Question about Sony Handycam DCR-TRV70 Mini DV Digital Camcorder
Menu how to operate menu
  • Anonymous Dec 05, 2008
    How do i change the language?
Sony Handycam DCR-TRV70 problem
Is there any other software/way to translate the language of my Camera from Chinese to English Version. The Sony DCR-TRV70 Mini DV Camera appear in Chinese Language.
I can't read this and I want it to transfer to english.
and User Manual of this Products.
This camera was brought from japan with my wife and I can't read anything because of the chinese language
Posted on Nov 23, 2008
SOURCE:
I have a taylor ice cream machine thats keeps a constant beep even when ice cream is ready model 339-27
I'm not 100% on this model but here goes....
A "beeping" tone will sound to alert you
of a fault.
To discontinue the tone, access the Operator
Menu and enter Option B. Correct the fault, then press
the OFF (<--) key, and the tone will stop.
FYI Fault Description
(Option B)
This option lists any faults detected by the control and
allows the operator to clear them from the system.
When a fault is detected it will be displayed on the
second line of the LCD. Pressing the MENU/SEL key
will display the next fault found or return the display to
the Operator Menu if no additional faults exist. If the
OFF key is pressed when a fault is displayed, all faults
that have been corrected will be cleared from the LCD
upon returning to the Operator Menu. To return to the
Operator Menu, press the MENU/SEL key.
for 337.....
Screen display.....
The POWER SWITCH OFF screen indicates that the
power switch is in the OFF position.
POWER SWITCH OFF
The normal operating screen will display the current
mode of operation and the level of mix in each mix
hopper. (The power switch is in the ON position.)
MODE: OFF
MIX:
L = OK
Operator Menu
_________________________________
The Operator Menu allows the operator to access
operational information and to set non-critical
functional parameters. The Operator Menu also allows
access to the Service Menu. (Note: Only service
technicians who know the access code may use the
Service Menu.)
Operator Options
A
Exit From Menu
B
Fault Description
C
System Information
D
Current Conditions
E
Service Menu
Pressing the OFF (<--) key will move the cursor one
position to the left. Pressing the STBY (-->) key will
move the cursor one position to the right. Both keys
include the "wraparound" feature. This means that
when the cursor reaches the end of the option, any
further movement in the same direction causes the
cursor to "wraparound" (to be placed at the opposite
end of the option listing)
here's the manual if you don't have it....
http://www.taylorfreezersales.com/op_man/0337op0.pdf
Best to you hope this helps a little
Mar 05, 2018 | Taylor Ice Cream Makers
How do I reinstall Windows 7 if I don't have a disk and my Acer laptop won't boot?
turn off reboot hit f8 till you see menu, go to restore on the menu should be a menu to restore to factory settings
try booting to safe mode hit f5 till you see menu
with command prompt type bootrec /fixmbr then the enter key type bootrec /fixboot and enter key reboot
Jul 07, 2015 | Microsoft Windows 7 Home Premium 64BIT...
Change font size on HP laptop
In the Start menu go into the Control Panel menu and select Appearance and Themes menu and there you can change the font size of the text.
Feb 06, 2012 | Microsoft Windows 7 Home Premium 64BIT...
How do you finalize disc in a dc100
To finalize the disk:
Select MENU --> then select: DISC OPERATIONS then select: FINALIZE then select: YES ... to go back to MENU
During the disk finalization, a progress bar is displayed. Close the MENU only AFTER the screen display returns to the DISC OPERATIONS menu
Feb 26, 2011 | Canon DC100 DVD Camcorder
Change my aficioDSM635 language
A. Press the {User Tools/Counter} key.
The User Tools main menu appears.
Note
? When the key operator code is set, the key operator code input
display appears when changing the default settings. Enter the
registered key operator code beforehand.
For key operator codes , see "Key Operator Tools", General Settings Guide.
B. Press [Copier/Document Server Features].
The Copier/Document Server Features menu appears.
C. Select the menu you want to set.
The setting display for each menu appears.
Reference p.83 "User Tools Menu (Copier/Document Server Features)"
D. Change settings by following the instructions on the display panel,
and then press [OK].
Exiting User Tools
A. After changing default settings, press [Exit] on the User Tools main menu.
Changes to User Tools are complete, and the machine is ready to copy.
Note
? You can also exit User Tools by
pressing the {User Tools/Counter}
key
Dec 17, 2010 | Office Equipment & Supplies
Print test
Step Press Displayed Result Notes
1. Install the ribbon, load paper, and power on the printer.
2. NOT READY Printer must be in NOT
READY mode to access
the tests.
3. OPERATOR MENU
UNLOCKED
Unlocking ENTER key
allows you to test the
printer.
4. OPERATOR MENU
PRINTER CONTROL
First of series of
configuration menus.
5. OPERATOR MENU
OPERATOR PRINT TESTS
Advances to the Operator
Printer Tests menu.
6. OPERATOR PRINT TESTS
PRINTER DEMONSTRATION*
Advances to first option in
Operator Printer Tests
menu.
7. OPERATOR PRINT TESTS
[TEST NAME]
Cycles through list of
tests. Stop when your test
displays.
8. OPERATOR PRINT TESTS
[TEST NAME]
The test you selected
starts printing.
9. NOT READY The printer test stops
printing.
Stop
Scroll­ + Scroll¯
Menu
Scroll­ UNTIL
Enter
Scroll­ UNTIL
Enter
Stop
Let me know if you need any other help with this. I carry all parts and refurbished units and offer free techincal support as long as the parts ordered thru us.
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 X240
[email protected]
Jun 24, 2009 | IBM 6400-I2S Matrix Printer
How can I get boot menu
Click on START, SETTINGS, CONTROL PANEL, SYSTEM. Click on ADVANCED, SYSTEM STARTUP AND RECOVERY, SETTINGS. Make sure TIME TO DISPLAY LIST OF OPERATING SYSTEMS are checked and put the number of seconds there. Click on OK and you should be good to go.
Jul 25, 2008 | Computers & Internet
Wharfedale lcd2010a
The TV is Manufactured by a company called Vestel in Turkey and will operate on the AK45 chassis remote control,if you try the codes for Bush or Alba one will operate it nut not of course menu functions but no problem there is a menu button on the side of the set.
[email protected]
Apr 18, 2008 | Televison & Video
Recording
The EDSR1600 will not go into manual recording mode (by pressing the REC button on the front panel) unless all of the automatic modes are disabled and the hard drive bays are firmly pressed in and locked. Press the MENU button, select ALARM and turn everything in the OPeration column to OFF. Return to the MENU, select MOTION and also turn set all the OPerations to OFF. Return again to the main MENU and under RECORD, set ALARM RECORD OPERATION to OFF, PRE-ALARM RECORD OPERATION to OFF, and PERMANENT RECORD OPERATION to OFF. Note: Turn the JOG wheel clockwise or counter-clockwise to select an option. Press the ENTER button to confirm the option and move to the next field. Press the MENU button to enter, or return to the main MENU. Press the MENU button twice to exit the main MENU. To check if the round key locks on the front of the Hard Drive bay trays are locked, turn OFF the EDSR1600. Open (pull down) the left side front cover and gently pull up on the drive bay handles. If locked, the handles should not lift and the bays should not slide out. After your check, press the bays in firmly to ensure good seating of the Hard Drives. The ESDR1600 should now go into manual RECord if the DVR is working properly. The red REC LED should also light each time a recording is being made. If the REC LED flashes, this means the DVR is recording a field or frame of video.
Jan 26, 2007 | EverFocus EDSR1600 16 CHANNEL 160GB...
Problem recording
Jan 26, 2007 | EverFocus EDSR1600/500
Sony Handycam DCR-TRV70 Mini DV Digital Camcorder Logo
350 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
