Question about Innova 3100 OBD II Code Reader
Every time I try to scan a car for codes, I get an err message on my code reader,I tried on a different car . Still get err.
Why doesn't it scan?
usually you need to configure the reader to tell it what kind of barcodes you want it to read and how to interpret & output the codes to your computer (whether you need prefix or suffixes to your codes( for automation))
the user manual for the reader has some bar codes to configure the settings for the scanner.
Jan 27, 2016 | Zebra Symbol LS4278, Bluetooth, Blood Bank...
ABS light is on but scan tool does not pick up an error code
Is it a code reader or a scan tool ,there is a difference ! An some will just read OBD codes from engine control module . You need to take it to someone who's scan tool can check all modules on the vehicle . Then again in some situations the factory scan tool will only work ! Everything You Need to Know About Scan Tools with John Anello
Sep 01, 2015 | Cars & Trucks
Code reader I cant get it to work
What you trying to read different systems require different readers. Abs one type, SRS another type and obd another. Make sure your ignition is turned to run but not start. I have several scanners and scan lots of vehicles. Get back to me if you need more help
Apr 22, 2015 | Cars & Trucks
Why does the radio works but CD player does not? WE get an err code.
the cd reader cant support newer disks or is old and just cant read like when it was brand new
Aug 17, 2014 | Cars & Trucks
Et1505an code reader comes up with link error every time i try to scan my 04 f-150 is it the scanner or my truck if it is my truck what is the cause. How would I fix it ?
The only way to find out if it is the code reader or the truck is to plug in another code reader or scan tool and see if it gives you the same results (try this first).
NOTE: Generic OBD code readers will operate ONLY on the Class 2 data link. A true scan tool will operate on BOTH the Class 2 and the UART lines. Accessing the onboard computer system with a scan tool may give you a fault code that indicates that the Class 2 circuits may be malfunctioning.
To diagnose onboard computer network communications malfunctions, the proper equipment that can communicate with the ENTIRE network must be used. Please note that generic OBD code readers cannot perform this function.
Apr 28, 2012 | 2004 Ford F150
I used a toptak TP 110 code scanner to scan my 2001 toyota solara after several tries I continually get an error code each time. To check the operation of the code reader I tried it on a different vehicle...
you are facing the protocol problem, imports uses a diferent CAN interface, if your scan tool is not capable wont read it. try going to an auto part they're scan it for free
Oct 02, 2010 | Toyota Solara Cars & Trucks
Error message on nissan xtrail car radio wont return to code in put message been 3 days since battery disconected tryed disconnect again no change
If you have the anti-theft code (it's like a business card attached were you find the code and direction) just follow the directions to enter the code but if you don’t have it, here is a link to get it
http://www.radio-code.com/?gclid=CLCh1em-jZ8CFZAN5Qod-zvRMQ
Jan 05, 2010 | Car Audio & Video
Radio code miata locked
try either 1414 or 0532. on my mx5 2003 UK its 1414
Apr 12, 2009 | 1996 Mazda MX-5 Miata
1993 MAZDA MX 6 STEREO PROBLEM
If you enter the wrong thing 3 times I think your radio is useless
  • Press SCAN and AUTO.M until bars are displayed.
  • While the bars are displayed, input the code number by pressing the channel preset buttons 1, 2, 3, and 4. Press 1 for the first digit, 2 for the second, 3 for the third, and 4 for the last. If you number is 2547, press 1 three times, 2 six times, 3 five times, and 4 eight times. If the dispay goes off while inputing, begin from step 1.
  • Press SCAN and AUTO.M approximately 2 seconds and 'code' is displayed. 'code' will flash for 5 seconds, then disappear to indicate that the system is operable. If 'Err' appears, begin from step 1.
  • !CAUTION: Three consecutive errors will activate the antitheft system, and the audio unit will be completely inoperable and 'Err' will flash. When this happens, the unit must be replaced by an Authouized Mazda Dealer at the owner's expense. Do not allow unauthorized persons to attempt to input a code number.
    Feb 11, 2009 | OEM Systems Car Audio & Video
    Innova 3100 OBD II Code Reader Logo
    61 people viewed this question
    Top Innova Measuring Tools & Sensors Experts
    ray gallant
    Vuk B
    Tom Chichester
    Are you an Innova Measuring Tool and Sensor Expert? Answer questions, earn points and help others
