wont start but cranks
Car wont start but makes multiple clicks later on cranks but dont start
    Problem Solver:
  • 16 Answers
Did you check for fuel to the injectors? Look around your injectors for the bleeder valve, it looks kind of like a tire valve, stick a small screw driver in it and push down on the valve, if fuel doesn't squirt out then you are not getting fuel to the engine. That could be your fuel pump fuse/relay or the fuel pump itself.
Posted on Nov 21, 2013
  • Jon Dow Apr 27, 2014
    Clicking sound indicative of weak battery. The fact that it latter cranks may be the result of the battery temperature increasing.
Wont start with key, all lights work, everything comes on, but will not turn over. I replaced key or switch? ,checked all fuses, but have no power to starter fuse
can i as symptoms before all those parts changed/???????
working with out a schematic, kinda stinks, no?
this IS not a no start ,sorry its NO CRANK
is car auto or stick, both are wired different.
see the steps here.
i dont have liberty books, (dont like this car)
replaced key switch, surely not, you that is not possible if car
has SKIN IMMO system. not at home, not DIY
if you , damage SKIM, LATER WHEN CRANKING WORKS
nowwill never start. ever. (immoblized )
to crank the engine on jeeps, the start relay closes
what closes that , answer the transmission park neutral switch
try cranking in neutral yet, bingo>
no cranks are easy , see below.
no starts, vastly more complex
most these cars use permissive, start relay
the trans gives this permissive so drivers can start in gear.
and run over muffy (safety)
https://www.jeepdied.com/no-crank.html
to fix cars like this
go to mitchells (online) google it. all shops have this....
or
here,, on CD, and book.
https://www.techauthority.com/en-us/products/81-370-05060CD
if you scanned the PCM with any scan tool
cranking, guess what, it would have errors called
this is 2005 Grand cherrokee,
see this simple drawing.
pin 30 realy must be 12v, if not fuse 10 blown or
main fuse. fronting it.
pin 86 is 12v in park and neutral, if not
p/n switch bad or loss of 12v to said switch.
pin 87 is GOAL, 12v here cranks starter.
last it that pesky 85
this is the PCM, logic
0vdc here, energizes start relay
now the bad news. if all voltage pass but 85, stuck at 12v, (circle 'A")
then you must scan the PCM to find out why
it has good reasons. and will tell you.
i can name 3 but ive not clue as to the options on car , like for example remote starting option.
etc.
Jan 31, 2016 | 2005 Jeep Liberty Sport
Wont start after running for a while. service lights work, radio, headlights but wont crank. just replaced starter, got new battery about a month ago. after 5-8 hours car starts with no problems.
Hot does make a difference. You say it won't start, but does it crank and not start, or not even crank? If cranks but will not start, any electrical part may fail as it heats, and when you shut it off the engine gets much hotter since coolant is no longer circulating. Thus, a marginal crank or cam sensor, or coil/ignition module may work while cold of while engine is running, but fail when you first turn car off.
Jul 08, 2015 | 2008 Saturn Aura
Car wont crank but will start
do a fuel pressure test on your fuel pump
Apr 14, 2014 | 2000 Chevrolet Blazer
Turning over but not starting
sounds like a faulty starter possibly the selinoide on the starter
Mar 03, 2014 | Kia Sephia Cars & Trucks
I drove to work fine got back in 4 hours later car won't start battery dead. then got a jump came home turn car off now car wont start.
If you just hear a click, try this:
This procedure usually works:
·Check the battery cable connections:
Make sure the positive cable, makes a good connection at the battery and at the starter. Make sure the negative cable makes a good ground connection at the battery and (preferably) at the engine.
·Check the battery the simple way, like this:
Turn on the headlights, then try to start the car.If the headlights do not dim or go out, then the battery is likely ok.
·Check the starter and solenoid:
If the wiring looks ok, then look at the starter solenoid for a good connection, and proper voltage at the starter(10 volts minimum while cranking).
If the starter spins and no crank, the problem is most likely the Solenoid's bendix gear is stuck.
Have someone hit (not too hard) the starter while you try to start the car. This usually works by dislodging a stuck bendix gear.
·Make a simple test of the alternator:
If you can, somehow get the engine running, measure the voltage at the battery. It should be at least 13.6 volts to properly charge the battery.
Apr 10, 2013 | 2001 Audi A6
2001 lincoln ls cranks but wont start
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
Feb 20, 2012 | 2001 Lincoln LS V8
2001 maxima wont start after changing crank and cam sensors
This will help.
Thanks.
Feb 17, 2012 | 2001 Nissan Maxima
2000 pontiac montana engine cranks over but will not start
This will help.
Thanks.
Feb 12, 2012 | 2000 Pontiac Montana
Starter wont crank on a 2000 oldsmobile intrigue
Check your manual if you have it. I believe you need to have the key in the ignition in the ON position for about 10 minutes to reset the security system.
Jul 08, 2010 | 2000 Oldsmobile Intrigue
I have a 1990bmw 325i. i turned the car off one day. ran in the store. ten minutes later came out and the car wouldnt start. left the car. came back thirty minutes later the car started. drove the car 25...
This will help.
Thanks.
Dec 14, 2009 | 1990 BMW 3 Series
1995-1998 VW Golf 4 Cylinder with ABS Front Wheel Hub Pair Logo
102 people viewed this question
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Tom
Mike Stager
Mike Stager
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
