Question about Samsung B1245 Front Load Washer
Flashing DE and still has some water in machine. Have cleaned filter
The water comes out the top of the manuel filter so not all the hot water goes through the holder. the coffee is loosely put in the filter
Try running vinegar through the Keurig to clean and de-scale it. You should use white vinegar, run it through using several cups until there is no vinegar left, then use clean water to brew plain hot water until you can no longer smell vinegar. This will help de-scale the Keurig and potentially remove any plugged bits of coffee that may remain.
Mar 01, 2011 | Keurig Coffee Makers & Espresso Machines
Hi my washing mashine wont spin, and code 0E comes up on sreen and start button starts flashing PLEASE HELP THANKS
That is actually DE. (Drain Error) Open the small access door at the bottom left corner of the front panel. Use the small hose to drain the remaining water out of machine. Unscrew the big knob and pull it out to clean out filter. (If filter was clear, replace pump motor.)
Jan 01, 2011 | LG Washing Machines
Getting DE error
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.
Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.
Thank you !!
Jul 26, 2010 | Samsung WF337AA Front Load Washer
Washing machine comes up flashing with a de sign
LG machines with DE (Drain Error) Water has not drained enough in 5minutes...Probably due to a partially blocked pump filter....Repeat drain to empty machine and cleat pump filter,,,Access via small door at floor level, unscrew pump cover, and clear filter... Some water may be released. Leaning machine back can help!...Good luck..Nomess
May 17, 2010 | Washing Machines
Water tank indicator light will not stop flashing even after loading the circuit as directed
There is a restriction in the suction line.If you can open the machine, just follow the water line,you'll find the filter which may be dirty, cleaned it or in the flow meter itself.It can be cleaned.Make sure to reconnect the hoses correctly .
Aug 12, 2009 | Saeco Magic De Luxe Espresso Machine
De error code
Hi
"dE" means that the door hasn't been closed properly. Check the inner seals of the washing machine particuarly at the bottom where water can get clogged. Also check the rubber seal around the front door to see if it has popped out or out of alignment. Also, "DE" in full letters can mean that the drain needs to be cleaned. Switch off the washing machine, pull out the flap on the bottom LH front of the machine, find the water tube and drain the water out of the LG. Then unlock and inspect the actual plastic tray/grid when twisted to unlock and pull out. There should also be a "drain" function on the main dial as a general maintenance option. Make sure you do this to keep your machine going.
Dont forget to rate this please if this solution works. Many thanks.
Mar 28, 2009 | LG WM1812C Front Load Washer
Cuisinart dcc-1150 coffeemaker
To replace water filter: Pull water filter holder out of reservoir, snap open, insert new charcoal water filters (can be ordered from Cuisinart or purchased froma store like william-Sonoma)
To clean machine: Run 2 cups water and 2 cups distilled white vinegar through machine like you would normal coffee.
To get rid of annoying self-clean lite: unplug machine from wall outlet for 20 minutes or longer.
-Tha Mp3 Doctor
Oct 24, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Filter in saeco magic delux
little magnet keeps that red light from coming on.
magnets probably gone bad, need to buy a new water tank. As far as i know saeco does not sell the magnets seperate.
could also be a blockage sending the machine into alarm.
May 08, 2008 | Saeco Magic De Luxe Espresso Machine
Water light is flashing but tank is full
I had the same problem - Cause: plugged water filter. We always used RO water so never replaced the filter. After 4 years I guess it was due.
Solution: Reprime the water system. Remove water filter. Fill tank with water. Turn machine on. Put a container under the steam/hot water wand and open the knob on the front panel. You may need to run half a tank of water through it before it resets. Hope this works for you all.
Mar 09, 2008 | Saeco Magic De Luxe Espresso Machine
Samsung B1245 Front Load Washer Logo
21 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
