Question about Xerox WorkCentre PRO 128 Copier
Philips SpeechMike LFH-5272 win 7
Need drivers
Where do I download a driver for Philips Speechmike Classic 6264 that can be used with Windows 7?
Unfortunately I cannot find any references to driver installation for versions of Windows beyond Windows XP. The possibly means the hardware is not natively compatible with Windows 7. You can try installing the Windows XP driver using either compatability mode or if push comes to shove you can use the XPMode virtual machine to run the device in a true Windows XP environment with Windows 7 Virtual PC. I would contact Philips customer support for more information.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Feb 26, 2015 | Philips SpeechMike Classic 6264 Handheld...
How do I restore a deleted recording?
It's a digital recorder, right? And I think the lost audios were initially stored in the memory card. In this case, you may need a data recovery program on your computer. Feel free to give this one a try if you're a Mac user. Recover Digital Photo Music and Video on Mac OS
Oct 30, 2014 | Philips LFH9600 Digital Pocket Memo with...
The philips LFH9600 dictations are going back to the beginning
There is a minus and plus button under the menu button. If she rests her thumb on the minus button it will skip backwards. This will also cause lost dictation because it will skip back without knowing about it and you can dictate over what is there.
Jul 10, 2013 | Philips LFH9600 Digital Pocket Memo with...
Philips device won't recognize when docked.
Remove cable from the docking station and plug it directly in to the LFH9600
dictaphone if the system communicated it is possible that the docking station is bad.
Jul 17, 2012 | Philips LFH9600 Digital Pocket Memo with...
Tengo una grabadora digital RR-US395 Voice Editing ver 1.0 pero el CD no me funciona con win 7. que puedo hacer
Hola que tal, desafortunadamente hasta donde yo sé Panasonic no ha actualizado Drivers para Windows 7 desafortunada mente así pasa a veces, en realidad té recomiendo que si vas a invertir en otro equipo consideres tus opciones ya que la verdad es mejor una grabadora de voz profesional y de una Marca líder en el ramo de las grabaciones como Olympus Philips o Dictaphone normalmente cada que sale un sistema operativo nuevo se actualizan muy pronto con el asunto de los drivers yo te recomiendo esta grabadora por su precio creo que vale la pena cada dólar http://www.tvps.com/Products/Philips-9380-Pocket-Memo-Digital-Recorder---New-LFH-9380__PH-LFH-9380.aspx
Apr 16, 2011 | Panasonic RR-US395 Digital Voice Recorder
LFH 720 - Does it record?
This machine is a playback-only model. You will need a hand-held recorder using Philips mini-cassettes.
Oct 13, 2009 | Philips LFH-720
Can I use Speechmike Pro 6274 with Macspeech/Dictate
Sorry, the Philips line for Mac support is: "the market is not big enough". Appauling isn't it?
Mar 18, 2009 | Philips SpeechMike Pro 6274 Handheld...
Philips SpeechMike Executive V3.2 wont run in Vista
I had trouble initially with the same error message as deedee 222 8 and cannot give exact instructions. Try intalling old version, uninstall and then install upgrade 390 from Philips web site. I had to restart 3 times to get rid of an error messge on boot up but then it worked!
Jun 01, 2008 | Computers & Internet
Xerox WorkCentre PRO 128 Copier Logo
49 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
