Question about Lenovo Computers & Internet
Computer will not power up the power light just keeps flashing
It is a thinkcentre MT-M 8808-9HU. tried to unplug over night tried again same result
    Habit-Forming:
    New Friend:
  • 160 Answers
Probably power supply, but you can try a different display monitor, try unplugging the hard drive. You need to see your PC go to the BIOS boot screen to do further testing.
Posted on Nov 19, 2013
3 Suggested Answers
if0else0
  • 166 Answers
SOURCE: what kind of soud driver can I instal in IBM ThinkCentre MT-M PC Desktop 9211 LUM model?
From Lenovo's support website here
Select appropriate driver or just select the "Update your drivers and software automatically" link on top
Good luck
Posted on Feb 20, 2012
jadiazq
  • 2878 Answers
SOURCE: couldn't find audio driver for IBM thinkcentre MT-M 8327-77G for windows 7
That because this system came XP. You will need to run drivers on compatibility mode if possible.
Posted on Oct 10, 2012
Red light flashes 5times continuously doesn't power on started last night
try unplugging it from the power outlet, hold and press its power on switch for 10 seconds, and test it again. you may also want to try another power outlet.
Aug 08, 2013 | Sony KLV-32BX300 SERIES BRAVIA LCD...
My television just doesn't turn on. It was working fine last night then it stopped working. The outlet works and the red light doesn't come on.
Tries tv unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting.Now,the tv should be working again,if the tv still getting same result no power LED light indication at all or just flashing power LED light indication.Mean ur tv the power supply board is the causes and the problems.The power supply board,that board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 01, 2011 | Memorex MLT3221 32 in. LCD TV
I tried to turn on mt TV and it wont. The power light just keeps on flashing
Your power source has failed, it is located in the television, replace the part and you can be watching tv again.
Jul 19, 2010 | Sharp LC-32SB21U 32 in. LCD TV
IBM ThinkCentre S51 Intel Pentium 4 PC Desktop won't boot up. The power light comes on for about a second and then goes off, over and over again. It does not stop unless I unplug it. The mouse's infrared...
Sounds like it's probably the power supply. The computer takes more power to boot up than to run, so if it can't get enough wattage it can't boot all the way up, and it will shut down and try again.
If you're comfortable opening your computer up, you can test the power supply connectors with a voltmeter or multimeter to verify. A new power supply is typically only $30 or $40.
May 29, 2010 | IBM ThinkCentre A51 PC Desktop
Lightning Last Night Nocked The Receiver Out.
leave unpluged overnight. usually capacitors hold charge and will release slowly. try that if doesnt work powersupply is bad.
Jun 03, 2009 | Yamaha RX-V861 Receiver
No beep tones on startup, power to all devices, no bootup
Just a shot in the dark...unplug power, remove battery..at least an hour . Press power button at least once in the hour.
Good Luck
Apr 04, 2017 | Gigabyte GA-N650SLI-DS4 nVIDIA nFORCE 650I...
Flashing lights
I've also been having problems with my Whirlpool. Try to turn off the power (unplug, flip breaker whatever) let the machine "re-boot". Then start the cycle again.
Good Luck!
Oct 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Strange behavior
Initially, pls try disabling the hibernation feature of your computer.
Other than that, would appreciate if you can post back the make and model of your computer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Computers & Internet
Light Bulb Icon Flashing
Unplug it from power.Pull the side cover to check for burnt smell or burnt spots on your board modem or power supply. Unplug the power suppy from the board, unplug the hard drive . Then plug it all up again , put the cover back on it .Plug power cords back up and try it again.If you get no where after this the surge knocked out your power supply or hard drive or board. Always use a good surge protector on all computers and printer and copiers.
Aug 06, 2007 | Compaq Presario S6300NX PC Desktop
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Computers & Internet Logo
121 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
