Question about Flat Panel Televisions
Lg plasma tv
42inch.2 years old ,got sound but no picture
  • 106 Answers
SOURCE: LG 50PX4DR plasma tv
Open the back cover and check the fuse on YSUS Board. If the fuse was gone, replace the YSUS board or ZSUS board.
Posted on Jan 14, 2008
  • 106 Answers
Open the back cover and check the fuses on Y Sus Board and X Sus Board. If you can find a blown fuse, just replace that board and your problem will be fixed.
Posted on Feb 23, 2008
SOURCE: LG plasma tv
Most likely it's the PDP panel wires failure. It won't cost you more to repair then to buy a new one.
Posted on Apr 28, 2008
  • 5 Answers
SOURCE: LG 50" plasma tv
call 877-543-8325 this is an LG Executive call center and they will fix this for free. I have a 50" plasma I bought january 2006 which is out of warranty by 5 months. They faxed me and the LG repair shop a 30 day warranty for my tv to cover the repair. Just tell them you heard a pop and in my case the picture is distorted. All they need is the model number and serial number and they should take care of it. No arguing needed.
Posted on Jun 03, 2008
  • 34 Answers
SOURCE: lg 42inch plasma
Sounds like main board failure and or power board failure. You need to contact manufacturer and describe problem for tech support. Some of the parts in Samsung TVs have lifetime warranties. Change out of two board is about an hour job and service call is usually comped. Hope this helps. J
Posted on Apr 09, 2009
  • 45 Answers
SOURCE: i have an lg 42inch plasma and now a vertical blac...
I had the same problem with a five year old 50" LG Plasma. I fixed the problem with a 11 dollar soldering iron from Radio Shack and about 2 hours of my night. You have to open the back of the tv and locate where the ribbon strips are attached to the screen. I beleive that on your 42" they will be on the bottom of the tv. Mine had 11 on top and 11 on bottom. Yours will probably have around 7 or 8 along the bottom. Mine was a little easier since I did not have to remove the control board. You unfortunately probably will have to remove it. It is not hard at all, just takes more time. Make sure to keep your screws seperated and remember where everything goes. On bigger jobs some tape and a marker are very useful. Put tape on the board and around the wires removed and leave a tail. This way tou will remember to hook them all back up. Once you find the ribbon strips you have to remove them one by one and look at what is behind the metal place. There will be 4 capacitors and 4 resistors. The tv manufacturers want you to buy new tv's every 5 to 10 years so they use a very cheap solder on their contacts. Use you soldering iron and re-heat the solder to liquify it again and thats it. Allow time to cool on each of the caps and resistors. It took me about 1 to 2 seconds on each side of these parts. I did use a dual wattage soldering iron from radio shack. Its is a 25 and 35 watt iron. I used the higher setting. I have pictures if you would like me to email them to you and show you what I did. Be careful removing the ribbon strips, I broke one of the clips that hold in the ribbon strip. That is costing me an extra 25 dollars off ebay but still for a free tv, its not bad.
Posted on Jun 05, 2010
0 characters
1 Points
My 42 samsung plasma tv lost picture
hello i have a 42inch plazma pdp42v6 check all caps ok
all board ok sound ok but no picture can anyone help me
fix this problem please
Dec 21, 2012 | LG RU-42PX10 42 in. HD-Ready Plasma...
42" LG plasma tv, 4
Probably filter capacitor in power supply if it
exploded should be easy to find may have caused other problems however
could be worth checking
Feb 25, 2011 | LG 42LC2D 42 in. LCD HDTV
LG plasma TV turned off, after the picture very light
I think you have a defective power board. the pop sound in coming from the board and giving you a low output voltage. do it yourself price about two hundred for parts.
Feb 18, 2010 | LG 42PC5D Television
LG 42inch plasma tv suddenly lost picture, now only works intermitently. Sound is ok.
i have got the same problem with my LG 42PC1D might work for a few days or a few hours no solution as yet
Oct 25, 2009 | LG 42PC3D 42 in. Plasma Television
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Getting a HD Picture on MY LG Plasma
Have you made sure the box is set to send a HDTV signal to your LG? Example 720p, 1080i, or 1080p? You usually have to set the resolution in the v+.
Feb 29, 2008 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Dec 31, 2007 | LG RU-42PX10 42 in. HD-Ready Plasma...
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
My plasma tv picture is green
take off back panel and adjust the V12(A) adjuster wheel on the power board it adjust the gas flow to the screen is should light up your screen
Sep 30, 2007 | LG MZ-42PZ14 42 in. Plasma Television
Plasma 42inch TV
I'm guessing this is a problem on the Y-SUS PCB or the Control PCB. Call LG and they will find you a servicer. Most LG Plasmas have 2 year warranties and they are covered in your home. It kinda sucks but it is better now than after your warranty expires this repair would cost several hundred dollars.
Dec 23, 2006 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Flat Panel Televisions Logo
236 people viewed this question
Top Flat Panel Televisions Experts
Jaime Hernandez
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
