Question about Wildgame Innovations HALO R400 Rangefinder
Very slow about finding yardage and sometimes have to push button several times or hold down very hard before it works
I forget my patern how can i reset it
Sometimes hard reseting it look up on youtube,sometimes its by turning off, then holding down volume down button and power button when icon appears let go of power button then push on power button again, while still holding down the volume down button
Nov 17, 2014 | Cell Phones
At times I have to push the start button several times before it turns on. What's wrong?
your start button might stick or it just wont work I suggest taking it to the place called ( i think peach mac) they fix stuff like that and getting them to look at it
Jul 10, 2014 | Apple iPhone4 4G iPhone 4
I have an android tablet I forget password to. how do I factory reset tablet
There are several brands of android tablets and all use a slightly different method for a hard reset:
1. Press power and volume down togeher and hold (Yarvik and some Samsung tablets)
2. Power and volume up together (some Samsung tablets, Sony tablets, ASUS tablets)
3. Power and volume down, than volume up.
Sometimes you need to rather rapid push another button after that. This is mostly shown on screen which button.
Select within recovery mode the option "hard reset" or "factory data reset ", this will take some time, and after it the tablet will restart automatically to the screen you saw the very first time you powered it up.
Hope this helps you,
Good luck,
Alexander Misset.
Jul 08, 2014 | Google Android
When I try to send a fax I get a redo message and no pages are sent...i have sent many faxes to this number....a message appeared after one page was scanned that said to prress clear and srop...i could not...
Please reset the Printer by following these steps:
Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
Release "Stop/Reset" while holding down the "Power" button.
Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
Push the "Power" button, then lift the MX310 cover open.
Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
Feb 27, 2011 | Canon MX310 Office All-In-One Printer
Program can not find unit
Disconnect your PC from the Internet and try again. That trick worked for me.
Dec 31, 2009 | Bushnell Yardage Pro 368100 Handheld GPS...
Rear passenger window won't go down (2003 Ion)
thats what the $75.00 per hr is for. what happens when the button is pushed? noise? clunk? fuse blows? try turning the key to the ON position, and open the door, get inside, now while holding the door open, hold the window button down, now slam the door, maybe several times, this sometimes will jar it loose. watch the dome light when you push the button down. does it dim slightly? IF there is a short it takes time to find, and that what you pay for....time.
Sep 24, 2009 | 2003 Saturn ION
Dropped from a golf cart....numbers dont come on
If you hear a rattle.....The "shock" may have broken a internal lens. (BAD) IF not, you may have just knocked it out of alignment. The rattle is the snake...and it bit you. NO rattle....It may can be re-aligned.
Good Luck!!!!!
MTG
Jun 18, 2009 | Bushnell Pinseeker 1500 Rangefinder
Can't change temperature-stays on "warm"
Push the COOK TIME button, if the time changes then if you leave the number of hours between 1 and 6, and press the ON/OFF button, it will cook on high that many hours. If you leave the number between 7 and 10, and press the ON/OFF button, it will cook on low that many hours. If you leave the number at "0" then the slow cooker will cook on WARM. If the COOK TIME button does not work, unplug the slow cooker, hold both the ON/OFF button and the COOK TIME buttons down and plug it into a wall socket. After the lights flash a few times, release the buttons. the switches should work.
May 19, 2009 | CorningWare SC60 Slow Cooker
Times Indiglo Nature Sounds Clock Radio T466W
Go to timexaudio.com, select SUPPORT, then select PRODUCT MANUALS.
Nov 19, 2008 | Timex T276B Clock Radio
Wildgame Innovations HALO R400 Rangefinder Logo
Top Wildgame Innovations Photography Experts
Tony
Are you a Wildgame Innovations Photography Expert? Answer questions, earn points and help others
