Question about Consew 817 Mechanical Sewing Machine
Needles for 817
The needles have to be shorter than what I can get. Please advise where you can find them.
Replacing needles on pfaff 788 serger
No worries. One needle is always lower than the other. Just make sure when installing that the needle is pushed as far as possible before the screw is tightened.
Feb 13, 2018 | PfaFF Sewing Machines
What's wrong when the top thread knots up under and around bobbin and sounds like needle is hitting something. I have changed everything.
Replace the bobbin with a bobbin that is shorter than the bobbin case. Yours is too tall. Now, replace the needle with a good, new needle.
Aug 13, 2015 | Sewing Machines
My needle won't pick up bobbin thread
timing is off. i am assuming that the new needle is either longer or shorter than the one it replaced. search youtube for a video on how to check and how to set.
Mar 14, 2015 | Sewing Machines
Can Bernina walking foot with soles and seam guided used on Activa 210 be used on 16 yr old Bernina Activa 230????
Please be advised that the newer machines (Classic models) such as the 130-180 and up, have a totally different geometry. This is to say that the older machines have a shorter distance from the center of the presser bar to the needle center. The newer machine design was increased to provide space for needle threaders etc. Older machines will use an older Walking foot model (still available).
Feb 27, 2014 | Bernina Activa 130
I have a brother vx-1125 the cotton keeps snapping..but the tension is correct..please advise..
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Aug 17, 2012 | Janome Sewing Machines
Needle seemsnot to travel far enough
First make sure that you are using the correct needles for the machine. I have seen machines with serger needles installed (these are sometimes shorter) If you confirm that the needle is correct then the problem may be more serious.
May 14, 2011 | Singer 1120 Mechanical Sewing Machine
Were my bobbins goes it has a bobbin case but the case makes the machine stop and breaks the neddle what can i do
you are useing the wrong needles for the machine or the needle bar that holds the needle has slipped down from its retainer. and it will need the timing done. with the bobbin case out you will be able to see how much shorter the needle will need to be or how much the needle bar will need to move up. the hook that picks up the thread should line up above the eye in the needle on the up stroke
Jun 25, 2010 | Kenmore 15516 Mechanical Sewing Machine
Cannot get the bobbin thread to come up with the top thread
1. Make sure the needle is up in the machine all the way.
2. Make sure the flat side of the needle is facing the rear of the machine
3. Only turn the handwheel on the side of the machine towards you, never away from you.
4.Double check your threading of the top of the machine.
5. Also make sure your using the proper needle, your machine takes the most common needle on the market but some look like it and are shorter or longer and wont work properly. Also make sure your not buying needles for a singer serger.
Oct 07, 2009 | Euro-Pro 473
Consew 817 Mechanical Sewing Machine Logo
21 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Oloyede Monsuru
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
