Question about Ecoquest Breeze AT Living Air Purifier
Wiring diagram for breeze at
Which set of pins does the ribbon wire plug into
I have a Sharper Image Ionic Breeze GP S1730 the inside wire broke on. Does anyone know how to repair it????
One person used piano wire, but the diameter must be right so the cleaning beads can slide up and down on the wire when the unit is turned up and down.
Oct 22, 2013 | Sharper Image Ionic Breeze GP SI730 Air...
Ionic breeze air purifier will not work
Bad limit switch for the removable fin bar Connected the red wires together
Mar 15, 2013 | Sharper Image Professional Plus Ionic...
The guide wire(s) inside my ionic breeze bathroom air freshener (model S1717) broke. How can I replace these wires?
either cut and strip wires and wirenut them back together or order another harness i suggest the first option
Feb 23, 2010 | Sharper Image Ionic Breeze Air Freshener...
One of the wires on my ionic breeze quadra broke. It is one of the wires that have the glass beads on them that you clean by turning the quadra up and down. Can it be replaced and how? Thanks.
You're probably screwed...
The company went under and doesn't service them anymore. It's possible you could find a local repair place that might be able to do something, but there is no authorized or trained service station, and you can't get parts.
You might be able to pick up spare parts if you scour eBay long enough.
Dec 02, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
I have a sharper image ionic breeze professional series and paid a preety penny too. one of the wires inside rusted and broke, it lights up but no breeze is comming from it and the green light doesnt come...
If you're referring to one of the ionizer wires (wire that has beads on it to clean the wires) then unfortunately, I'm afraid the unit can't be repaired. As Sharper Image has no authorized repair centers or replacement parts. If you're referring to wiring in the base of the machine, then a repair could be affected by either cleaning off the wire ends and reattaching them with a small piece of wire or soldering the broken wire back to the unit itself. Sadly, many of us (myself included) spent a lot of money on these units and the only place I've found parts is a website called http://breezerepair.com/parts.html (not an authorized repair center) but of the parts they have carry, they don't have the wire you referred to. Sorry to be the bearer of bad news.
Nov 07, 2009 | Sharper Image Professional Plus Ionic...
I have a professional series ionic breeze gp. It stopped working and has a red light on-something I had never seen before. Can you help with this model?
Well there is a small micro switch that is actuated by the grid. This is mounted on the side of the top control piece. There are two wires attached to the little circuit board, usually one is corroded so you need to cut it back and soder it to the center pin of the switch. also check the fuse.
Good Luck!!
Thanks
Sep 20, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Broken "wire/filament' in ionic breeze quadra
This does NOT work. The electric guitar wires burn out in 1-2 months.
Jul 13, 2009 | Sharper Image Professional Plus Ionic...
No power.
Jan 29, 2008 | Sharper Image Ionic Breeze GP (SI730) Air...
Ecoquest Breeze AT Living Air Purifier Logo
41 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
