I have windows 8 and cannot print coupons - Computers & Internet
My account was charged but I don't know how to print out my coupon, however I did print out a receipt.
yes, the coupon should come to your email, there should be a place on the coupon where it show to print
Mar 29, 2016 | Office Equipment & Supplies
Hp printer will not print coupons
In addition to downloading and installing the coupon printer, please make sure that the coupon printer is enabled in your browser and that you are using a compatible browser. System requirements along with tips for printing can be found at http://help.coupons.com.
Thanks!
Nov 27, 2012 | HP PSC 1350 All-In-One Q3500A Printer...
I cannot install coupon printer from coupons.com
You shouldn't need a coupon printer to print the coupons in the first place. The virus software is probably seeing something it doesn't like about the program. I would never recommend installing something like that especially when you can print things off the internet anyway. Stay away from installing downloaded things unless you really know they are safe.
Aug 14, 2017 | HP Computers & Internet
I Have An HP D145 Printer That Won't Print Some Online Coupons Or Will Only Print Portions Of Them. Any Advice? Thank You
Most likely this is an issue with the way the website is displaying the coupon. Check to see if there is an option to print coupon. You might also try to create a PDF copy of the coupon and then printing the PDF document. Finally, one other thing you could try is to take a screen capture of the coupon, save as an image file or PDF and then print as an image or PDF. Hope this helps.
Jul 11, 2011 | HP OfficeJet d145 InkJet Printer
Will not Print online Coupos
Just fixed my Brother HL-5140. Hope this helps :) I have struggled for years and finally figured this out from the Brother website.
If you are unable to print coupons from the Internet the print processor
setting in the driver needs to be changed. To change the setting,
1. Open Printers and Faxes.
2. Right mouse click on the Brother printer and left click Properties.
3. Click on the Advanced tab.
4. Click the Print Processor button.
5. Under Print Processor, select WinPrint.
6. Under Default Datatype, make sure RAW is selected. Click OK.
7. Back on the Advanced tab remove the check next to Keep Printed
Documents.
8. Click Apply and OK.
Try printing the coupons again.
Aug 20, 2008 | Brother HL 5140 Laser Printer
The "keep printed documents" stays checked after i uncheck it!
Had the same thing happen. Go to properties, then advanced and check "print directly to printer". You'll be able to print your coupons. Make sure you go back to your previous settings when not printing coupons.
May 24, 2008 | Brother MFC 210C All-In-One InkJet Printer
PRINTING COUPONS
whats the message you get?
should print sometimes i do a copy where i select all and paste it into word or notepad.
Dec 18, 2007 | Brother MFC 420CN All-In-One InkJet...
Keep Printed Documents
If you have a Brother printer please change the following:
Start -> Control Panel -> Printers and Faxes -> Right click on your selected printer and select "properties"
Go to Advanced tab -> Print Processor
Change the settings from "BRMFC" print to "WinPrint" and set default to "raw" and Click Apply
Now go back to uncheck "Keep Printed Documents" and attempt to print the coupon.
I am a big fan of coupons.com, their tech support guy sent me these instructions. Good Luck!!
Nov 20, 2007 | Brother MFC 420CN All-In-One InkJet...
How to print smaller coupons.
I am answering this assuming your printer is attatched to a pc and not a standalone unit. You need to define what size you want your prints to be in the printer settings or properties menu window of your pc itself. Click on your printer icon and go to properties, or it should open up this window when you first go to print a job. Know your required size and specify it to the program you are in, ie i assume because you are printing a flier, you have scanned it first, so once it is scanned, open up the image in windows viewer, and tell it what size you want it to print out. Auto printing buttons on a printer are set to manufacturers default settings to a standard size.
Aug 13, 2007 | HP PSC 2175 All-In-One InkJet Printer
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
