Question about Cifial Hi-Arch Widespread Lavatory Faucet CIFIAL 245.150.625
Installation instructions plumbing
How do I change the faucet direction for the cold water? The plumber installed it so that the cold water faucet turns counterclockwise instead of clockwise to shut off.
  • Patricia Felder
    Patricia Felder Nov 19, 2013
    He did put the cold water faucet on the correct side (the right), but I learned later that both the hot water faucet and teh cold water faucet are supposed to turn clockwise to shut off. The cold water faucet instead turns counterclockwise to shut off. I'll call the plumber--it make require replacing the cartridge to fix it. Thanks!
    Novelist:
  • 180 Answers
He put the wrong faucet in the cold-water side.. There may be a way to change the direction without changing the faucet... but, if there is, I don't know about it... I think you need to make the plumber come back and fix it right.. I had that problem in my shower after a plumber worked on it.. I almost burned myself to death trying to adjust the temperature.
Posted on Nov 19, 2013
I need help tightening a kitchen faucet to the sink.
If you look under the sink you shouls see a big nut ...all you have to do is to tighten it while holding the faucet on top at the right place
Mar 24, 2017 | Moen Plumbing
I need to replace the hot water handle
A picture, model, or brand of the type of faucet you have will be helpful as there are only three types of faucets. One hole, two hole, and three hole faucets. The one hole ones have two types: a single hot or cold, or a mixer valve to combine hot and cold into a single faucet. Each have a surface mount or wall mount version.
They all follow the same similar installation method. Turn off water supply. Unscrew supply lines from supply to underside of the faucet. a Plumber's wrench is needed or a spanning crescent wrench to remove the supply lines.
-Unscrew whole assemble from the sink.
-insert new one into the same hole as old one.
-from underneath, install the new faucet using the supplied hardware.
-Use plumbers tape (Teflon tape). It's often a white or pink silicon tape around the threads prior to screwing the supply lines back in. Re-connect the supply line.
-Open hot water faucet to maximum. Slowly turn on the water supply. Watch for leaks and drips. If any close the water supply and undo the supply leads and apply more Teflon tape.
- to apply tape. Start at the end and pull tightly, wind the tape into the threads in the direction of the turn. Do not wind in opposite direction.
-Try to turn on water again, turn slowly until it is at maximum, watch for leaks and drips.
-now slowly close the faucet and continue watching for leaks and drops.
If the faucet is fully closed and there is no leaks, you've done a good job... basic plumbing 101.
Now if your pipes are solder types and not screwed in supply line, and you're not confident with a torch or have little experience, ask for help from a friend who has some torch knowledge or hire a plumber. It is simple to do but requires a lot more steps than simply screwing in and unscrewing supply lines.
Aug 30, 2015 | Plumbing
I need anInstallation Manual for Grohe Concetto faucet..where can I find one?
contact the plumber and have him fix his mistake the faucet came with instructions . what did he do with them
Oct 16, 2014 | Grohe 3427 Concetto Single Hole Bathroom...
Water Heater Rumbling When Running Cold Water In Faucet
Check and see if the cold water has been plumbed to the 'c' on the heater, the hot to the 'h', and the relief valve somewhere else, usually on the side. Maybe the plumber cheated somewhere to make installation easy.
Nov 29, 2013 | Rheem Water Heaters
Our tankless hot water heater runs cold sometimes.
Check for crossover: Where bad faucet cartridge or check valve lets cold enter hot pipe so hot never arrives at tap.
http://waterheatertimer.org/Crossover.html
If problem is not plumbing, then add a comment and describe which water heater you have, including approx age and what has been done so far.
Call local plumber to fix tank-type heater
If you have tankless, call manufacturer to get list of local technicians who work on these computers that heat water, or save money and tear it off wall and install tank-type heater today.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
Aug 04, 2013 | Bosch & Tankless LP Hot Water Heater
We have a Reliance 501 Electric Water Heater. We get only very hot water in bathtub in one bathroom but not the other bathroom. Could the problem be the water heater?
No, the problem is not in the water heater. It could be the plumbing pipes were installed incorrectly.
A common problem with hot water is also found in the settings of anti-scald and pressure balance tub and/shower valves. You may only need to reset the temperature control on each faucet. Every faucet brand has a slightly different adjusting system. Hopefully you can find the faucet's brand name, and then visit their website to find the owner's instruction manual for your model.
A cross connection in the water piping system is rare, but it does happen from time to time. It would allow cold water to mix with the hot. You would need a plumber or leak detection company to locate every water pipe connection in and/or under your home to confirm and correct the issue.
Sep 05, 2010 | RELIANCE ELECTRIC WATER HEATER
Very little cold water from shower valve
If this is a new installation and has always beenj this way, then I would suspect that there may be an obstruction in the cold water line leading to the valve. Or something stuck in the valve at the point where the cold water is connected. If someone has worked on thius valve recently , then I would suspect that they got the valve cartridge in backwards, If the catridge is not placed in the valve correctly the opperation is messed up.
May 06, 2010 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Delta 174925 single faucet,only gives Tepid water on ''COLD''
SOUNDS LIKE THE CARTRIDGE ASSEMBLY IS BUGGERED UP. PART #46463.
MAYBE THIS WILL HELP:
All parts and finishes of the Delta faucet are warranted to the original consumer purchaser to be free from defects in material and workmanship for as long as the original consumer purchaser owns their home. Delta recommends using a professional plumber for all installation and repair.
Delta will replace, FREE OF CHARGE, during the warranty period, any part or finish that proves defective in material and/or workmanship under normal installation, use and service.
Replacement parts may be obtained by calling 1‑800‑345‑DELTA (3358) or by writing:
Delta Faucet Company Product Service 55 E. 111th StreetIndianapolis, IN 46280
Dec 15, 2009 | Water Heaters
Installing a Pot Filler
Hi 13Kat,
I'm Harvey the Master Plumber.
You must connect to a flanged fitting behind the wall. The wall is sandwiched between the flange behind and the escutchen in front that holds the pot filler in place. These are usually installed on stainless steel sinks that have stainless steel back walls and do not come supplied with the flanged fitting, available at any plumbing supply.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Oct 06, 2008 | Franke PF3000 Deck Mounted Pot Filler...
Plumbing
Hi rbyerly,
Your problem is:
remodeled bathroom,installed new moen valve and hardware. Now water is coming from both the shower head and the faucet when the diverter is in the down postion. Question; Is this a single handle or three handle diverter? Assuming it's a three handle, it should just be a mater of adjusting the center handle. If single, the diverter is in the spout not the valve. I don't know how to direct you further without specifics. Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Oct 06, 2008 | Home
Cifial Hi-Arch Widespread Lavatory Faucet CIFIAL 245.150.625 Logo
85 people viewed this question
Top Cifial Home Experts
Donni Steen
Tom Chichester
Are you a Cifial Home Expert? Answer questions, earn points and help others
