Question about HP® LaserJet M5035 MFP Laser Printer/Copier/Scanner/Fax/Digital Sending - Same Day
Squeaky noise So I did a test with 6 blank pages and the squeaking still happens so I know it has nothing to do with toner or cartridges. I assume its the rollers. If they need to be cleaned, how do I do this?
    Champion:
    New Friend:
  • 210 Answers
You clean the printer by running cleaning pages. You can find "Cleaning Page" in your printers menus. As for the "squeaky noise", I have found it is the worst with "recycled" toner and toner kits. Finding the cause of the squeak is a very difficult thing to do. You will need to remove the front, back and sides of your printer and check all the nooks and crannies for the squeaky wheel. I have been able to remove the squeak by installing a manufacturer original toner. "Cleaning" the rollers usually has nothing to do with the squeak.
Posted on Nov 20, 2013
  • 35 Answers
SOURCE: three broken horizontal lines across all printed pages
I can see a couple of possibilities here. One: The cleaning blade for the drum could be damaged and not all of the toner is being cleaned off of the drum between pages. Two: The drum could be damaged and the damaged parts of the drum are not accepting the changes generated by the laser. I don't think you have a fuser problem because if it were that, the toner would probably smear when you touch it. Typically, I would say it is the toner cartridge but you replaced it and still got the same problem. I would inspect the drum cleaning blade first. That would be the most cost effective first option. Hope this helps. Good luck.
Posted on Jun 21, 2007
IB4G2008
  • 3587 Answers
SOURCE: toner marks down right side of page
hmmm...sounds like your toner cartridge is truly unhappy. I'd return it if I were you.
no worries..start by getting new driver for that here
Posted on Feb 28, 2008
SOURCE: Squeaky Printer
Mine had a similar squeak and I took the toner out and shook it. Squeak went away.
Posted on Apr 29, 2009
DosHog
  • 168 Answers
SOURCE: Photosmart 7960 prints blank documents; prints from internet ok
If it can print from the internet, it is working properly. I would disconnect the printer from the computer, uninstall the drivers and reboot twice. Reinstall the drivers and hook up the printer when instructed. Make sure that you select this as the default printer. (unless, of course, you have another as default)
Posted on Jul 24, 2009
How to stop squeaky noise when printing?
Usually this is an engineers job. However, you can try a different toner cartridge if it's a laser printer, as often cheap cartridges will squeak.
Jul 31, 2014 | Brother MFC Office Equipment & Supplies
OKI C700 printer making squeaky noise when printing?could it be the cartridge- changed few hours ago?Thanks
If the squeak only developed after changing the toner cartridge then I would say yes it could very well be the cartridge. Particularly if it is a generic brand.
I have found that most squeaks in printers are caused by the toner/drum cartridge
May 26, 2011 | Office Equipment & Supplies
My HP P1505 makes a squeaking noise when there is a motor turning inside, but not when it's just on. Sounds like a roller or bearing. It has a non-HP toner cartridge. Does this model have a known...
Most noises on these models are caused by the cartridge. Typically fuser issues will cause a growling noise not a squeak. If the inside of the machine is dirty you could have toner on the transfer roller busings. Try a different cartridge first, you fastest and most likley problem.
Apr 30, 2011 | HP LaserJet P1505n Printer
Black ink is coming out on one side of paper only
If this means that part of your page is coming out blank then the easy fix for this is to remove the toner cartridge and while holding it level, shake the cartridge from side to side. This will re-distribute the toner inside of the cartridge and restore printing to the reset of the page. Just re-install and test. This happens most often when the cartridge is starting to get low on toner so you may want to begin the process of getting another cartridge on the way.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 02, 2011 | Canon PC-940 Black and White Copier
If my printer is squeaking what could be the problem besides the toner cartridge?
Squeaking noise is usually caused by the toner cartridge, expecially after market ones. But if its not the toner, I've seen the mirror motor cause a rotation noise in the 1300/1200 series printers.
Nov 18, 2010 | HP LaserJet 1300 Printer
Hl-2140 noises
For a possible fix to the Brother HL-2140 squeal/squeak/noise problem open the printer at the other side from the paper tray and toner cartridge door. You should see a little black roller rod along with some white wheels.
The noise may be coming from the contact between the wheels/rollers which pull paper toward the output tray on top after it has been printed.
Check and clean/wipe the wheels and black rod, especially in the center area. Hopefully the noise will now be reduced/eliminated.
Cheers, Stephen
Sep 14, 2009 | Brother HL 2140 Laser Printer
Squeaky HP printer
Typically the squeaking comes from the toner cartridge. If you just purchased it, take it back, it's bad. If you can find an identical printer, swap cartridges and see if it makes a difference.
May 27, 2009 | HP LaserJet 1300 Printer
Nextra7 condenser dryer making squeaky noises
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
tukuymhg
Feb 14, 2009 | Hoover Nextra 160 HNWF 3137 Front Load...
Squeaky Printer
May 29, 2008 | HP LaserJet 1100 Printer
HP® LaserJet M5035 MFP Laser Printer/Copier/Scanner/Fax/Digital Sending - Same Day  Logo
464 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
