Question about Toys
Bmw 745I Problems - Toys
5 Suggested Answers
tse22
  • 103 Answers
SOURCE: brake warning light is on for 2002 bmw 745i.
The brake pads have sensors in them, when the pads get worn down to the sensor the light comes on letting you know its time to replace. this happens well before the pads are completely gone to reduce wear on the rotors. You should have the brakes replaced and the sensor also.
Posted on May 17, 2009
Atyourdoor
  • 93 Answers
SOURCE: BMW 745i airbag light. Told to replacing airbag clockspring
Hello , check the airbag contact sensor behing the grill assembley . They are located to the left and right of the grill almost to the headlight assemblies. Check the wires to them for corrosion and damage. Check the fuse as well. There should be an air bag testing wire or fuse in the fuse panel. DO NOT UNPLUG THE AIR BAG SENSORS OR HIT THEM !!
Posted on Aug 22, 2009
  • 37 Answers
SOURCE: Need a bmw 745i 2004 Owner Manual
I t may help you, I found this store on ebay, there are pretty cheap books, I bought mine from this guy, check it out:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=180490869526&viewitem=&sspagename=STRK%3AMESELX%3AIT
if the link doesn't work just try item number 180490869526
Posted on Jun 05, 2010
dvwright
SOURCE: I have a 2003 745i BMW Transmission
The transmission is a sealed unit and the system does not have a dip stick for the typical user to check. Check the floor/pavement beneath where you normally park the car each day, if you see an oil stains then the gaskets are probably leaking and need to be replaced. Expect to pay $1,100 to $1,500 at the dealer.
Posted on Oct 03, 2012
Bmw 745i problems
check your fader switch from front to back >>>>>>>>>>>mutebuttonon radio not switched on ...alternatively radio output or amplifier in car if fitted
Jan 13, 2014 | Cars & Trucks
Bmw 745i problems
as the noise is not described, a suggestion to check the exhaust manifold , gasket or flex section of the exhaust pipe to manifold may be in order
the flex section has a habit of cracking under the stainless steel braiding
Oct 30, 2017 | Cars & Trucks
What are signs and symptons of thining brake pads on 2005 bmw 745i
fluid level drop and eventually a high pitch squeal when applying the brakes.
Sep 03, 2012 | 2005 BMW 745i
My 745i has gas and batterty power but it will not start.
The 2002 BMW 745I has a recall when the gas goes under a third of gas it will shut off and not start cause it thinks it has no gas. You can call BMW and they will check if your car is on the recall list and you can get it fixed for free. Or they told me to just take it to the BMW dealership and tell them.
Nov 14, 2010 | 2002 BMW 7 Series
2004 745i needs a new engine. Is it worth paying
WHY do you need a new engine for the car,whats wrong with it as no engine is worth throwing away and a BMW it worth doing it up as even a 318i is worth doing up etc as the body is worth selling if 100%and the engine is worth doing so dont be a mug.
Oct 27, 2009 | 2004 BMW 7 Series
I need to tow a 2002 bmw 745i, i have a dead battery and can't put it in neutral
YOU need to take the KEY and JUST above the Hood latch is a place tofit your Key, Turn and a box filps down with a cord, pull the cord and it makes the gear go to neutral
Sep 18, 2009 | 2002 BMW 7 Series
Aug 22, 2009 | BMW 750 Cars & Trucks
BMW 745I 2002 wiper dead
there are several things that can cause the wipers in your car not to work. if you have verified the fuses are good and verified power to your wiper motor, I would try disconnecting the negative battery cable for 15 minutes, then checking operation of the wipers. by the way, which fuses did you check?
Mar 24, 2009 | 2002 BMW 7 Series
Toys Logo
678 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
