Question about Technics SA-EX500 Receiver
Ex500 manual receiver sa technics amplifier tuner
SOURCE: How to set tuner presets in Technics SA-GX550 receiver
The user manual is available free at:
http://support.panasonic.co.nz/docstore/SAGX550%20Book.pdf
Posted on Jun 26, 2008
  • 4234 Answers
SOURCE: Technics SA-AX540 Receiver
It is unlikely that the display itself is faulty although it can happen. The typical problem is either the backlight is defective or the suply to the unit has a bad connection. If you can solder, try resoldering the pins on the display itself. The pins on the ends are the power and ground. I don't recall whether or not your model has a separate back light bulb or not. That too could be burned. Chack for that too.
Keep us posted,
Dan
Posted on Mar 02, 2009
SOURCE: Technics sa 400 Receiver
Checked fuses then sprayed contact cleaner on the fuses and the fuse holders. The speakers began to work correctly.
Posted on May 29, 2009
SOURCE: technics tuner amplifier sa-eh750
I want to change the language on technics hi fi sa/eh750 to english
Posted on Jun 01, 2010
SOURCE: have a technics SA-EH750 STEREO
Mine did this too. I found that setting the time on the clock fixed the problem. to set the time turn the stereo off then back on. you cant set the clock if the stereo has turned itself back on. press the clock button then press set. you can set the time or just press set again. the clock is set. you will need to do this each time the stereo is turned off at the wall or after any power interruption no matter how brief.
Posted on Apr 28, 2013
No sound
the service manual http://www.hifiengine.com/hfe_downloads/index.php?technics/technics_sa-500_service.pdf
Jul 27, 2014 | Technics SA-EX500 Receiver
WANT TO GET OUTPUT I.C FOR STEREO AMPLIFIER TECHNICS MODEL SA-AX540
Try Ebay or Audio Lab of Ga.
If it's a single module , it wont be cheap
May 01, 2014 | Technics SA-EX500 Receiver
User manual
Technics SA-EX500.pdf - Hifi-pictures.net
copy the above ,and paste to google ,the first what google opens is a manual ,just save file to your compute. :) hope i helps
Jan 31, 2014 | Technics SA-EX500 Receiver
Where is the aerial input located on this item
Look for 2 small shiny metal screws on back, fm aerial is usually a T wire with couple forks which go under the shiny metal screws.
Nov 16, 2013 | Panasonic Technics Sa Gx100 Amplifier...
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
I need value for R 707 ( resistor on 14v power
You can order a service manual from the manufacturer.
Jun 03, 2010 | Technics SA-EX500 Receiver
Technics tuner amplifier sa-eh750 makes crunching noise and f61 comes up on desplay
Jan 30, 2010 | Technics SA-EX500 Receiver
HOW CAN I HOOK UP MY IPOD TO MY RECEIVER
Use a phono to RCA stereo jack (pic below) and hook one end to the head phone jack on your ipod and the other ends to your amplifier aux or tape input and adjust the volume to low on the ipod - select the input on the stereo - Aux or tape in.
You'll need this type of cable
Nov 13, 2009 | Technics SA-EX500 Receiver
24 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
