Question about Canon Pixma MG5220 InkJet Printer
Magenta ink tube disconnect Canon MG5220
Head checked out on similar printer. Something going on with magenta ink pump tube
  • 12 Answers
SOURCE: iP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Posted on Jan 21, 2009
pineworks
  • 4041 Answers
SOURCE: service error 6A00 in my canon ip 5200 printer. what should i do
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
  • 39 Answers
SOURCE: My Canon MP145 is not printing Magenta color.
USE ONLY ON PLAIN PAPER , STANDARD QUALITY.
Posted on Jul 25, 2010
SOURCE: I have a canon MG5220 printer and unable to scan
Regarding the Cannon scanner error 2145,50. I note you have tried to fix this, but failed. The actual problem is that the scanner will not communicate with the computer correctly if it is connected through a USB hub. A direct connection to the computer cures it.
I know, I had that problem. I am a retired elctronics design engineer.
Posted on Oct 14, 2011
I have a Canon I9950 printer it started playing up and despite head cleaning in warm water etc as recommended still did not print all the colours. I bought a new print head and new canon inks (always used...
I would check to make sure that the contacts on the cartridgew sensors are not fouled with dried ink. A q-tip with rubbing alcohol should help to remove the dried ink if that is in fact the problem.
Oct 19, 2013 | Office Equipment & Supplies
Canon mg5220 printer won't print black
Try this: take a small, sharp knife and make sure the air slit on the top of the cartridge goes all the way through the plastic.
You know that little tab you have pull off the top of the cartridge before inserting in the print head? There is a tiny slit under the tab to let air in, which is necessary to let the ink flow out. The slit is made very small so ink won't leak inadvertently out the top. Sometimes the slit doesn't go all the way through the plastic. When that happens, the ink can't flow.
I blew through that slit on a defective cartridge and no ink came out. I used a pen knife to open the slit (it doesn't take much) and then blew again. This time ink spewed out the bottom. My print test showed the black ink coming through. It was a bit spotty so I cleaned the print head and now the black ink comes out just like its supposed to.
Mar 13, 2012 | Canon Pixma MG5220 InkJet Printer
HP Designjet 110 inconsistent printing of magenta
>Check ISS pumping, >Check ISS tubes is there air gap?>Check cartridge bag broken in side?>Check for leakage at cartridge bank & carriage assm.>Do the following force priming to fil ink in tubes as well as in print heads:****Hold the power button down and press the cancel button three times and the resume button three times.****Switch Off the printer and then On again in order to start the priming of the ink supply tubes.
Jan 04, 2012 | HP DesignJet 110 Plus NR InkJet Printer
The color ink cartridge that is " blinking " is
Don't buy Canon as they absolutely ROB you for the ink!! They are worse than ****** dealers! At least HP allows you to use non (rip-off) OEM cartridges without all the hassle! My printer will be thrown out after the ink runs out as I will not be ripped-off by Canon again!
Apr 30, 2011 | Canon Pixma MG5220 InkJet Printer
Cannot get the magenta ink tank to flow in a Cannon Pixma 4500
Yes, you can take the printing head out  and soak it up in hot water. You can even blow some air on it, this will dislodge even the nastiest dried ink gunk. If even after that the head doesn't work then it's dead - buy a new printer.
Jul 11, 2010 | Canon Office Equipment & Supplies
Magenta ink wont print
If everything else is working, except for Magenta toner; replace toner with a new one.
Jun 21, 2010 | Canon imagePROGRAF W8400 InkJet Printer
Canon i9950 prints green on photo paper
I had the same problem. Having checked other websites I came across the following which narrowed down the problem to the Photo Cyan / Photo Magenta ink tanks, and replacing the Photo Magenta one (although it was not empty) has successfully resolved the problem. Eveidently ink from the original one was not flowing and so caused the syan cast. (I experimented by subsequently removing the Cyan one which produced prints with Magenta cast)
TEXT OF POST I FOUND:-
That post is labeled "Cannon (sic) S9000 Print Head" and concerns a greenish hue error in all print quality levels OTHER THAN plain paper. In other words, all output designated as Photo Paper Pro, Glossy, High Resolution Paper, etc., results in output with enormous and unacceptable levels of green hue. All output designated as "Plain Paper" whether the output actually is on plain paper or photo paper pro, turns out well.
This problem is not unique to the S9000, as I experienced it identically with the S820 and predictably can occur in any printer with the six cartridge print head.
It is a frustrating problem because you know that the printer is physically capable of printing WITHOUT the hue (as it proves to you each time you choose a "plain paper" paper setting.)
Troubleshooting by reinstalling and updating the printer drivers, and uninstalling/reinstalling the ZoomBrowser EX, replacing the ink cartridges, and deep cleaning are all blind alleys.
A call to Canon support solved the problem for me with this simple and important revelation:
The Plain Paper setting is unique in its use of only 4 of the 6 cartridges. In the Plain Paper setting, only the black, cyan, magenta and yellow cartridges are utilized. The Photo Magenta and Photo Cyan are not utilized. In all higher resolution settings, i.e., in all other settings, all 6 cartridges are utilized.
It follows that if one's problem disappears when not using these two Photo cartridges (i.e., when printing at the Plain Paper setting), then the problem lies with these cartridges.
(In my case, I'd loaded a plain "Cyan" cartridge in the "Photo Cyan" slot during earlier trouble shooting and had forgotten to replace it with the proper Photo Cyan cartridge.)
Problems with magenta hues would admit of the same solution.
Hope that helps anyone else out there tearing out their hair trying to troubleshoot this. "
Dec 10, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Canon Pixma MG5220 InkJet Printer Logo
29 people viewed this question
old marine
old marine
