Question about Frigidaire FD7189 Espresso & Cappuccino Maker for 230 Volt/ 50 Hz
How to use FRIGIDAIRE FD7189 ESPRESSO & CAPPUCCINO MAKER FOR 230 VOLT/ 50 HZ
2 Suggested Answers
kdrake84
  • 262 Answers
SOURCE: Frigidaire oven 60 HZ 3 Wire 10.0 KW @ 120/240
See my tips and how to's for your answer
Please consider giving us a four thumbs up for our rating!!
kdrake84
Rank: Guru
Rating: 95%, 96 vote
Click on the link below.....
How to find appliance model numbers
When trying to troubleshoot or purchasing parts for your appliance the model number is the key to do
Posted on Mar 27, 2011
No water coming out
Espresso Makers FAQs at MrCoffee.com.
www.mrcoffee.com/.../espresso-makers/espresso-makers-faqs....
Mr. CoffeeBrowse our Espresso Makers FAQs to find answers to common questions about Mr.Coffee products. ... Why isn't espresso coming out when I try to brew a cup?
Steam Espresso & Cappuccino Maker (ECM160-NP) - Mr ...
www.mrcoffee.com/.../mr.-coffee...espresso...maker...-/ECM1...
Mr. Coffee
Rating: 2.7 - ‎32 reviews
coffee-steam-espresso-and-cappuccino-maker--ecm160-np-/ECM160-NP.html ..... Thecoffee grounds don't come out wet like the other unit. ..... too much as the steam pressure only (no pump) isn't enough to force the water through the "cake".
Repair Your Clogged Coffee Maker - Instructables
Dec 21, 2015 | Mr. Coffee Coffee Makers & Espresso...
My th 132 AF has nothing on the screen but has a 240 supply to it what could be wrong
http://waterheatertimer.org/pdf/TH132-A-F-AF-230-thermostat.pdf
Check that breaker is not tripped on one leg
Unit is rated 230 Volt 50 Hz / apparently with hot and Neutral for European power supply
US is 240 Volt 60 Hz
Uncertain if that matters
Check wiring
The product manual does not show batteries, reset, or troubleshoot
Gene
Sep 25, 2014 | Hardware & Accessories
What is the drum belt # for dryer mde675nzhs since i need to replace the broken one
Check owner's manual. No help? go online to the companies customer service or tech help.
Jun 06, 2014 | Electrolux Frigidaire MDE675NZHS Front...
Won't start
power 120 volt cannot to supply to 230 volt, maximum correction factor for voltage is 15%
Apr 04, 2014 | AO Smith 5 HP 3450rpm R56Y Frame 208-230...
What should i set the micro switch on the back at?
Power:
2 ohm stereo (per channel): 975W
4 ohm stereo (per channel): 660W
8 ohm stereo (per channel): 400W
4 ohm bridge-mono: 1950W
8 ohm bridge-mono: 1320W
Load Impedance: Safe with all types of loads. Rated for 4 and 8 ohms in Stereo mode, 4 ohms in Bridge-Mono mode
Voltage Gain to 1-kHz, 8-ohm rated output,
CE 1000:
30.5-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.34-volt sensitivity.
CE 2000:
32.1-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.83-volt sensitivity.
Required AC Mains: 50/60 Hz (North American units are 60 Hz only); 100, 120 and 230-240 VAC (+/-10%) units are available.
AC Line Current,
100 Volts: 11.4 A;
120 Volts: 9.5 A;
230-240 Volts: 5.0 A;
At Idle: All amps draw no more than 90 watts.
AC Line Connector: NEMA 5-15P (15 A).
Sep 07, 2012 | Crown CE2000 2-Channel Amplifier
We lost instuctions on our krups coffee/cappuccino maker dont know how to use
XP4050 Krupps
pumps water through machine into drip tray not through coffee anymore
Apr 26, 2009 | Krups Cappuccino/Espresso Maker -...
Hi ! I have a Delonghi espresso machin calld
Try this location in Wa.
Action Small Appliance
1500 145 Place SE
Bellevue, WA 98007
Phone: 425-643-9806
Whenever I need parts for deLonghi this is where I call.
Mar 08, 2009 | DeLonghi Coffee Makers & Espresso Machines
Frigidaire FD7189 Espresso & Cappuccino Maker for 230 Volt/ 50 Hz Logo
164 people viewed this question
Top Frigidaire Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Frigidaire Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
