Question about Stihl Br500 Br550 Br600 Back Pack Blower Fuel Cap
Br550 shuts off after about 20 min. run time, Won't re-start.
Fuel tank vent
bad inline fuel filter
leefs inside the tank flush it out
bad plug replace it
bad air filter replace it
bad pickup ignition coil
oil level too high or low take it all out and measure what you put back by the user manual from the stihl site {use google to find it}
Posted on Dec 04, 2014
Top drawer stops, will restart if I push start
Sounds like a micro switch problem to me, telling the dishwasher that the drawer is open when it is not actually open.
Dec 26, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Cub Cadet LT1050 Runs fine..20 min...dies...wait 20 min....runs fine 20 min.
Check the breather in the fuel cap, run it with the cap loose and see if it is any better.
May 30, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Mower run for awhile then shuts off
If you have a Briggs & Stratton this problem is there is not enough valve clearance . IT is a major problem with B&S motors as the valve stems stretch with use and the clearance is lost and when hot the valves are held open. Remove the valves and grind the end to obtain correct clearance.
Apr 26, 2013 | Garden
1987 Ford f150 shuts off and wont start until engine is cooled off
To clarify, you said it runs for 20 min then quits, and it won't start again until it cools off. Have you checked for spark at the plugs and fuel pressure right after it quits running ?
These models have an ignition module attached to the side of the distributor that has a history of failing when hot. The coil and the pickup inside the distributor can fail too. Could also be a relay.
Oct 12, 2012 | 1987 Ford F 150
Need to know why a 97 mercury cougar won't start until cooling fan and fuel pump stop running
I would think it's a problem with (CCRM) constant control relay module . This module has relay's inside that control the fuel pump , cooling fans , A/C compressor clutch , PCM - engine computer power relay . And thier are electronics involved , solid state circuity . Google CCRM
found this helpful answer from mercury mechanic on JustAnswer com
May 07, 2017 | 1997 Mercury Cougar XR7
Will crank sensor cause the car to kill when it gets normal operating temp and then 20 or 30 min later start up again
Check the ignition module and coils alot of times the module went its going out will do that.When it gets warm the car will shut off and sometimes it will start back up and sometimes it won't.
Apr 22, 2012 | 1996 Chrysler Cirrus
Dryer runs for about 20 min. then shuts off will start after it cools down and run again for another 20 min.
The only thing that can be is a bad motor. Both the run and start windings are going at the same time. Start windings are not dropping out.
Sep 19, 2011 | Kenmore 66832 Dryer
Air massage runs 20 min. then shuts down. when I restart it right away it only runs a short time.
air systems have a built in timer on them. 20 mins.
they are supposed to be shut off for 20 mins to cool the blower down then can be turned on again.
Feb 13, 2011 | Maax Home
Stihl Br500 Br550 Br600 Back Pack Blower Fuel Cap Logo
188 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
