Canon ir 2520 error code
Load paper error message but tray full
Remove the peper the output tray
Posted on Apr 10, 2014
SOURCE: Canon MP600 paper wont feed- error message- HELP!
Right ... After 5 minutes of looking and fiddling I have found the solution!! press the button abover HOME and it should change the tray in which you are printing from :D
Problem solved
Posted on Feb 08, 2009
SOURCE: Printer will not print
I had the same problem and to fix it there was a blue tray I had to pull out (the tray for the photopaper). Once it was pulled out so it was about flush with grey part beside it, the printer worked again. (The photopaper tray is just above where you put the regular paper.)
Posted on Mar 26, 2009
SOURCE: Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Posted on May 13, 2009
canontech
  • 1219 Answers
SOURCE: Solution for canon ir 2520 error code E000020
E020 0000
The path between the sub hopper and the developing
assembly is clogged with toner.
1.Check the rotation of hopper motor gear. (If rotating, false
detection by the sensor is doubted. Feed the toner to the
developing unit in service mode: CLEAR>ENGIN>TNRINST.)
2.Replace the Developing Assembly Toner Sensor (TS1).
3.Replace the Sub Hopper Toner Sensor (TS2).
4.Replace the DC Controller PCB (PCB4).
SERVICE MODE:
* 28 * or MENU and #
Posted on Jul 01, 2010
SOURCE: prints 2 pages and says to load paper
Somehow after adding paper you changed the paper size to B5. Change it back to Letter and it should resolve your problems
Posted on Jan 12, 2011
Canon image runner ir 2520 says load paper but the paper is already on the paper tray please help
To fix the error:
- You select setting
- Device Settings
- Plain Paper Feed Settings
- Set up on Rear Tray instead of cassette
Oct 30, 2016 | Canon Office Equipment & Supplies
What dose code 0002 means in canon ir 2520
that error means there is over temperature detection . you need to clear that error from service mode
May 04, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
How can i fix the error code e000002 shown on my canon ir 2520 photocopier
Unplug the printer let it sit for one minute than power it back up. If the error doesn't clear repost.
Mar 05, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
Hull, my canon IR 2520 cant print when i send the job it only beeps with a red light, can some one help me...
press the status monitor on touch screen. it will show that load paper LTR. that was an error.
go to additional function-> printer settings-> paper size over ride-> make it ON.
Sep 22, 2015 | Canon Office Equipment & Supplies
Conon ir 2520 erore code e000750
E000 errors are usually a bad fuser (also called fixing assembly by canon) You should buy FM4-3367-000 (for US/ Canada / Mexico 110V version.
Sep 11, 2014 | Canon imageRUNNER 2520 Laser Multifunction...
CANON ERROR LOAD PAPER IN TRAY
There is no paper in the tray. You need to place the papers in the printer.
Aug 09, 2014 | Canon Ir 3300 Black & White Copier
Solution to errorE000003 0f ir 2520
Press the additionel function button & press 2&8 buttons at once and again press additionel function .select COPIER and FUNCTION and CLEAR and ERROR andpress OK button.
Feb 26, 2013 | Office Equipment & Supplies
Where can i get the codes canon ir 2016 series.
Hi, here you go:
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540
0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542
0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744
0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
Jul 16, 2010 | Canon Office Equipment & Supplies
442 people viewed this question
jasbo
jasbo
