Question about Acer AL1916W 19" LCD Monitor
GForce 6600 vs 7600 GS on Acer al1916w
I have 2 computers, the older one has a Gforce 6600 and the newer one the 7600 GS. Both are running on Acer 19" wide screens. I'm a photographer and it's crucial that both sreens took the same. The thing is the older screencard displays the photos perfectly. On the new PC the photos has harsh colours and it just doesn't look right. I've tried a few callibration utilities, but none of them can fix my problem. Do I really need to go a and spend money on a calibration spider?
  • Anonymous Apr 23, 2008
    Thanks Jemmyrash. I found the problem to be the motherboard, not the screen card. I removed the screen card and used the onboard display card. Same thing. This was a bloody expencive PC. So I saving to buy the Spider 3 Pro. Since I'm a photographer, I should come in handy anyway.
You are welcome.
Posted on Apr 23, 2008
  • 180 Answers
Try to change the monitor . The monitor with GS 6600 plug it out. Then unplug the monitor attached at the GS 7600 and plug it into gs 6600 and see the result.
If it is ok now. Then it you must to troubleshoot with the GS7600
display card.
Posted on Apr 19, 2008
SOURCE:
Need to know what 2 wires to hook this gforce chip
The Gforce chip on a gas engine hooks into the AIT, and there is only 2 wires. I'm not sure about the Cummins, but there is a very good website for GForce, and you can probably find out from there.
Sep 14, 2014 | Cars & Trucks
Fitting a Gforce video card in a veriton 5700GX
Your restrictions are based on available slot size and version. So get one that fits PCI-e x16.
Could not locate PCI version so check your manual, because the slots are backward compatible. Meaning you can connect a Ver 1 card into a Ver 3 slot, but not the other way around.
Expansion Slots - 1x PCI-e x16 slot, 1x PCI-e x1, 2 x PCI slots
Dec 11, 2012 | Computers & Internet
I have acer aspire 5920G, when i instaled windows 7 64bit i instaled drivers for vista 64bit from acer and for the gforce card from the site of the gforce for windows 7 64bit, the problem is that my screen...
the drivers might be clashing with one another. note that if you use windows vista, it comes mostly pre installed with most basic drivers, thus try to uninstall the one from gforce by giong to your control panel-system-device manager-drivers. i am sure you screen will be ok to tell you that its drivers were interfered with.
if this is not the case, please post a comment and i will try to find a best alternative for you problem.
thank you,
wonder
Sep 22, 2009 | Acer Aspire 5920-6727 Notebook
GFORCE 6 SERIES QUIT CAN IT BE REPAIRED ?
Unfortunately you have a couple of problems #1 finding someone to repair it, #2 the cost involved if you could. You are better off trying to buy a used or old stock one off EBAY.
Mar 23, 2009 | Nvidia GFORCE FX5700LE 256DDR WITH TV+DVI...
RE: UPGRADE THE GRAPHICS CARD
Hi there.
Yes your machine should and will support that graphics card and higher.
Here is a link to tech specs on the Gforce 8400 >>>>>>>>>
http://www.nvidia.com/object/geforce_8400_tech_specs.html
You can get this card or one thats higher specs if you like but the Gforce 8400 is a very good card and i think you will like it.
Have fun and thanks for using FixYa!!
Mar 23, 2009 | Acer Aspire™ T180 PC Desktop
MSI K8N --Compatible video card
Get another GForce video card a later model with at least 256Mb of memory. If you play games you might want a higher spec GForce video card.
Mar 15, 2009 | MSI K8N Neo4-F Motherboard
New wide screen monitor incompatibility issues with older comp
The two cards(Gforce Nvidia card) might not be compatible for your motherboard because they're for heavy graphics like playing games, and *********** board is old that you;ve mentioned. including the message memory range unavailable. Try using your old card with the new monitor.
Nov 25, 2008 | Computers & Internet
I have a e-GeF0rce 8600 GTS. My computer sees a NVIDIA GeForce 6150SE N FORCE 430.0. iS THIS A PROBLEM
Hello Baldarchi,
This is normal and how ever uninstall the current driver and install latest driver from the following link:
http://cid-3a2fd42defd10b67.skydrive.live.com/self.aspx/Public/Nvidea%20video%20driver.exe
The above driver supports:
[DEV_0098] NVIDIA GeForce Go 7800 [DEV_0099] NVIDIA GeForce Go 7800 GTX [DEV_00C8] NVIDIA GeForce Go 6800 [DEV_00C9] NVIDIA GeForce Go 6800 Ultra [DEV_00CC] NVIDIA Quadro FX Go1400 [DEV_0144] NVIDIA GeForce Go 6600 [DEV_0146] NVIDIA GeForce Go 6600 TE/6200 TE [DEV_0148] NVIDIA GeForce Go 6600 [DEV_0149] NVIDIA GeForce Go 6600 GT [DEV_0164] NVIDIA GeForce Go 6200 [DEV_0166] NVIDIA GeForce Go 6400 [DEV_0167] NVIDIA GeForce Go 6200 [DEV_0168] NVIDIA GeForce Go 6400 [DEV_01D4] NVIDIA GeForce Go 7350 [DEV_01D6] NVIDIA GeForce Go 7200 [DEV_01D7] NVIDIA GeForce Go 7300 [DEV_01D8&SUBSYS_81E6104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_81EF104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_81FD104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_8205104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_820F104D] NVIDIA GeForce Go 7400 [DEV_01D8] NVIDIA GeForce Go 7400 [DEV_01DA] NVIDIA Quadro NVS 110M [DEV_01DB] NVIDIA Quadro NVS 120M [DEV_01DC] NVIDIA Quadro FX 350M [DEV_0244] NVIDIA GeForce Go 6150 [DEV_0247] NVIDIA GeForce Go 6100 [DEV_0297] NVIDIA GeForce Go 7950 GTX [DEV_0298] NVIDIA GeForce Go 7900 GS [DEV_0299&SUBSYS_309F103C] NVIDIA Quadro NVS 510M [DEV_0299] NVIDIA GeForce Go 7900 GTX [DEV_029A] NVIDIA Quadro FX 2500M [DEV_029B&SUBSYS_309F103C] NVIDIA Quadro FX 1500M [DEV_029B] NVIDIA Quadro FX 1500M [DEV_029D] NVIDIA Quadro FX 3500 [DEV_0397] NVIDIA GeForce Go 7700 [DEV_0398&SUBSYS_81EF104D] NVIDIA GeForce Go 7600 [DEV_0398&SUBSYS_81FD104D] NVIDIA GeForce Go 7600 [DEV_0398&SUBSYS_8205104D] NVIDIA GeForce Go 7600 [DEV_0398] NVIDIA GeForce Go 7600 [DEV_0399&SUBSYS_81FD104D] NVIDIA GeForce Go 7600 GT [DEV_0399&SUBSYS_8205104D] NVIDIA GeForce Go 7600 GT [DEV_0399] NVIDIA GeForce Go 7600 GT [DEV_039A] NVIDIA Quadro NVS 300M [DEV_039B] NVIDIA GeForce Go 7900 SE [DEV_0407&SUBSYS_01F11028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_01F21028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_02281028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_02291028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_022E1028] NVIDIA GeForce 8600M GT [DEV_0407] NVIDIA GeForce 8600M GT [DEV_0408] NVIDIA GeForce 8600M GTS [DEV_0409&SUBSYS_019B1028] NVIDIA GeForce 8700M GT [DEV_0409&SUBSYS_019C1028] NVIDIA GeForce 8700M GT [DEV_0409] NVIDIA GeForce 8700M GT [DEV_040B&SUBSYS_30C3103C] NVIDIA Quadro NVS 320M [DEV_040B] NVIDIA Quadro NVS 320M [DEV_040C&SUBSYS_20D917AA] NVIDIA Quadro FX 570M [DEV_040C&SUBSYS_30C5103C] NVIDIA Quadro FX 570M [DEV_040C] NVIDIA Quadro FX 570M [DEV_040D&SUBSYS_019B1028] NVIDIA Quadro FX 1600M [DEV_040D&SUBSYS_30C3103C] NVIDIA Quadro FX 1600M [DEV_040D] NVIDIA Quadro FX 1600M [DEV_0425] NVIDIA GeForce 8600M GS [DEV_0426] NVIDIA GeForce 8400M GT [DEV_0427&SUBSYS_01F11028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_01F21028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_01F31028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02091028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02271028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02281028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02291028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_022E1028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_9008104D] NVIDIA GeForce 8400M GS [DEV_0427] NVIDIA GeForce 8400M GS [DEV_0428&SUBSYS_9008104D] NVIDIA GeForce 8400M G [DEV_0428] NVIDIA GeForce 8400M G [DEV_0429&SUBSYS_01FE1028] NVIDIA Quadro NVS 140M [DEV_0429&SUBSYS_20D817AA] NVIDIA Quadro NVS 140M [DEV_0429] NVIDIA Quadro NVS 140M [DEV_042A] NVIDIA Quadro NVS 130M [DEV_042B&SUBSYS_01F91028] NVIDIA Quadro NVS 135M [DEV_042B&SUBSYS_01FE1028] NVIDIA Quadro NVS 135M [DEV_042B] NVIDIA Quadro NVS 135M [DEV_042D&SUBSYS_01FF1028] NVIDIA Quadro FX 360M [DEV_042D&SUBSYS_024A1028] NVIDIA Quadro FX 360M [DEV_042D&SUBSYS_024B1028] NVIDIA Quadro FX 360M [DEV_042D] NVIDIA Quadro FX 360M [DEV_0530] NVIDIA GeForce 7190M / nForce 650M [DEV_0531] NVIDIA GeForce 7150M / nForce 630M [DEV_0532] NVIDIA MCP67M [DEV_0533] NVIDIA GeForce 7000M / nForce 610M [DEV_053F] NVIDIA MCP67M
Sep 12, 2008 | Computers & Internet
Rhem 2 graphic card
the red x popps up and game freezes on Rhem 2.
May 08, 2008 | Computers & Internet
Video card
actually your computer is working on the onboard video adapter.
1. connect first the monitor to the onboard video card.( do not remove the connected geforce video card.)
2. switch on the computer and press "F2" on new model computer, "Delete" on old model computer.
so that you can enter to bios setup.
3. if bios setup is open; try to find the "AGP bridge configuration"
(some other bios AGP B C is in chipset) by arrow up,down,side left and right) enter.
4. Find " primary graphics adapter"
5. In there, select : If Video card is "pci" connected ; select "pci"
If Video card is "AGP" connected ; select "AGP"
6. press F10 to save and exit the setup.
7. after saving the configuration, disconnect power cord and transfer the monitor to the video card (Gforce). and then connect the ac power cord and then start. or switch on the computer.
Note: be sure to install the drivers of your GFORCE for optimum performance of the card.
hope this help.
Dec 21, 2007 | ASUS P4P800 SE (890552603657) Motherboard
Acer AL1916W 19" LCD Monitor Logo
151 people viewed this question
Ekse
Alun Cox
