Question about Kodak ESP Office Equipment & Supplies
Calibration ok but still prints blank pages
Replaced both black and colour ink. calibrated printer and all the colours printed out perfect. However document is coming out blank
    Champion:
    New Friend:
  • 210 Answers
If the print tests are good, the only thing preventing your printer from printing is the print drivers. Download the latest correct drivers from Kodak's website and install them.
Posted on Nov 20, 2013
  • 238 Answers
SOURCE: Colour won't print - HP Deskjet 5150 Inkjet Printe
hi, remove the color cartg take a tissue paper and run it horizontaly on the nozzel, if u can notice the three colors, ur cartridge is ok, may be the contact area of the cartridge,try to clean both the surfaces, and install the exact driver for the printer which will give you the cartridge maintenence options. let me know??
Posted on Dec 16, 2007
  • 518 Answers
SOURCE: Kodak esp 3 all in one. colour prints come with purple tint
Surely you can turn the flow of ink down via your settings
Posted on Jun 14, 2009
SOURCE: Using colour ink without black ink in Epson CX5500
this cannot be resolved, Epson software is useless it will force you to buy an INK
Posted on Jul 13, 2009
Sebin
  • 712 Answers
SOURCE: black ink will not print. Colours ok
Get a syringe, remove the needle, remove the ink cartridge and use the syringe to blow air GENTLY through the hole the cartridge connects to. Make sure you have a cleaning cloth to remove ink dislodged from pipe connected at the print head, do this gently to remove any obstruction and there should not be too much mess and can easily be cleaned up.
Posted on Feb 04, 2010
SOURCE: Lines running horizontally across the printed colour page
Checked ink cartridge's, two had dried out, still had ink in them but the exit apertures were blocked.
So new set of ink cartridges and problem fixed.
Thank you
Jim
Posted on Feb 06, 2010
My colour text comes out with a shadow (in a different colour) like something is out of line. Black text prints crisp and clean.
yes, it is something of line. Color text is printed by three cartridges overlapping on the page. Most printer have a setting called Calibrate. You can sometimes do it in Windows, too.
Start button--> Control panel-->devices and printers--> (right click the name of the printer--> properties--> the last tab often is calibrate.
Sep 26, 2016 | Office Equipment & Supplies
Why is the colour in my photographs not printing as they are in my laptop I have added new inks and cleaned the printing heads
Anonymous, there's a whole science of "color management" that you've invoked. First, what you're seeing is truly caused by lack of "calibration" in any stage of your workflow.
Your camera takes pictures, and whatever colors it sees are what it sees.
Your monitor shows you colors, but there's no standard calibration involved.
Your printer prints colors, but it too isn't calibrated to any standard.\
Assume for a minute that your monitor is set up to be a little too dark. You edit the pictures, and lighten them up so they look ok on screen. Now, when you print the picture, it's too light.
I've had similar issues, and have ended up purchasing a monitor calibration tool (Color Munki Smile) to calibrate my monitor, software "Profile Prism" to calibrate my printer, and now the prints I get look almost exactly like what I see on screen...
Sep 11, 2014 | Canon Pixma iP4500 InkJet Printer
HP Photosmart C7100 - only 10% of page printer
If your printer does not print the entire page, it is probably because the print head is clogged. Try going to print preferences and locate "maintenance". Find the "clean print head" option and click on it. Follow the instructions. You might have to do it several times, and that will use a lot of your ink, but it might do the trick!
As for the "printer can't get calibrate", that is refers to your print head. That has nothing to do with your cartridges, as they are just tanks with ink in it. Check this link, might help:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1153777&prodTypeId=18972&prodSeriesId=1153777&objectID=c00721373
Mar 08, 2010 | HP Office Equipment & Supplies
WHAT IS DENSITY SENSOR IN LASERJET 8500
The Density Sensor is located inside the right upper door and senses the colour calibration pattern for each colour formed on the transfer drum during a calibration cycle. Press GO. Print a configuration page and then troubleshoot as an Image-quality problem as instructed in the user manual. Check the transfer guide for cracks and replace if necessary. Check the event log for errors numbered 54.00.0<X> the X indicates, 5-sensor abnormality, 4-Cyan, 3-Magenta, 2-Yellow, 1-Black. The last 3 error codes should be seen on the Configuration page.
Dec 29, 2009 | HP LaserJet 8500 Color Printer
Printer keeps showing Office Jet 8500 Wireless
The printer wants to align the print cartridge, if you print out the alignment sheet, and then following instruction, place on scanner and scan it in etc, and it fails to callibrate, I have found it is because some of the information on the calibration page is not being printed correctly so therefore machine cant calibrate the print heads from it, this is normally due to poor quality cartridges or failing/empty print cartridge or cartridges, these use two I think, and I bet one of the colours from the colour isn't printing properly, replace colour cart if blacks look good. Below is a link to HP so you can see what a alignment page needs to look like to pass calibration, compare yours and you may find a colour is dodgy on it.
see HP's support information
Nov 12, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Printer will not print anything black. What do I
run a nozle check, and clean them, if this doesent work, replace colour ink cartidge with a new one
Aug 30, 2009 | Kodak Office Equipment & Supplies
Our 5300 won't print black text yet there is more black ink than colour.
Try this one, Turn on the printer, Take out the inks, remove the printhead, put back the printhead make sure it will snap and you hear a click, put the inks back, wait for the printer to initialize, Press the Menu button, look for Calibrate printer, then print calibration page, then scan it after. Load a regular paper. Then try to print a demo page by pressing Photo and Copy at the same for 5 seconds then let it go. If same problem persist call this no for further assistance 1800 421 6699
Thanks
Aug 24, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Just replaced my black ink but printed page comes out blank
Change your print preferences to black and white as a work-around until you get color.
Aug 10, 2009 | HP PhotoSmart 7660 InkJet Printer
Put in new ink and it is telling me out of ink and will not let me print anythings.. How do you reset ink
Simple oly when you know how ;-)
I think you have a slight blockage, to solve:- (dont know which printer or PCyou have so ill do my best)
Click on Start
All programms
Pick your printer from the list
Open the software
You will have 2,3 or 4 options depending on your printer spec.
You need to 1st remove the cartridge
Print 1 page with no INK a message will pop up saying con not print need ink for example.
You then NEED to calibrate your cartridge, you need to find:-
1 Align Cartridge/Nozzle - Unblocks, and Sets up. (Syncronize)
2 Calibrate Black - unblock black
2 Calibrate Colour - unblock colours
3 Print test Page - See how it looks
5 Align again - Unblocks everything giving good ink flow and gets the print right close to 100%
6 print test page!
It shoud now work ;-)
Good Luck xxx
Jul 15, 2009 | Canon Pixma MP480 All-In-One InkJet...
Printing Both Sides with LBP5100
my Cannon lpb 5100 colours are out of allignment (black OK) - error is "out of Register colours correction"
NOt sure how to solve this problem - calibration does not work?
Oct 12, 2007 | Canon LBP 1120 Laser Printer
258 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
