Question about Protron Televison & Video
Loud frequency noises
Turn tv on sometimes the sound will not come on for hours....then there is this loud horrible frequency sound that is piercing.
  • 115 Answers
Just change the speakers
Posted on Nov 19, 2013
SOURCE: SHARP,PIERCING, ALARM LIKE NOISE COMING FROM TV
Could you give me the link that lists other sound problems about Olevia TV's? My sound fades in and out. It's annoying.
Thank you.
Posted on Nov 15, 2008
javswr
  • 44 Answers
SOURCE: Hi pitch squeel (Electricial Hi frequency noise),
Check your power supply board for some bad caps (capacitors) on the board. They will look bulged on the top an may be a little leaky (brownish stain). A bad cap can sometimes produce a harmonic, causing issue's with the sound. Also look at the signal board (where all the inputs are), for bad caps. I have come across this on a lcd tv!! Good luck, hope this is helpful!
Posted on Mar 01, 2009
rulds2008
  • 3866 Answers
SOURCE: TV creates LOUD sound when turned on. sounds like a blow horn.
Manufacture is recalling most of these and I am aware of this issue contact the manufacture to have them fix it for free.. Thanks
Rulds2008
Posted on May 15, 2009
  • 92 Answers
SOURCE: I have a 32inch vizio
change your main board will correct this problem.
Posted on Jun 20, 2009
gsalmen
  • 77 Answers
SOURCE: loud white noise sound when i switch my LCD tv on.
the main total assy is failing. it has the tuner ,sound, and a lot of the processing for the set check there first
Posted on Jul 09, 2009
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
How can I fix my television?
Please consult some local TV tech.
Aug 04, 2015 | Televison & Video
Some notes on keyboard leave a horrible piercing static noise when volume is turned three quarters up.
Sounds like feedback from your monitors, the speakers can't be pointing in the direction of the mic.
Sep 09, 2017 | Yamaha Piaggero NP11 61 Key Digital Piano
Sudden rainbow vertical lines, Loud squeel. wont turn off. Whats wrong?!
good first shut off the outlet for what is looking like this with your tv connection problems with the drain tube of images giving us the inside source for capacitors in a technical lead for the electronic exchange of capacitors and diodes for your device
Sep 06, 2012 | Samsung LN46A500 46 in. TV
Hi I have a very annoying, ear piercing high frequency pitch coming from what seems to be the television. However, I was trouble shooting and based on the cable technicians thought; said to be the...
Hello
The LOT [Line Output Transformer] of your TV has damaged. It is the one, that supply all the voltaged needed to CRT. Its internal windings will get shorted in between, and is irreparable. Replacement is the only remedy to this proble. Replace the horizontal output transistor also with this. you haven't specified whether there is picture with your tV or not. If this high frequency sound is along with picture, there is some loose in the cores of the SMPS transformer, or LOT itsef. If there is no picture at all, and this high frequency sound is there, no doubt; LOT is damaged. OK.
May 22, 2011 | JVC TM-2703SU 27" TV
TV is making a loud ear piercing noise.
Ur high voltage is going through FBT,the big black block of plastic with a wire red or gray solder to the board.The Flyback transformer.There a steel "3 inches like a paper clip like steel.Put some supper glue on that "3 steel paper clip look like, will help or stop loud wishling noise all together.
Apr 21, 2010 | RCA HD52W59 HDTV Projection Television
Lift phone to make a call, get a line tone and then loud piercing noise as I move around the room, so am unable to have a clear noise free conversation. Phone is BT Studio 1500 digital phone with answer...
try walking around the room/house and turning any other electronics off, if the interference stops, then you've found the offender! could be RFI (radio frequency interference), could also be a neighbor! if you can change frequencies on your phone, try a different one. may work.perhaps you have a computer or other electronic device that's badly shielded. you may have to replace your phone with one that operates on a different frequency, if you can't find the problem!
good luck!
Sep 29, 2009 | Lands Phones
Hi pitch squeel (Electricial Hi frequency noise), sounds like noise from a step up transformer or inductor. What can I do to stop this noise... It stops after about 1 or 2 hours after power on. but it is...
Mar 01, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Loud buzzing noise throu8ghout cycle. Sometimes washer sticks in wash mode
first thing i would check is to make sure your copper water line is not touching the motor this will give you this noise. just take off lower kick plate and start d/w you will be able to tell where the noise is coming from.
Nov 28, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
Televison & Video Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
