Question about Kitchen Appliances - Others
Instruction to set utilitech model UTTNOCD2 TIMER FOR LIGHTS
HO DO I SET A UTILITECH TIMER FOR CHRISTMAS LIGHT TO COME AND GO OFF ,ODEL 154182
3 Suggested Answers
SOURCE: where can I download instructions for utilitech timer
UTILITECH - Grounded in Quality
Digital 2-Outlet Timer (TE06WHBL)
Instruction Manual & Warranty
Before using your timer please read the following instructions carefully.
FEATURES
- Up to 8 ON/OFF events per day/56 ON/OFF events per week
- Option to program individual days or 8 different weekday groups
- Minimum switching period one minute
- Summertime/wintertime change over
- Easy to read LCD display
- Random automatic ON/OFF security feature
- Countdown feature
- Manual override button
- Rechargeable battery back-up (if there is no LCD display, plug
timer into a wall receptacle, this will recharge the battery)
SETTING TIME
Press and hold CLOCK key, then press DAY key to select correct day,
HOUR key to select correct hour, and MIN key to select minutes. When
MIN key is released, time will be set with seconds starting from 0.
Either holding down or repeatedly pressing appropriate button can
advance days, hours and minutes.
Do not set ON and OFF for same time.
PROGRAMMING EVENTS
The timer has the capacity for 8 ON/OFF events per day.
Save program capacity by using available blocks of days.
Blocks of days are:
1. M,T,W,Th,F,S,Su
2. Individual days of the week
3. M,T,W,Th,F
4. S,Su
5. M,T,W,Th,F,S
6. M,W,F
7. T,Th,S
8. M,T,W
9. Th,F,S
For each ON time and each OFF time--DAY, HOURS and MIN must
be set. Press PROG key onceto set first ON time--"ON" and number
"1" appear to left of LCD display indicating to enter first ON time.
Press DAY button to choose required day or blocks of days, then set
hour and minutes using HOURS and MIN buttons. After setting required
ON time, press PROG button to validate entry and move onto first
OFF time--"OFF" and number "1" appear to left of LCD display
indicating to enter first OFF time by using DAY, HOURS and MIN
buttons as above. Press PROG button to validate this entry. Repeat
remaining 7 ON/OFF settings as required. After setting required
ON/OFF settings, press CLOCK button to return display to clock. Timer
is now ready to operate. Check programmed settings by pressing
PROG button repeatedly--each setting will appear on screen.
MANUAL OVERRIDE
To choose permanent Manual ON, permanent Manual OFF,
Auto ON or Auto OFF, press Manual button. Each mode will be
displayed on screen. When choosing Auto ON, timer turns ON until
next programmed OFF time. The programmed settings will only work
on Auto mode. When Auto mode OFF is chosen, timer is OFF until
next programmed activity. (Inverted black triangle on LCD points
to either AUTO or MANUAL indicating which is selected)
COUNT DOWN FEATURE
To enter count down feature, press CLOCK and PROG buttons
simultaneously. Using HOURS and MIN buttons, set count down time.
(Maximum selection is 9 hours 59 minutes, minimum is 1 minute.)
Press MANUAL button to start countdown. Output will turn ON until
end of count down. Count down may be paused at any time during
period by pressing MANUAL button. To re-start, press MANUAL button
again. To review time during count down period, press and hold
CLOCK button. Release CLOCK button to return to count down display.
Note: To return to timer mode, press CLOCK and PROG buttons
simultaneously.
RANDOM AUTOMATIC ON/OFF SECURITY FEATURE
With this option selected, timer will switch ON and OFF in a random
pattern at least once in every 8 hours. (This may mean timer will
switch OFF within a set ON period, or vice versa.) Ideal for use with
a light--switching it ON and OFF automatically gives appearance of an
occupied home, but not at exactly the same time every day. To enter
Random mode, press DAY and HOURS buttons simultaneously.
An "R" will appear on display and unit will start random switching.
If no programmed times are set, timer will switch ON or OFF
approximately 1 minute after entering Random mode, then continue
randomly. To turn Random mode OFF, press DAY and HOURS buttons
together again.
SWITCH OVER SUMMERTIME/WINTERTIME ZONE CHANGE
To change from wintertime to summertime, press HOURS and MIN
buttons simultaneously. Clock will be set forward one hour and
"S" will appear on display. Repeat same procedure to return to
wintertime.
Note: if unit is purchased during summer, set clock time for one hour
less than correct time, select Auto mode and press HOUR and MIN
keys simultaneously. The unit will then adjust to correct summertime
and "S" will appear on LCD.
RESET
To reset unit for time and programmed ON/OFF settings,
press RESET button.
IMPORTANT SAFETY PRECAUTIONS and
RATINGS
[Contact the manufacturer; I've already wasted too much time typing
this in:
AmerTac
Saddle River Executive Centre,
One Route 17 South, Saddle River, NJ 07458
800-777-0802
www.amertac.com
Made in China
Posted on Oct 26, 2010
SOURCE: Don't know to set timer
1) Open following page to identify timer for sure
Instructions for Utilitec 0148297 are supposed to be same as Woods 59366
http://waterheatertimer.org/Woods-timers-and-manuals.html#59419
http://waterheatertimer.org/pdf/Woods-59366-manual.pdf
2) If this is not your timer, then stop by Lowes and buy another timer.
Use sharp blade to carefully cut open side of package, and slide out instructions.
Scan instructions into pdf format and post instructions on your website.
Add a comment to this thread with web location of that manual so others can enjoy your generosity.
Put manual back into package and return timer for full refund.
3) See other available Utilitec manuals:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
4) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 07, 2011
Utilitech digital timer
The timer could have been miswired.
Mar 12, 2014 | Hardware & Accessories
I lost my instructions for my Utilitech #0357930 timer. I cannot get it to work; I can set it to start but not stop. Just need some directions. Buttons on it are On, Off, Day, Hour, Min, Enter, Pro
The AutoChron 81000 Programmable Wall Light Switch Timer is identical to the Utilitec #0357930 (AmerTac) TMDW50L. Here are links to manuals for models prior to and as of 2012.
Before 2012
As of 2012
Nov 28, 2012 | Hardware & Accessories
How do I program a Utilitech 0148297 timer?
See following link to identify your timer with instructions:
Rotate dial until current time lines up with arrowhead; when plugged in, dial rotates
48 segments located on dial; each segment is 1/2 hour
Segment pulled up = lights OFF
Segment down = lights ON
Override switch located top of timer, move switch to TIMER
If this is not your timer, then add a comment
If you do not want additional free help, take advantage of fixya phone support.
For a price, fixya expert speaks to you via phone while you set timer.
Dec 30, 2010 | Woods 59200 Lamp and Appliance Timer with...
I need a manual for UTILITECH #0148373.. and i need it now! PLease help me..i need to know how to use this product. HELP PLZ!
Open following link to correctly identify product:
http://cgi.ebay.it/UTILITECH-2-OUTLET-TIMER-0148373-15-AMP-LOT-OF-4-/290468257053
Utilitec 0148373 timer is plug-in type timer.
Set on-off times by moving pins.
Pins are located on dial and stick up. They can be moved back and forth like stick-shift on car.
See example of pins at following link:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
Instructions:
Turn ON lamp.
Light bulb is good.
Plug lamp into timer.
Plug timer into outlet.
Move some pins outward.
Then manually rotate dial clockwise to watch how lights turn on-off.
That will tell you if lights turn on or off when pins are set outward.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial turns as time passes.
Lever on top of timer is moved to 'Timer'
Dec 30, 2009 | Kitchen Appliances - Others
How to program utilitech 2-outlet timer
I bought a Utilitech #0192775 self-adjusting wall timer to regulate some window candles. I want to simply set it to come on from dusk to dawn, and have followed their directions the best I can. However, it does not work. Even some of the steps in the instructions are not on this model, so it is impossible to follow their directions to the "t". Do you know how to get this wall-timer to do what it says it will do? Thank you!!
Nov 22, 2009 | Hardware & Accessories
Kitchen Appliances - Others Logo
451 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
