Question about Music
My jack input fell inside my hollow body jack Cassidy bass I managed to pick it out but now the wires have detached from the input. Any ideas what is the best course of action? I have found one of the connecting wires (should there be 2?) but it's too short to attempt to pull out and solder back on help!
    New Friend:
  • 21 Answers
Join a piece of wire to the connecting wire and solder in place .
Posted on Nov 22, 2013
3 Suggested Answers
  • 31 Answers
SOURCE: plug-in jack fell inside body of epi dot
jus take the roof bracket off the scratchplate and you can push it back out with some copper wire ! happened to me twice lol
Posted on Oct 25, 2009
  • 5603 Answers
SOURCE: my input jack's nut has
Open the unit and restore the jack to the proper place. Do NOT overtighten the input jack mounting nut.
Posted on Feb 01, 2011
I need the wiring diagram for an Ibanez AS153 semi hollow body, where can I get one?
the 153 is wired like a Les Paul or SG
2 humbucker, 2 vol, 2 tone
with the addition of a 3 way coil tap for the neck pick-up
wired similar to:
http://www.guitarelectronics.com/product/WIRING_MOD_HB0066/Guitar-Wiring-Mod-HumbuckerOFFParallel.html
Aug 16, 2016 | Ibanez Artstar Series AS153 Semi-Hollow...
How do I replace cord jack on a Peavey bass guitar?
You'll need needle nose pliers, small phillips head screwdriver, soldering iron, electronics-grade solder, socket screwdriver or 1/4" wrench, black electrical tape. Purchase necessary replacement jack. Remove plastic electronics cover plate, located on the back of the body, behind control knobs. This will expose the electronics cavity. Locate existing jack and its wire connections inside the exposed cavity. Remove any electrical tape covering the jack connections. Using a hot soldering iron, touch each of the two soldered input jack connections, one at a time, just until the soldered connection melts. Then, disconnect the associated wires (taking note of which wire connects where!). Once disconnected, loosen and remove the nut on the outer part of the jack that holds it onto the guitar body. Remove the old jack. Insert the new jack (with the nut removed) into the existing hole, from inside the electronics cavity and tighten it in place, on the outside of the guitar body, with the nut. Re-attach the wires to the new jack, by using needle nose pliers to wrap them tightly around the correct posts. Touch the hot soldering iron to each post and apply a small amount of solder to the post as it's being heated. Once the molten solder runs over the connection and looks shiny, remove the tip of the soldering gun. This process takes only 2 to 3 seconds. Let the connections cool for a few seconds. To insulate, wrap connections with black electrical tape. Replace cover plate.
Apr 27, 2014 | Peavey Music
Active pickups on bass, no sound
Without additional details, this is impossible to answer. I'm assuming you changed the battery? verified the pick ups are still wired and have not come unsoldered? The internal portion of the jack could have become bent or stretched and is not making contact with the cable? What kind of bass and pick ups?
Sep 01, 2013 | Music
My double pick up Dean edge quit working while playing. I checked the wiring and all looks good, but three is s a black wire coming from hole to center of body attached to nothing. Looks like it never was....
Make sure you have two wires soldered to the output jack on the bass. having a wire lose is not purposely put like that, for no sound from the bass then that wire is either from the pickups and connects to the pots on the bass or on the output jack. I would suggest taking it to an authorized dean dealer to inspect the wiring.
Jul 13, 2011 | Dean Edge 4 Bass Guitar
My Epiphone Dot just started humming really loudly when I plug it in - it stops humming when I touch the input jack. I assume it's a grounding issue on the input jack, but how do I get at...
Make you a hook out of a coat hanger. Get inside and hook the wiring to the jack, take the nut off the jack and pull it up through the F hole. You can plug in to it a patch cord so you can pull it back through once fixed. Check out Guitarelectronics.com for a wiring diagram.
Jul 03, 2011 | Epiphone Elitist Country Deluxe Hollow...
I have a Fender Deluxe Active Jazz Bass thats makes this really really loud buzzing earthy sound. It seems to happen spontaneously, in fits and starts, but particularly if the cable input on the bass is...
This sounds like either a bad guitar cable or a bad jack in the guitar. Possibly your friend is not as qualified to find these intermittent problems as needed? These jacks are really junky and often have riveting of the barrel come undone... especially if the retaining nut is overtightened. The LONG barrel like jacks are notorious for failing. You have all the information you need to solve this problem. First try a different guitar cable... (often they are broken or intermittent at the end where they flex). If that doesn't fix it, replace the jack in the guitar. Also verify that the conductive coating paint within the guitar is grounded. Sometimes the contact to it is destroyed when the volume control shafts or jacks become loose and they depend upon the shaft barrel to ground the paint.
Jan 30, 2011 | Fender Deluxe Active Jazz Bass Electric...
Bass Guitar Keeps sound keeps cutting in and out.
There is an inconsistency in your text. You indicate that cables were swapped and problem still existed...
You said:... "i have tried using it on a different amp and still fine".
If you tried it on a different amp and it was still fine then the guitar is probably OK.
THEN your amplifier is in question as the root of your problem.
What is the amp you have? The guitar is the CB-42, but what amp do you have?
MANY intermittent problems with amplifiers are often with the input jack itself. These jacks are easily broken by tripping over a cable plugged into them.
Jan 04, 2010 | Fender Rumble 100 Bass Guitar Amplifier
Plug-in jack fell inside body of epi dot
Oct 22, 2009 | Epiphone Dot Electric Guitar
Fender bass guitar shorting out
Inspect the wires leading to the 1/4" jack on the bass. Try moving them to see if you can figure out which wire is the culprit. Check for any bad solder joints on the pots inside the guitar.
Chances are the jack has been twisted and damaged a wire and/or a solder joint.
Jun 16, 2009 | Fender Music
Music Logo
54 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
