Question about Bushwacker Utv Polaris Ranger 400 / 500 Full Cab Enclosure With Lexan Windshield
Polaris ranger 400 having fuel problems
When trying to accelerate it spits and sputters
Why is my 1989 Polarus ranger 500 spitting,coughing and backfireing thew the carb
shorting ignition circuit , bad coil , valve stuck open , burnt valve , fuel /air ratio wrong
Feb 13, 2017 | Polaris ATV
Why does my 1997 chevy k1500 with a 350 vortex sputters when i accelerate?
Can I suggest your timing is out or your plug leads are not connected in the correct sequence.
Aug 04, 2014 | Chevrolet 1997 Chevrolet K1500 1500 4WD
Speraticly keep losing a cylnder and when it does it really loads up on fuel spits and sputters dies and blows white smoke
White Smoke -- is Coolant & a Bad Head Gasket
Do a Cylinder Leak Down Test & a Combustion
Leak Test
Nov 26, 2012 | 1987 Ford Ranger
When advancing down highway vehecle spits and sputters then clears up then spits and sputters what is it
When was last tune up? Plugs, wires, all filters & fluids? Especially fuel filter. I'd start there and run a good fuel system cleaner through it.
Mar 15, 2011 | 1988 Ford Ranger
I have a 2006 Polaris Ranger. When driving sometimes at a comstant speed the Polaris feels like it is flooding out(starts sputtering). Can I use some type of additive in the fuel to help clear this...
i use gumout in my brute force 750 FI and have not had any problems,also check your plugs and carb.adjustment (if you have) as for gumout adjust amount you use to amount of gas.
Jan 24, 2011 | Polaris ATV
Van Sputters And Loses All Power When I Accelerate
Internal combustion engines requires 3 things... fuel, air, and spark. You do not have enough of one or more of these. If the wires and plugs are old, change them.  Air filter, same thing.  Fuel filter can also clog up with stuff after awhile. When you take a look at the air filter check where the air comes from.  It is possible a little critter has built a home and blocked the air flow (rare, but, it has happened).
May 07, 2009 | 1993 Plymouth Voyager
85 ford ranger 2.8 v6
Try replacing the ignition module in the distributor. This is a common problem on these engines.
Jun 16, 2008 | 1985 Ford Ranger
Bushwacker Utv Polaris Ranger 400 / 500 Full Cab Enclosure With Lexan Windshield Logo
46 people viewed this question
Top Bushwacker Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Bushwacker Tool and Hardware - Other Expert? Answer questions, earn points and help others
