Question about Garden
How do i replace choke cable on my dyt 4000?
Craftsman Kohler Pro 26 V-twin, choke is froze up, need to replace choke cable
chad7houston
  • 62 Answers
SOURCE: replacing the blades on a craftsman dyt 4000
Not a hard job, but you will need a couple of tools. First, you will need a wrench that fits the nut that is holding the blade on. I prefer a closed end wrench, but an open end will do. Second, you will need a blade changing tool. The brand name is called a Blade Hog. It attaches to the deck and holds the blade in place so you can turn the nut. Raise the deck as high as it will go, attach the Blade Hog, and then loosen and remove the nut. Be sure and pay attention to which side is up on the old blade and put the new one on in the same manner.
hope this helps,
c
Posted on Oct 08, 2008
spekgt
  • 60 Answers
SOURCE: what engines will fit craftsman dyt 4000 (18.5 blew w/ 290 hours)
Hi there
The only thing you have to do is have the size (diameter) and lenght (from cranckcase to end of shaft) of the shaft you have on your b&s and just go to your local Honda dealer , give them your shaft size and they should be able to give you all the options for a brand new motor . I really believe you can get a Honda 20hp model GXV620 or a 24hp model GXV670 that will replace your B & S motor .
Hope this help .
Posted on Sep 01, 2009
mowerman1857
  • 389 Answers
SOURCE: where can i fine manual for engine replacement
TO REMOVE THE PULLEY FROM THE CRANKSHAFT END:
Remove the blade belt and, if needed, the deck to give yourself more room to work. Apply your brake pedal and lock it down, this will relieve the tension on the ground drive belt.
If you have an electric blade clutch, find the plug where the wire goes over from the clutch to the frame and unplug it.(Electric clutch will be heavy when unbolted so be ready for it.)
In the center of the pulley or blade clutch you will find a long bolt (most likely a 5/8 head on it) You may need a deep socket to reach it depending upon the type of stack pulley on it, remove this bolt and the pulley should slide freely on the crankshaft. slide it downward and slip off the belt on the top of the pulley then remove the pulley the rest of the way
Posted on Oct 05, 2009
  • 33 Answers
SOURCE: My craftsman mower with a 26 hp kohler dies when choke is in
carb dirty, jets partially plugged, float sticking. Not so uncommon problem and is caused by the fuel left in the carb over the winter gumming up (going bad). You can attempt to clean this on your own if you are somewhat mechanically inclined. Search small engine repair and it will give you a generic breakdown of the parts in a small engine carb. If not the, to have someone overhaul a small engine carb will run you about $120 including parts (at least around VA).
Posted on Apr 05, 2010
  • 19 Answers
SOURCE: How do you remove an engine from a Craftsman dyt
remove the deck and drive belt, then the pully and the four mounting bolts. unplugg all the wires and lift the motor out.
rural king has briggs and straton motors at their stores for a cheaper price than on line. I got a 18.5 hp for $420.
Posted on Aug 09, 2010
What is the head bolt torque specs for a Kohler Pro 25HP V-Twin engine?
Go here and look up your engine model
Owners Service Manuals
Here is a Manual for the Kohler Command Pro CV26
http://www.kohlerengines.com/onlinecatalog/pdf/24_690_02_EN.pdf
The picture shows the torques of the Kohler Command Pro
Aug 19, 2014 | Craftsman Garden
Craftsman DYT 4000 with 26hp Koehler and 48" cut. Tractor will start but will not run smooth. Need to have the choke pulled out and once you push it in the motor shuts off. Will not start if choke is...
try running a can of seafoam through it. you have a clogged carb passage or two. sometimes this works. if not youll need to clean out that carb
May 14, 2017 | Garden
My Craftsman 4000 dyt lawn tractor's electric clutch went out and when it locked up it choked the motor down....now everything is dead, there is not and "juice" going to the starter, the headlights will...
Sounds like the machine stopped charging,usually caused by a faulty rectifier/regulator or a bad connection to it.Try either charging the battery for an hour or so or you can put booster cables from your car to it and then if everything is ok you need to fix the charging system,or replace the battery[once they are sulphated they will not take a charge even if the charge system works].Check the connections to the battery as well and if you can test the tractor when it is running and see if the voltage stays between 14 and 15 volts.Let me know how you make out.
Jun 12, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Apr 04, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
What engines will fit craftsman dyt 4000 (18.5 blew w/ 290 hours)
Hi there
Hope this help .
Sep 01, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
