Question about Sony Cyber-Shot DSC-S40 Digital Camera
Batteries discharge rapidly and even spontaneously
Got two different sets of rechargeable batteries. Both sets show the same problem - they get discharged very rapidly. When the camera is used, then the batteries get discharged after some 30 shots (!), when not used, then the spontaneous discharge takes about 2 weeks (!). Since the batteries set are each of different type and from a different manufacturer, I believe the prob must be in the camera.
  • ondratej Oct 18, 2007
    Oh that looks great, can't you tell me how to actually get the setting re-set? Thanks
I wrote the above information (which is not a solution) but have since talked with a Sony tech by phone. He had me reset the settings on the camera. I followed his directions. Guess what? My battery consumtion issue seems to be resolved. I will certainly keep track of battery related data for now until I am sure I am out of the woods. If the problem returns, its back to the drawing board. By the way, my camera turning off after 3-4 minutes is a normal function.  Good luck!
Posted on Oct 17, 2007
I have the same problem. I believe the camera is defective since the rapid discharge has ocurred since I bought the camera in June of this year. My sister has the same camera which she bought at least 2 years ago. Her batteries last at least triple the amount of time as mine do and she takes far more pictures that I do. As an experiment, I used her batteries in my camera and they discharged after 30 shots at the most. When the same batteries were recharged and loaded into her camera, the batteries lasted for more than 120 shots. I'm really frustrated. I bought this camera per my sister's recommendation and it cost more than $350. The store has offered to send it back to Sony for a fee but I'm afraid Sony will say I am at fault and not replace or refund.
Posted on Oct 16, 2007
SOURCE:
Sylvania mp3 driver
The battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Rechargeable batteries will fail if stored in a discharged state for long periods.
May 03, 2013 | Audio Players & Recorders
Ryobi batteries P103 (2) or P104
The physical differences between two models of Ryobi batteries is:
- The P103 (Part Number 130429008) is a 1.5 Amp/Hour (a measure of how long a battery lasts on a charge) battery. If totally discharged it takes about 15-20 minutes to charge back to full. It is lighter than the P104 because it has half the cells inside. Lighter, quicker to recharge, quicker to discharge, shorter lifespan.
- The P104 (Part Number 130429017) is a 3.0 Amp/Hour battery. It takes about 30-35 minutes to charge it to full if fully discharged. Slightly heavier, longer time to discharge & recharge, longer lifespan.
Considerations:
- No difference between batteries in the performance of your tools.
- The number of times you discharge and recharge a battery determines a batteries lifespan. That's why most manuals will tell you to fully discharge a battery before putting it on a charger.
- If you only have one battery you cannot use your tools while it is recharging. On big projects you have to have two batteries.
- The weight difference between batteries is negligable unless you are working with the tool in your hand for extended periods.
Mar 04, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
My Fujifilm FinePix AV100 12MP Digital Camera battery easily gets discharge or Low Battery even the battery is fully charged and new, what do you think the problem might be???
Welcome to FixYa.
First thing we need to verify is what type of battery are you using.
The Capacity of rechargeable Ni-MH batteries may be temporarily reduced when new, after long periods of disuse, or if they are repeatedly recharged before being fully discharged. Capacity can be increased by repeatedly discharging the batteries using the DISCHARGE option and recharging them in a battery charger. Do not use this option with non-rechargeable batteries.
Also possible reason why your battery easily discharge if:
* battery are cold
-warm the battery by placing them in your pocket or other warm place.
* ther is a dirt on the battery terminals
-clean the terminals with soft and dry cloth
* the camera is always on AUTO mode
- choose different shooting mode
I hope this information will help on your issues.
Feel free to send us your comments or suggestion if this solution is helpful.
Thank you for using FixYa.
Apr 08, 2011 | Cameras
Shows low battery, even after installing new batteries. will not work.
The best batteries are rechargeable NiMh batteries of the ENELOOP (Sanyo) type.
These batteries have a very, very low discharge. Some other brands have such types too.
Oct 21, 2010 | Konica Minolta DiMAGE S414 Digital Camera
NO PICTURES
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00614986&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=437165Solution two: Use the right battery What AA battery should I use for best performance? The following table summarizes how AA batteries perform in different types of use. Type of Use Alkaline NiCd Ni-MH Oxyride Photo Lithium Most economical when taking more than 30 pictures per month Poor Good Good Poor Fair Most economical when taking less than 30 pictures per month Fair Fair Fair Fair Good Heavy use of flash, frequent pictures Poor Good Good Fair Good Heavy use of video Poor Good Good Fair Good Heavy use of Live View Poor Good Good Fair Good Overall battery life Poor Fair Fair Fair Good Low temperature/winter use Poor Good Fair Poor Good Infrequent use (without dock) Fair Fair Fair Fair Good Infrequent use (with dock) Fair Good Good Fair Good Recharge batteries No Yes Yes No No Solution three: Make sure that your batteries are completely charged Follow the steps below for your battery type: Ni-MH rechargeable batteries Ni-MH batteries lose charge, or self-discharge, at a rate of one to two percent per day, whether they are installed in the camera or not. This means that if a battery is fully charged, after several weeks, the battery will be low or dead even if it was not installed in the camera or if it was installed in the camera but no pictures were taken. Ni-MH batteries are best for those who use the camera frequently and recharge often. The amount of charge that Ni-MH batteries can hold gradually decreases because of usage, aging, and lack of maintenance. To maintain your batteries at maximum capacity, "condition" them when they are new or have not been used for over a month. Follow these steps to maintain (condition) your batteries:
  1. Completely discharge the batteries by using the camera normally until it will not operate.
  2. Recharge the batteries.
  3. Do this three or four times.
NiCd rechargeable batteries Nickel-cadmium (NiCd) batteries lose charge or self-discharge at a rate of one percent per day. Store NiCd batteries in a cold place such as the refrigerator or freezer to minimize the loss. To store in a cold place, place the batteries in a tightly sealed container to keep the moisture out. Before using them, warm the batteries to room temperature. The amount of charge that Ni-Cd batteries can hold gradually decreases because of usage, aging, and lack of maintenance. To maintain your batteries at maximum capacity, "condition" them when they are new or have not been used for over a month. Follow these steps to maintain (condition) your batteries:
Alkaline, Photo Lithium, and Oxyride non-rechargeable batteries Make sure that the batteries are new and have not been used for anything else. . Solution seven: Try a new set of batteries If you have tried all the solutions described above but your batteries still do not last very long, try a new set of batteries. If the old batteries are damaged, a fresh set of batteries will solve the problem. Batteries can be damaged in the following ways:
  • NiCd and Ni-MH batteries can be damaged by over-charging. After a battery has been recharged, do not try to add additional charge to the battery by sending it through another recharge cycle before using it.
  • Batteries can be damaged by dropping or sudden impacts. Even if there is no apparent external damage, the rechargeable battery could later develop an internal short or leak while in the camera and cause damage.
  • If batteries have become wet, they may short out and will not work properly.
Jul 17, 2010 | HP Photosmart M417 Digital Camera
I use rechargeable batteries in my FE-35 and they are constantly showing up as empty. They show as full for about 30 secs and then they are shown as completely empty. It's very frustrating. Has anyone else...
This may not be so much an issue with the camera as much as a problem with the batteries. Since these are type "AA" battery packages, you should attempt to use them in another device - such as a small flashlight or other device that can operate on AA batteries.
If the batteries fail to to power the flashlight (or other test device) for more than 5 - 10 minutes after charging overnight (or as long as directed by the battery charger), the problem is with the batteries. It is very important that the batteries are charged properly. Properly means for for the required amount of time AND in the correct charger. There are different types of battery types: NiMh, NiCad, NiZN, Li-ion, etc. Using the wrong charger to charge the batteries could cause unpredictable results - or create a potentially dangerous condition. Additionally, some battery types develop a "memory" and can be responsible incomplete charging and rapid discharge. This happens if the initial charge is insufficient and the batteries are not completely discharged prior to recharging. It may be possible to recondition these batteries - but this size battery is relatively inexpensive, so replacement might be a better option.
If the batteries are working okay in the test device, then the problem may lie in the camera itself. Test the camera by installing fresh, AA alkaline batteries. If the camera rapidly discharges the alkaline batteries, it's a safe bet that the camera has a problem.
Please rate this reply if you found it helpful - good luck!
Jul 07, 2010 | Olympus FE-35 Digital Camera
My pro 96 keeps saying low battery even with a power source.????????
You probably just need a new set of batteries..batteries die like flies for no good reason, OR it needs a full discharge/recharge cycle, if rechargeable.
Mar 05, 2010 | Radio Shack Pro-96 Scanner
Sorry but does the dw911 xe type 1 radio charge the battery
Yes, the DeWalt radio will recharge the batteries, from the 12 Volt to 18 Volt versions. However, even with the radio plugged into an AC outlet, you have to either have the radio turned on, or have the unit in the AUX setting, in order for the batteries to get charged.
It typicaly takes about an hour +/- to fully charge a discharged battery. I normally don't put batteries directly into a charger right after they become discharged from being used in a tool, since they are still warm from use and charging them will generate more heat in the recharging
process.
Heat is the enemy of rechargeable batteries, so to get the longest working life out of your batteries, I'd let them cool down first, before recharging them, unless you absolutely need to use them right away, then go ahead and recharge them. If you can delay recharging them until they've cooled down, you'll get a more fuller recharge out of them.
Hope you find this Very Helpful and best regards!
Sep 30, 2009 | Dewalt Drills
S9500 : rapid battery discharge
Check your focus control on the left side of the camera is not set to "continual focus" CF, as this will constantly adjust focus and run your battery down quickly.
Also NiCd batteries are not very useful -use Nickel Metal Hydride (NiMh) which last longer and don't suffer from memory effects. These batteries don't reach full capacity until after a number of recharge/drain cycles.
Mar 10, 2008 | Fuji FinePix S9500 Zoom Digital Camera
What is the difference between the available AA battery chemistries?
AA batteries are available in four basic varieties: Alkaline Nickel-Metal Hydride (NiMH) Nickel-Cadmium (NiCad) Photo Lithium (Li-FeS2) Alkaline and photo lithium are non-rechargeable, while NiMH and NiCad are rechargeable. Each has advantages and disadvantages. Non-Rechargeable vs. Rechargeable: Rechargeable batteries are desirable from an environmental standpoint because they are reusable. Self-discharge refers to the fact that batteries lose energy when unused and even when not in a camera or other device. Rechargeable batteries tend to have relatively high self-discharge rates, approximately 1-2% per day for nickel-based batteries. Non-rechargeable batteries generally have very long shelf lives and extremely slow self-discharge rates. This makes non-rechargeable batteries a better choice for infrequent usage. Non-rechargeable batteries are available fully charged in stores all over the world, which makes them a convenient choice for travelers or customers who have dead rechargeable batteries and no time to recharge. Photo Lithium Batteries (Li-FeS2) (non-rechargeable): Photo lithium batteries will yield the longest battery life of any AA battery, surpassing NiMH by 50-100% and surpassing alkaline by 100-500%, depending on the load. While they are more expensive than alkaline batteries, their additional energy capacity makes the cost the same or less per shot than alkaline batteries. Nickel-Metal Hydride Batteries (NiMH) (rechargeable): NiMH batteries are the lowest cost overall solution for users that take a lot of pictures (more than the equivalent of a roll of film per month) or use a lot of high-power features. The largest disadvantage to NiMH batteries is their fast self-discharge rate of 1-2% per day whether the batteries are in a camera or not. NOTE: NiMH batteries need to be completely charged and discharged a few times when new to achieve their full capacity. Rechargeable batteries will eventually fail. If you have been getting acceptable battery life and then see a decrease in life, either quickly or slowly over time, a worn-out battery may be the cause. Storing or charging the batteries in high temperature conditions will accelerate this potential failure. Alkaline Batteries (non-rechargeable): Although the cheapest and easiest to find, alkaline batteries yield the worst performance of all the chemistries in a digital camera. They lose capacity at high power drains and at low temperatures. Skiers and other winter outdoor enthusiasts may find them unsatisfactory. Alkaline batteries are frequently available in two types: High drain (ultra, titanium, maximum etc.) Regular The high drain versions are a premium product designed to operate better under heavy loads than the standard product. However, there is a trend of major brands to increase the performance of their standard battery to b
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
83 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
