Question about Sewing Machines
Fitting spring for bobbin winder on er classic sc12 sewing machine
SOURCE: Kenmore Sewing Machine model # c877.15
I have an old Kenmore and here are the directions from my manual: 1. Draw thread from spool through bobbin winder tension discs. 2. Wind thread around an empty bobbin several times. 3. Place bobbin onto bobbin winder shaft with thread coming from rear of bobbin. Push bobbin winder latch against bobbin until it clicks. 4. Release clutch by turning clutch knob toward you. Start machine.
Posted on Aug 09, 2007
RickE1
  • 202 Answers
SOURCE: Bobbin winder will not turn..
Without knowing what type of machine you have its hard to determine if the problem is mechanical or electronic. If the bobbinwinder has its own motor than its probably electronic and it could be a bad motor or circuitboard. Sounds like this could be it.
The minimum service charge could be about 50.00 but this won't include the more expensive part. You might look up Sidewinder bobbinwinders which is a small separate unit you can purchase in most fabric stores or online for about 20.00 and just wind bobbins separate from the machine.
Good luck.
Posted on Dec 20, 2008
  • 16 Answers
SOURCE: Bobbin winder will not spin on sewing machine
If you take the top off you will see a tiny rubber tire that engages the winder to the handwheel. Over time they get really soft are really hard and disintgrate. If you have a local sewing shop take the old one in and get a new one to slip on it takes only a few minutes and cost usually less that $2.00
Posted on Jan 22, 2010
  • 371 Answers
SOURCE: sewing machine husqvarna 3610 bobbin
You probably will need to replace the bobbin case. It is probably only available from Husqvarna Viking. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
caroldon
  • 17129 Answers
SOURCE: bobbin winder won't spin Cannot load bobbin
Can be dirt or particles that have made it stuck with friction and so a resetting /overhauling with good oiling, degresing will resolve the matter, provided there is wearing off in the drive.
First use a degreasing spray before you can disemble.
Posted on Sep 30, 2010
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
Runs fine until bobbin winder is engaged, then won't run. as if there is no power.
If the bobbin winder is malfunctioning, for ~$30, you can purchase a stand-alone bobbin winder at JoAnn's or Hancock's fabric stores or online, ie Amazon. At least you will still be able to use your machine even if the bobbin winder on your machine will not work.
Dec 23, 2015 | Simplicity Quilter's Classic SW240...
Sewing machine stops sewing
what type of sewing machine do you have, and have you tried turning it off, then switching back to the sewing position. you may need service, or an external bobbin winder.
Nov 18, 2014 | Sewing Machines
Bobbin winder won't spin
i have the same problem ,its the o ring on the inside of the machine on bobbin winder , i purchased the o ring from brother for 27 pence i just need to know if its safe for me to open the machine without lots of springs popping out xx
Apr 07, 2014 | Brother XL-2230 Mechanical Sewing Machine
Need bobbin winding ring for Sears Kenmore model # 148.12140, no longer avail at parts online. Is this ring available anywhere else?
part number 1939 Looks like a normal bobbin winder friction ring. Try sew classic. they have some generic ones in a few different sizes. (btw.... looks like a Janome one might fit, but I didn't find it)
http://shop.sew-classic.com/Bobbin-Winder-Parts-Rings-Tires_c16.htm
Aug 29, 2012 | Sewing Machines
The rubber part of the bobbin winder is worn and needs replacement.
The bobbin winder rubber is a standard size for all machines and providing you an get to the winder it is easy to fit
Aug 13, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
Can't put a bobbin on the winder Husqvana Viking 6020
Is this a Designer 1 or a #1? There is no moving lever on the pin of a Deigner 1,they are fixed. If it's a #1, use sewing machine oil or Triflow. NEVER use 3 in 1 oil. It will gum up and cause problems later on.
Aug 31, 2009 | Husqvarna Viking 1
Viking sewing machine 545 bobbin stuck on rewind
It should just pull off of the winder shaft. There is a small spring that sticks out from the shaft to hold the bobbin in place (at least on my wife's Viking which is a different model number than yours). Is there a release button somewhere near?
Jul 17, 2009 | Singer CE-100 Futura Computerized Sewing...
How to fix bobbin winding
. Put the spring on the hole that the bobbin winder fits into. Now put the bobbin winder in, but don't tighten the screw- just turn it once or twice. Put the straight projection of the spring on the right side of the bobbin winder. Start to tighten the screw. Before you get the screw too tight, pull the downward projecting side of the spring over the housing of the machine so that it is pressing on the inside of the machine creating a push to the left. Center the circular part of the spring underneath the screw and the bobbin winder and tighten up.
Jul 15, 2009 | Euro-Pro 473
I need an instruction manual for the Babylock Pro II Model B15
hi!there similar bobbins winder in any brand of sewing machine uses mostly in domestic particularly in industrial manufacturing in this fig.check it out if similar to your bobbins any how itmay be he86acf3a.jpglpfull onethe bobbins winder that was a thread and shoul be clockwise rotation when coming out to bobbins case,if you to wound the thread on your bobbins winder, pull threads on spool then wind this in several times 4 to 6 rotation clockwise loop thread on top machine there is bobbins winder disc for tension put winder bobbins on shaft winder near hand wheel push the latch against bobbins winder to fit thead run machine to wind the thread.After hread wound in bobbins winder cut thread and insert winder to bobbin case as shown.
insert bobbins to shuttle hook case under needle foot holder
lift the cover plate you can see under this is the shuttle hooke415486.jpgafter set up was made on bobbins thread,set also the upper loop thead beginning at top of machine start on spool, pull thread and loop to upper disc tension then to the slot portion as in figure
insert on lever dial goes to the needle adjust tension to #8 range to #12 for cotton fabrics two layer sewing.
Mar 17, 2009 | Baby Lock Sewing Machines
Sewing Machines Logo
15 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
