Question about Gateway (5502156) CD-ROM Drive
Gateway P4D-66 battery replacement
On boot up, I get a battery error. I've searched the mother-board over and over. I've even pulled it out and search the back side. I can't seem to locate the battery.
Code
  • 33 Answers
SOURCE: Gateway 7405gx boot failure
Hi Dan -
On this particular Gateway series of laptops, there is actually a bios "chip" you can replace entirely. It's sitting in a cradle right next to where the keyboard connects to the mobo (square black chip, one angled corner). It's very easy to pop out and replace, and is definitely something I would try.
You can do a search on eBay for "gateway bios chip" and you should have some luck.
I hope all goes well.
Posted on Nov 23, 2007
SOURCE: replacing a mother board for a gateway 505gr
First off find out what form factor the tower will support. most new mob will tell you what form factor they are.
Posted on Dec 31, 2007
compdoctor20
  • 172 Answers
SOURCE: Gateway Computer
CVI error is a visual interface error, most likely a graphics card built onto the syetm board. However the motherboards are no longer available but there are a number of ways to upgrade this pc if all else in in good order.Contact for further support
Posted on Dec 01, 2008
ericbrunswic
  • 88 Answers
SOURCE: signal to monitor goes in and out, mostly out
Hopefully, it is just the on board video that has gone bad, and not the motherboard. When you install a video card on a PC, that has on board or integrated video, you will need to access the BIOS screen on start up and disable the on board video. That way the video signal will come from the new video card and not the on board video.
I hope this helps,
Eric
Posted on Jan 18, 2009
Geekman
  • 32281 Answers
SOURCE: I spilled juice on my gateway T-6330U laptop
Check the video connectors on the motherboard.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Posted on Sep 21, 2009
Gateway MT6840 won't power up
before checking ur mother board check for ur operating system.
Mar 08, 2012 | Gateway MT6840 Notebook
D600 wont power up
Try removing the battery and boot on the power cord sometimes the battery shorts the system so it will not boot if it does boot then you need to replace the battery it could be the battery is dead and your power cord is bad check and make sure that is not the case if the power cord is good then I would look into replacing the mother board you can find a replacement on Ebay or at dell .if you have to replace it do a google search on hot to replace the mother board on a Dell latitude D600
and you will ba able to get step by step on how to disassemble it
Aug 28, 2011 | Dell Latitude D600 Notebook
GateWay FX6800-01e Computer After computers been shut down and I attempt to boot up, System will not boot. I have to go into the BIOS and reset the boot sequence. BIOS reflects the removable Seagate...
deffintly sounds like a cmos battery issue. these are very easy to fix. all u have to do is take a antistatik strap around your wrist and hook to computer. you then can tak a flat head screw driver and pop the battery off the mother board. your can replace looks like a watch battery and is very common . ou can pick up at any computer store or watch place. heres a video that u can actually see how to do it http://www.youtube.com/watch?v=tkBWZOtp2is
Jan 06, 2011 | Gateway FX6800-01e PC Desktop
Cant boot up gateway gt5628
pull the battery off the mother board for a couple days to reset the bios
Mar 08, 2010 | Gateway (4000444) Motherboard
Gateway GT5014 will not boot.
Ok, this is a mother board issue. the entire mother board seems to be malfunctioning. the blinking amber/green light is confirming this. the mother board may have some fried circuitry and it will have to be replaced in this situation.
I would recommend extracting the mother board and stripping it. look for any discoloring factors that will lead to a burn out location. this will direct you to the necessary repair zone.
Please rate and have a great day:)
May 13, 2009 | Gateway GT5014 PC Desktop
No Boot
if u didn't get any thing on display even check signal cable the problem is in the monitor
or you are getting check signal cable the problem is in the mother board or Ram first change the ram even thou you are not getting display change the mother board
Apr 16, 2008 | Computers & Internet
Hi Dan -
Nov 22, 2007 | Gateway 7405GX Notebook
MODEM FRIED, NOW I GET COM1 ERROR WHEN REINSTALLING VIA CD(S)
If it's a separate modem card, replace it.
If it's the built in modem, you'll need replace the mother board.
If you have an extra slot, you might be able to install a cheap add-on modem card which should override the built in. But that's a long shot may not work but worth a try.
Nov 05, 2007 | Gateway 507GR PC Desktop
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
