Question about Tascam US-144 Sound Card
Time out 0x0005 - Tascam US-144 Sound Card
  • Josh James
    Josh James Mar 14, 2016
    Hi j ronaldo, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
How do you adjust valves on a 2006 3.5L V6 Toyota Avalon?
There is a Toyota Technical Service Bulletin issued for this:-
T-SB-0291-08 September 11, 2008 2GR-FE Valve Timing
Procedure Service Category Engine/Hybrid System Section Engine Mechanical Market USA Applicability YEAR(S) MODEL(S) ADDITIONAL INFORMATION 2005 - 2009 Avalon 2007 - 2009 Camry VDS(s): BK46K 2008 - 2009 Highlander 2006 - 2009 RAV4 Engine(s): 2GR VDS(s): BK31V, BK32V, BK33V, BK34V, ZK31V, ZK32V, ZK33V, ZK34V, ZK35V 2007 - 2009 Sienna Introduction This service bulletin provides information regarding valve timing inspection and service guidelines for vehicles equipped with 2GR-FE engines. © 2008 Toyota Motor Sales, USA Page 1 of 5 T-SB-0291-08 September 11, 2008 Page 2 of 5 2GR-FE Valve Timing Procedure Introduction (Continued) Figure 1. 3 2 1 5 9 8 7 6 4 1 RH Bank Intake Camshaft Timing Gear 2 RH Bank Exhaust Camshaft Timing Gear 3 RH Bank No. 2 Timing Chain 4 Crankshaft 5 Idler Gear 6 Timing Chain 7 LH Bank No. 2 Timing Chain 8 LH Bank Exhaust Camshaft Timing Gear 9 LH Bank Intake Camshaft Timing Gear Warranty Information OP CODE DESCRIPTION TIME OFP T1 T2 N/A Not Applicable to Warranty © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 3 of 5 2GR-FE Valve Timing Procedure Inspection 1. Set the No. 1 cylinder to TDC/compression. A. Set the timing mark to 0 on the timing chain cover by rotating the crankshaft clockwise. B. Verify the timing marks on the camshaft timing gears are in general alignment with the timing marks of the camshaft bearing cap: TIMING MARK IDENTIFICATION CYLINDER BANK INTAKE GEAR MARK EXHAUST GEAR MARK RH Bank (Bank 1) Small Mark Single Line LH Bank (Bank 2) Large Mark Double Line HINT When the engine is correctly timed, the timing marks will NOT perfectly align. Figure 2. Figure 3. RH Bank Exhaust Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark Figure 4. RH Bank Intake Camshaft Timing Gear 2 1 1 Bearing Cap Timing Mark 2 Gear Timing Mark © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 4 of 5 2GR-FE Valve Timing Procedure Inspection (Continued) Figure 5. LH Bank Intake Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark Figure 6. LH Bank Exhaust Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark HINT If the timing marks appear vastly out of alignment, turn the crankshaft one revolution (360 ) clockwise and note the position of the timing marks. Component Removal Guidelines 1. If engine disassembly is required that involves removing the camshafts or timing gears, set the #1 cylinder to TDC compression, wipe away any oil, and mark the following items in relation to each other prior to disassembly: • Timing gears • Timing chain • Timing chain No. 2 NOTE This relationship MUST be maintained. The intake gear is timed in relation to the crankshaft via the timing chain; the exhaust gear is timed in relation to the intake gear via the No. 2 timing chain. © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 5 of 5 2GR-FE Valve Timing Procedure Component Removal Guidelines (Continued) 2. If NEW camshaft timing gears or the No. 2 timing chain are being installed, the two yellow links on the No. 2 timing chain can be used to ensure correct relationship between the intake timing gear and the exhaust timing gear. Figure 7. 1 1 Yellow Link A. Align the paint mark on the timing chain with the intake gear timing mark (to ensure the intake gear is correctly timed to the crankshaft). Figure 8. RH Bank and LH Bank 3 3 4 3 3 4 5 4 5 4 1 2 1 RH Bank 2 LH Bank 3 Yellow Link 4 Gear Timing Mark 5 Timing Chain Paint Mark B. Align the two yellow links on the No. 2 timing chain to the timing marks on
May 04, 2015 | 2006 Toyota Avalon XLS
Noise in the timing chain
May be its problem with timing chain and it has to be inspected and replaced.Or its possible that timing chain is got misaligned.
There are few help,links provided related to timing chain assembly and dis-assembly. Go through it and confirm proper inspecting of timing chain.
Click the required help link below:----How to Replace Timing Chain Cover & Seal on Audi A4 ? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-timing-chain-cover-seal.html
----------1982 Toyota Pickup: Set ignition timing, engine overheating, timing chain issue, dist off? http://whatisbyme.blogspot.in/2012/05/1982-toyota-pickup-set-ignition.html
----------How to Remove Timing Chain Cover and Seal on Toyota Previa?
http://technoanswers.blogspot.com/2011/12/how-to-remove-timing-chain-cover-and.html
How to Remove Timing Chain and Gears on Toyota Previa?
http://technoanswers.blogspot.com/2011/12/how-to-remove-timing-chain-and-gears-on.html
Ford Mondeo ST220 camshaft Timing specifications? http://technoanswers.blogspot.in/2012/02/ford-mondeo-st220-camshaft-timing.html
------------Replacing Timing Chain Cover For 2009 Ford?
http://repairhelpcenter.blogspot.in/2012/03/replacing-timing-chain-cover-ford-2009.html
Timing Chains & Front Cover Removal on 2008 Ford Taurus? http://repairhelpcenter.blogspot.in/2012/03/timing-chains-front-cover-removal-on.html
----------How to Replace Timing Chain Cover, Chain, Sprockets, & Seal On Ford Taurus? http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-timing-chain-cover-chain.html
---------How to Replace Timing Chain & Sprockets on Ford Windstar? http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-timing-chain-sprockets.html
---------Timing Chain & Sprockets Replacing on Ford, Mercury and Lincoln? http://fordrepairhelp.blogspot.in/2012/03/timing-chain-sprockets-replacing-on.html
----------How to Replace Timing Chain & Sprockets on Ford Edge and Lincoln MKX? http://howtobyme.blogspot.in/2012/03/how-to-replace-timing-chain-sprockets.html
------How To Replace Timing Chain, Sprockets & Front Cover on Ford Expedition and Lincoln Navigator? http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-timing-chain-sprockets_356.html
---------Timing Chain, Sprockets, Front Cover & Seal removal for Ford Mustang? http://schematicsdiagram.blogspot.in/2012/03/timing-chain-sprockets-front-cover-seal.html
---------How to Replace Timing Chain on Buick LaCrosse? http://howtobyme.blogspot.in/2012/03/how-to-replace-timing-chain-on-buick.html
---------These details will help.For more help keep updated.Thanks.
Oct 15, 2012 | Cars & Trucks
How do i change the time on the clock?
Hi the details are below. Hope it helps I have added a link for the manual at the very bottom, Good luck with it.....
Time Adjusts the systems clock. The time difference (+, -) between the time originally set in your navigation system is set here. You can also select summer time On/Off. > Time settings, (See page 131) Summer Time Choose whether or not to take summer time into account. On: Summer time is taken into account. Off* Summer time is not taken into account...... When the period of summer time comes, or when the summer time ends, your navigation system does not automatically change the summer time setting. > Change the summer time setting, (see Page 131)
To set the time difference, touch "+" or ."-" The time difference between the time originally set in the navigation system (Pacific Standard Time) and the current location of your vehicle is shown. If necessary, adjust the time difference. Touching "+" or "-" changes the time difference display in one-hour increments. The time difference can be set from +3 to -3 hours. If necessary, set to summer time. Daylight Saving Time (DST) is off by default. Touch "Off" to change the time if you are in the daylight saving period. This turns the display below summer time "On". 9 To complete the setting, touch "Back". The map of your surroundings appears. This completes the setup of your navigation system. Chapter 1 explains the basic operation of your navigation system. > To change the time later, (see page 75)
The link to manual here:- http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/417273154AVICD3OperationManual0221.pdf
Mar 29, 2011 | Pioneer AVIC-D3 Car DVD Player
Can we install a a ptg 74pvp tankless hot water heater in a closet? Would we need to install grating in the closet wall to provide more fresh air?
Rheem Tankless Water Heater Selection and Installation Videos
  • Introduction - time 04:11
  • Pre-Qualifying the installation - time 01:13
  • Selecting the Right Product - time 01:48
  • Key Differences Between Tankless & Storage Heater- time 01:27
  • Choosing the Location - time 01:20
  • Installation: Major Components - time 00:58
  • Installation: Tools Required - time 00:48
  • Installation: Mounting the Heater - time 01:15
  • Installation: Plumbing & Gas Connections - time 04:29
  • Installation: Side Wall Vent Termination - time 02:41
  • Outdoor Installation - time 01:21
  • Connecting the Remote Control - time 01:42
  • Turning on the Water Heater - time 01:00
  • Commercial vs. Residential Products - time 01:47
  • Manifolding Multiple Units - time 01:43
  • Troubleshooting & Additional Support - time 01:01
Feb 02, 2011 | Rheem Tankless Hot Water Heater...
When installing numark dj io during installation it always says unfortunately the installation failed. (Error: Timeout - 0x0005)
check all usb connections, with any other device like pen drive, if pen drive is working perfectly , then go to " control panal" go to "add or remove programme " and uninstall any " ASIO drivers or softwares" . and restart the PC and install the device and software, drivers as told in the product manual.
if still have problem - change the RAM of your PC,
best of luck and KEEP SMILING .aaarwind
Jan 14, 2011 | Numark DJ/iO Sound Card
Alesis Multimix 8 USB won't be recognized
There are NO drivers to be installed for this device. Plug in the usb to the device, and the PC once the PC is running turn on the mixer. XP should inform you that a USB Audio Device has been found & installed. Any software you use for rec'ing will let you choose what sound device to use, select USB Audio Codec.
May 27, 2009 | Alesis Multimix 8 USB 8-Channel Mixer...
Cannot install TASCAM US 144 driver
Go to device manager and verify that the ports are powered. Windows has as a default that if no USB is detected after a prescribed time, that they be powered down. (Without notification, I might add!) I would then change the parameters to where they are manually turned off and on to help the situation...accordianman
Apr 02, 2008 | Tascam US-144 Sound Card
Open Questions:
See all Tascam US-144 Sound Card Questions
Tascam US-144 Sound Card Logo
124 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
