I have a customer who has a Warm Morning direct vent propane heater: model DV.203 AMA. His complaint is the thermostat does not seem to work properly. The dial is turned to the lowest setting and it maintains 60 degrees. Is that the lowest it will go or is there something wrong with his thermostat?
    Top Expert:
  • Heating & Co... Master
  • 35,737 Answers
Some thermostats have a default lower limit such as 60 degrees to prevent complete loss of heating. The lower limit is not set by the user.
Posted on Nov 19, 2013
  • Marc Jolma Nov 19, 2013
    Thanks for the reply. It seems to be working fine, my customer was just hoping he could have it a little cooler for when they're not there. Thanks again.
Buffalo12980
  • 625 Answers
SOURCE: Can someone please tell me what is the lowest temperature setting a Fahrenheat 3000 Watt Large Room Fan-Forced Wall Heater Model FZL3004 will turn on at ?
about the only way I can figure is to let the room get very cool and adjust the thermostat to its lowest setting. now turn on the unit. monitor the heat until the stat just opens. the thermostat bimetal will be closed and will open when the bimetal expands and opens its contacts. another way is to hitch up a chart recorder to measure temperature with its output connected to the heater. [too expensive for you or the DIY to accomplish]
Posted on Dec 14, 2007
  • 41 Answers
SOURCE: Endless Summer Patio Heaters won't stay lit
Hi ColdinSF,
You need to remove the covers from the unit and blow out the gas lines with compressed air. If you can remove the gas lines blow out the lines and what they connect to like the pilot light and main feed line to the burner. Usually they gunk up with use and just need to be blown out with compressed air to clear the lines again. Maybe you have some dirt or foreign object from your gas tank which has clogged the line. Also check the igniter electric lines as well and make sure everything is connected properly. Especially make sure you tighten the gas lines you remove. Hope this helps.
Regards
Bryan
Posted on Dec 22, 2007
  • 14 Answers
SOURCE: The heater will not ignite properly and the heater will not shut off
Judging by your pics (helpful, by the way) you have a high limit wired into your thermostat wire. Try disconnecting that wire nut connection in front of your valve and hooking the thermostat straight to the top and bottom posts on the valve (eliminating the high limit). If it runs fine, either the connection was poor or your high limit wire is pinched.
Posted on Feb 28, 2008
SOURCE: Rinnai rce-606tra II -- temperature is wrong
move thermister probe higher on back of unit
Posted on Mar 10, 2008
SOURCE: Comfort Glow Vent-free Gas Heater CGN18B
Check with Ebay seller s.a.w.inc for available thermocouples. If that doesn't solve the problem the valve unit will likely need replaced.
Posted on Feb 13, 2009
I have a GloWarm propane/lp gas space heater. Can I use bottled propane tanks?
no you can't, and aren't you worried about carbon monoxide poisoning? Where does the burnt air go?
GloWarm Heaters - ventfree infrared heaters
GloWarm Infrared heaters are residential gas space heaters that are ventfree,
so no venting is required
GloWarm Plaque Infrared heaters direct heat from radiant plaques that
"warm like the sun."
Infrared heaters heat objects in the room before the air,
making them ideal for un-insulated rooms in your home.
All propane heaters require a 100 lb. tank or larger!
GloWarm Heaters ventfree infrared heaters
Oct 27, 2015 | Heating & Cooling
Empire dv210 thermopile
600 millivolts is needed for the thermoplie to work
Jan 27, 2013 | Empire DV-215 Direct Vent Natural Gas...
My father died 11 years ago and he bought a Glo-Warm Vented heater for propane gas only. It has never been used as we found it still in its box in an old attack. Can I use this to our natural gas system?...
check on line google make modle serial number btus etc and ask for nat gas converstion kit , age could be the problem here ,or try national energy they are on line or google the makes and ask them direct
Mar 27, 2011 | Heating & Cooling
I have a DV-55 direct vent... Blower kicks on for about 30 sec after it lights then goes of and continues to cycle this way then finally stays on
That is normal...especially if the air is pretty cool when it starts... the air cools the heat exchanger too much and it cycles till everything gets warm... nothing to worry about.. :-)
heatman101
Jan 15, 2011 | Empire Direct Vent Wall Furnace;...
My dv-215 direct vent propane unit thermostat is no working right. The burner will not lite until I push down on the mechanism inside the thermostat the burner will shut off when I move the mechanism to...
You need to replace the thermostat if you have to force the contacts to close.
Make sure you get the right type of stat. It appears this is a thermopile millivolt type, as opposed to a standard thermocouple. The stats are not interchangeable.
I noted stats were available at Sears, but there I am sure there are other sources to purchase from.
Dec 18, 2009 | Empire DV-215 Direct Vent Natural Gas...
How to change gas orfice to propane glass smokes up. soot
Is this unit originally set up for natural gas? If so, the burner oriface and the gas valve need to be retro-fitted to propane. This is something only a qualified service technician should attempt as an incorrect retro-fit could cause an explosion resulting in someone getting hurt or even killed.
Nov 09, 2009 | Empire Hight Efficient Direct Vent Wall...
How to change the orfis from propane to gas on a empire 40,000btu
what is the model # for the furnace. You are going to have to change the pilot orofice and gas valve for natural gas also.
Oct 30, 2009 | Empire Hight Efficient Direct Vent Wall...
Light soot around propane fireplace vent
burners burning yellow , in complete combustion , blocked air ways to burner , it needs a service soon as poss
Dec 22, 2008 | Empire DV-215 Direct Vent Natural Gas...
Heating & Cooling Logo
125 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
