Medium to large pot made of heavy weight material
3 Suggested Answers
  • 136 Answers
SOURCE: Whenever I sew on medium weight material, the
Most often it is top threading, if you are sure it is correct then there is probably thread wound around a rubber wheel which meters out the proper amount of thread for each stitch. Face palte and top must be removed for access.
Posted on Aug 29, 2009
  • 8 Answers
SOURCE: tension
You would do best with a heavy weight needle. You also might want to use Upholstery thread rather than normal weight thread. Depending on the machine, you probably need to change the tension. Some high end machines do this automatically. Your best bet is to try a test run on scrap material to get the right needle, stitch, thread combination. Good luck.
Posted on Dec 29, 2009
How many pounds is 152.6 cubic inches?
Depends on the material that you will fill that space with.
The weight of the material can vary so no answer until that weight is known. You would need at least a 1 cubic inch sample weight.
Feb 08, 2015 | Cats
Which needles to use for the proper material
smaller tip higher number for fine material, medium for cottons and such and large for heavy materials
Oct 07, 2014 | Sewing Machines
Never shot this size of hand gun before, have shot a ruger 357 mag 150 grain bullet. what bullet would you recommend to shot with?
Shoot it with .38 special cartridges to practice trigger control and function drills (less recoil). Save your .357 for hunting, self protection, and familiarization fire. The weight of the bullet is not overly important, construction is. hollow points for self defense and hunting medium game. Rule of thumb? Light weight and fast for humans, heavy weight and slower for medium game.
Dec 18, 2013 | Optics
Needle
normally a 2020 but depending on the material you are sewing will determine the guage. ie: purple/red-16 use on heavy weight material, purple/yellow-16 use on heavy weight knits.
Jul 10, 2013 | Kenmore Sewing Machines
What is the most important thing to consider when choosing a stock pot?
I think the most important thing is the bottom of the pot. When you cook, you do not want the bottom of the soup to get burnt! Even if your pot is the perfect size and shape, if your soup burns, the pot is still no good. You have to make sure the bottom is made of a good material and it is thick and heavy.
Jan 16, 2013 | Home
What causes the bottom stitch to look like it's catching the material when I sew?
try changing the needle--flat side to the back of the machine
the needle & thread & fabric have to be compatable
light weight fabric requires a different needle than medium to heavy weight fabric
if you do not have a manual check with bernina customer service about one
or
sewing partsonline.com
try a top tension of 3 or 4
clean under the needle plate & in the bobbin area for loose thread or lint
Mar 30, 2012 | Bernina Artista 180
I have an 87 F150 302. I have messed up the wires on the stater solenoid. There are 6 wires attached to the solenoid. I would appreciate the wire diagram for this Thank you Rachael
There is one large cable that leads down to the bottom of the engine(starter). This goes on one of the large terminals on the solenoid. All the rest of the wires with large eyelets go on the other side which includes the cable from the battery. The small push on terminal goes on the small stud. If you have two small studs, it should go on the one closer to the front of the truck.
Sep 05, 2011 | 1987 Ford F 150
I keep breaking needles
Are you trying to sew a zig-zag stitch with a straight stitch foot so the needle is striking the foot? Or is it an issue of the material being very thick?
I just googled this machine and it looks pretty lightweight so perhaps you are expecting it to sew fairly heavy materials such as jean seams and it is struggling to do this.
Also keep in mind that you should select a needle appropriate for the sewing job, so 60 or 70 for chiffon and lightweights, 90 for medium weights, 110 for heavy weight and use ball point needles for stretch fabrics.
Hope this helps a bit.
Feb 21, 2011 | Singer 8280 Mechanical Sewing Machine
Matsui slimline dishwasher don't know what symbols mean one is a pot with a tray underneath. One is just a pot and the other is a shower with a tray type line at an angle
OK . . .
Pot with tray underneath is "heavy soil" - this will be a long wash
Pot only is "medium soil" - this will be a standard wash
Shower with tray / line is "light soil" this will be a quick wash / rinse
Please rate this solution if you find this helpful. Thanks.
Oct 16, 2010 | Dishwashers
Tension
Dec 29, 2009 | Kenmore Sewing Machines
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
