Question about ACCO Brands Rexel 3150 Shredder
Red light stays on my shredder - ACCO Brands Rexel 3150 Shredder
Overload light stays on
Most likely the cutters are still stuffed with paper shreds and needs to be dismantled and cleaned
Mar 29, 2014 | Honeywell Seven Sheet Micro Cut Paper...
Shredder wont shred
My boss has a shredder that will not run unless the bin is exactly centered in the bottom of the unit. There is a safety switch inside there, and a magnet to activate it. Make sure nothing is interfering with the bin or the shredder fitting together.
On other units, there is a slot that must match up with the shredder. It will only work one way. See of the shredder will turn around and put it on the bin the other way.
Mar 10, 2012 | Aurora Electronics AS1018CD Shredder
The red & yellow light light stay on motor doent turn on when I feed paper I took it apart & clean it still not working
If you've already cleaned the "eyes" you may have a bad PCB...give Royal a call at 1-800-524-0799 they should be able to help with parts.
Aug 11, 2010 | Royal VF1012mx Shredder
Cuts out after 1 second & red light comes on
The red light typically means either something isn't installed right in the shredder head, or there's a paper jam. Did you recently take the shredder apart? If not, there's probably some jammed paper in there somewhere.
Jul 06, 2010 | Fellowes PS60-2 Shredder
Red light on as well as green,what is the red light
The red LED can mean one of two things -- either the shredder head is not assembled correctly (did you take the shredder apart recently?) or there is a paper jam inside the machine. Sometimes the jammed paper is far down and hard to see.
Jan 30, 2010 | Fellowes PS60-2 Shredder
Red indicator light always ON mode but the unit is not jam.cannot run even paper inserted
This can be caused by more than one problem.
The bucket it not properly placed under the shredder or the safety switch is stuck or bad. I am sure there is also other reasons the could cause the red light staying on.
Nov 16, 2009 | Intimus 280 Shredder
The red light stays on and the shredder won't work
Unplug the unit
take it apart
7-9 screws on back , gently pry it apart , probly dirty as heck in there or somethings jammed in there, also clean off the lil sensor with a q tip and 70% isopropal rubbing alcohol
Jun 24, 2009 | Fellowes Powershred 420 Shredder
SB-97Cs Full red light stays on
You can order from Fellowes or a dealer like myself. Maybe the unit is all jammed up with shreds in the housing. Try taking the top off and cleaning it throughly. Be careful with the short ribbon cabl.
Jun 19, 2009 | Fellowes Manufacturing Powershred SB-97CS...
Red Light on, but no jam
Your problem is probally with the safety interlock switch on your machine. On the PS-65c It is located on the right hand side of the unit. There will be a tab of plastic on the inside lip of the basket that goes into a slot on shredder head. If plastic piece is bent or broken machine will not operate. If it does not appear broken make sure when you put shredder head on that it fits flush all the way around on the basket. If none of this helps contact Fellowes Customer Service at 1-800-945-4545 and we will be glad to assist you further.
Jan 28, 2008 | Fellowes Powershred PS-65C Medium-Duty...
Shredder problems
Seems it could be a problem with one of your sensors Fellowes Customer Service can easily and quickly diagnose your problem. 1-800-945-4545
Dec 07, 2007 | Fellowes Powershred 420 Shredder
ACCO Brands Rexel 3150 Shredder Logo
Top ACCO Brands Office Equipment & Supplies Experts
Adorjani Laszlo
Tom Chichester
Are you an ACCO Brands Office Equipment and Supply Expert? Answer questions, earn points and help others
