Question about ViewSonic VA1931WA LCD Monitor
Viewsonic disassembling
How do I remove the back of my ViewSonic VX1932WM-LED monitor
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Oct 03, 2014 | ViewSonic VX1932WM LCD Monitor
How to disassemble?
pankaj29, A 1 to 2 hour visit to YOUTUBE may help!!!! Search using "lcd monitor disassembly" and "lcd monitor repair" just for starters. Lot of video clips that will help you "part" the fromt "bezel" from the rear "cover". Do not use sharp cutting instruments for prying!!!! One careless slip and it's off to the local hospital "ER" or maybe call a mortician!!! 12fixlouie
Oct 24, 2010 | ViewSonic VX2235WM Monitor
I have two Viewsonic VP2030B monitors that both died together. Possibly a resolution or scan rate problem but I need a bit of help disassembling the things. The main chassis seems to be held in place...
wa7tuv, If the plastic front "bezel" is very thin and the monitor control and setting buttons are located on the verticle sides of unit, it just may be that the "bezel" will need to be parted from the rear cover, with the glass lcd panel left in the rear panel. Then you will need to remove screws so you can get lcd panel out of the rear cover. You might just get lucky and find a video of some owner/technician doing a tear-down if you search YOUTUBE using "lcd monitor disassembly" or "lcd monitor repair" as search terms. Be very careful and protect the glass lcd screen at all times. It is the most expensive part of the unit. You CRACK the glass, It's you bought it, you own it, Toyota!!!! You could also check with Viewsonic to see if they have a cash+old unit exchange program for out of warranty,but prematurely failed units that will be swapped for same model "refurbished units????? 12fixlouie
Sep 16, 2010 | ViewSonic VP2030b 20.1" LCD Monitor
ViewSonic VP201b with a black screen
hramirez, Retevo. com says time to retire this old monitor. Its that or you will need to do some extensive reading here on fixya on how and what to look for inside the unit that could be causing your black screen condition!!! Then you will go to YOUTUBE and view some of the many video clips that deal with "lcd monitor repair" and lcd monitor disassembly". Have you noticed any bad, swollen top, elcetrolytic filter capacitors on the units "switch-mode-power-supply/CCFL inverter printed circuit board?? How about any "cold" frosty looking solder joints around the component leads of the power transistors and ferrite inverter transformers? May need to get large magnifying glass to find those pesky little cold solder joints. 12fixlouie
Jul 26, 2010 | ViewSonic VP201b 20.1" LCD Monitor
Instructions on how to disassemble and fix a Viewsonic VX2235WM
Here is a link to a repair guide that shows how to dis-assembly the unit and that what to look for any replace on the power supply board to repair most problems on the VX2235wm monitors. The repair guide has pictures and videos showing the procedures.
http://www.ccl-la.com/blog/index.php/repairing-the-viewsonic-vx2235wm-lcm-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
May 19, 2010 | ViewSonic VX2235WM Monitor
How to disassemble
There is ccfl(cold cathode fluroscent lamp) tube which is faulty therefore no light is there the ccfl tube operates on 600vac with 40khz-60khz so check 600vac to the tube if no voltage is there then check circuit and to open see any locks available there if no screw is observed take a smallest screwdriver (preset alligner)to open the lock
Mar 13, 2010 | ViewSonic VA721 17" LCD Monitor
What is the procedure for disassembling the VA712B monitor?
mercoman, Do not use any sharp cutting instruments. See disassembly VIDEOS on YOUTUBE of typical PARTING of rear cover from front bezel. Start at bottom edge looking for place to insert dull flat-blade screwdriver. Use caution. 12fixlouie
Mar 04, 2010 | ViewSonic VA712B 17" Flat Panel LCD...
Dead on arrival need to open back cover
emtv_satc852, First visit YOUTUBE and watch some of them being pried apart at their perimeters around the four edges. That's how most of them are opened. Some people use an old CD or DVD disk, while some use thin blade screwdrivers. Try "lcd monitor disassembly" or "lcd monitor repair" on YOUTUBE. Good luck. Hope this helped. 12fixlouie
Feb 25, 2010 | ViewSonic VX2433WM 23.6" Monitor
I have a ViewSonic VA703B, I need to get it working but I cannot get the back of. How can I get the back of.?
gregmclure1, Most rear covers kind of snap-apart from the front plastic bezel. need to remove pedestal first. Best thing to do ,go visit YOUTUBE view typical "LCD monitor disassembly" and or "LCD monitor repair" videos FYI. PROTECT THE LCD PANEL AT ALL TIMES!! You may even find a video of someone working on a VIEWSONIC monitor. Hope this helps. If it does, then rate this on fixya.
12fixlouie
ps What will you be working on once the back is removed? Do you know what to look for?
Dec 04, 2009 | ViewSonic VA703B LCD Monitor
NEED TO CHECK FOR BAD CAPS IN VIEWSONIC vp2130
To disassemble your monitor follow these steps.
1. Remove the stand, usually 2 to 4 screws
2. Now there will be screws in each corner on the back of the monitor.
3. Take a small flat blade screw driver and seperate the two halves of the case. The front and back are held together by plastic latches spaced several inches apart around all four sides.
4. After the back case is off the boards you will be looking for are under the metal shield, remove the screws that hold it on.
5. Check my web site at www.ccl-la.com , we have pictures of what the bad caps look like if you are not sure.
6. Be sure to replace any capacitors that have raised and blown tops.
I hope this helps, If so please rate my solution.
If you need more info let me know.
Buddy
Corporate Computer
www.ccl-la.com
Jul 03, 2009 | ViewSonic Pro VP2130b 21.3" LCD Monitor
ViewSonic VA1931WA LCD Monitor Logo
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
