Question about HP w17e Monitor
WHEN ON FOR AWHILE OSD LOCKED WILL POP UP AND SCREEN WILL GO BLANK
My computer says OSD locked , ive tryied every thing and nothing worked , HELP!!!!!!!!!! PLEASE
On screen display is locked. Fix it by:
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD. Source(s): http://h10025.www1.hp.com/ewfrf/wc/docum...
Aug 12, 2011 | Computers & Internet
A small little blue box appear in the middle of my screen with OSD locked and after 10 seconds it changes to OSD unlocked and it doesn't go away!!!
hi,
please browse the following site
I have a RAZ 3, cingular service and at the top, middle of my screen is a ..... Hi, wondering what the the blue blinking icon which what appears to be 2 small white ... I notice it after Ive had my cell off for awhile and turn it back on. ... and at the top of the screen it looks like a little box with an A in it, ...
www.askdavetaylor.com/what_do_all_the_icons_on_my_motorola_razr_v3c_phone_mean.html - Cached - Similar
May 30, 2011 | Office Equipment & Supplies
My monitor is eperiencing OSD locked and it keeps on popping out the screen. how do i fix it?
Hi rimandopaolo,
I see that you are getting the OSD locked pop up on your screen.
Press the Menu button on your LCD monitor look for the OSD option on the menu once pressed selct the OSD option try to see if it will give you an option to unlock the OSD setting on your LCD monitor
I hope this helps.
Have a nice day,
mvincentc
May 11, 2011 | Hannspree HW191D LCD Monitor
I get OSD locked and cannot change the screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock is displayed. If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
Jan 26, 2011 | AOC Monitor
"OSD LOCKED" box on my screen
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
Osd main controls locked
Press the OK button for 15 seconds. That should unlock it.
Apr 25, 2010 | Philips 170B4MG 17" LCD Monitor
OSD Locked pop menu
You must reset the on screen display in the menu. Hold down the Menu button for at least 60 seconds. A menu list will appear on your monitor screen. Using the adjust button, press the arrows to enter the menu. Scroll down to the Reset section.
On the right side of your screen, you will see an alternating Yes/No choice. When the Yes message flashes, press the Ok button. The menu should be reset and the flashing OSD control message should disappear.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | Philips 190B6CB/27 19" LCD
W2361vg
Aug 29, 2009 | LG L1915S 19" LCD Monitor
OSD Main Controls Locked
Hold the "OK" button for about 20 seconds
It will initialy come up with the message "OSD Locked" and then after the 20 seconds a ne message will appear "OSD Unlocked"
Dec 20, 2008 | Philips 150S4FB 15" LCD Monitor
How do you get the covers off? "Does not support this mode"
Well here I am again trying to get the covers off of an unfamilar device. I found the 2 screws at the bottom and removed them.. On a hp 1702 I just forced the sides open, pulling and bending to pop the cover off.. How do you get this mag cover off?
Problem indicates on screen "Does not support this mode" on power up, then screen goes blank. OSD doesnt work... blank screen... Does not support message looks good though for an instant...
Feb 16, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
HP w17e Monitor Logo
61 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
