F24 error code is key stuck error as the service manual of your product says (THERMADOR C302 SERVICE MANUAL Pdf Download ' ManualsLib) By replacing the faulty key or whole key board will revive the machine. As the model is discontinued/obsolete, a good service person can find alternatives to make it in working order.
ManualsLibhttps://www.manualslib.com > ... > Oven We have 6 Jenn-Air WW30430P manuals available for free PDF download: Service Manual, User Manual, Use And Care Manual. Jenn-Air WW30430P Service Manual (51 ...
The list of codes is on page 105. Code E34 is simply listed as contact customer service. Which is not really all that helpful in diagnosing the problem. Have you tried to reset the oven? Disconnect the power cord for 2-3 minutes and trying again? If this doesn't work, given the general code, you should call the customer service number in the manual.
Hope this helps.
In order to help you turn on the oven you will need the oven manual. But as you have not provided the model number it is hard to advise which manual applies. You may want to visit this website and type the model number after you check it from the plate on the oven door. (side). AEG Service Support User Manuals
You will not be able to access a service manual on line.
You will have to go to Whirlpool web site and request one.
There will normally be charge for this
when you took down the control panel and gained acess to the upper cavity , there wasnt a service manual just to the left inside a red plastic bag???, if not there is another fuse loacted just behind the micro front looks to be atop the capacitor area
