Question about Alpine MRP-M1000 Car Audio Amplifier
Using a car batter charger to test my amp I only get a clicking noise.
Can I test an amp this way? It has 10amps.
    Problem Solver:
  • 18 Answers
YOUR AMP IS JUNK THEN.
I’m happy to assist further over the phone at https://www.6ya.com/expert/chris_ec38c09da1ae48dd
Posted on Nov 20, 2013
Wiring diagram for se4020 Schumacher batter charger all the wires are unhooked inside.
I can't find a manual for your charger, may have to get ahold of Schumacher to get the wiring diagram
Feb 09, 2018 | AMP Car Audio & Video
Does a B&D jump charger and inflator have a charging fuse 500 amp ?
Not to my knowledge, usually the charging fuse will be a low value in relation to the voltage output and the wattage. Maximum would be 10amps or so and the unit would charge all night to come up to charge.
Sep 06, 2017 | JUMP START SYSTEM
NI-MH D 14.4V 8000mAh Charger Hack. I need an alternative charger like charging on a car battery?
NI-MH batteries a re very different than car batteries and even tho voltage may be similar, you risk destroying your battery, camera or worse, an explosion. Your batter may only need a limited amount of amperage to charge (likely not much more than 1500ma or 1.5 amp) a car battery charger may put out twice or even ten times that much - hence the explosion risk! Also these kind of chargers detect when your battery is full and will quit charging or switch to a maintenance mode. I'm afraid you're pretty much stuck with using the charger meant for it.
May 08, 2016 | Cameras
Motor does not seem to work. sensor light does not come on. you hear a noise indicating the batteries are working
If you are hearing a loud "Clicking" noise when you turn the key it usually means the battery has some power but not enough cranking amps to start the car. Get a battery charger on it or take it somewhere and have the battery tested.
Jan 18, 2016 | Cars & Trucks
I turn ignition on lights and dash light up ,then press start button and only get a clicking noise ,the bike will not turn over.
Your batter is weak or defective. Try charging the battery with a small (1-2 Amp) battery charger overnight, or using jumper cables connect another 12 V battery and try starting the bike.
Oct 23, 2010 | BMW R 1200 GS Adventure Motorcycles
My acer extensa 5220 doesnt charge and there are nil lights showing. How do i test the battery adapter. Or please suggest other options to try.
Unless you have a voltmeter or multimeter, then you can only test your battery charger by removing your batter and try to start up your computer with only your charger plugged in. If it boots up, then the problem isn't likely to be with your batter charger, but with the battery itself. Sometimes an adapter will power up a latop but not charge the battery.
Jun 15, 2010 | Computers & Internet
I lost my manual for 97 mountaneer fusebox diagram
1. pwr antenna 7.5 amp 2. high mount stop lamp 7.5amp 3. lights 15 amp 4. left headlight 10 amps 5. data link connector 10 amps 6. airbag, blower motor relay 7.5 amps 7. lamp dimmer 7.5 amps 8. RH headlight, daytime running lts, fogs 10amps 9. autolamps, memory seat 10amps 10. blend door ( heater), shift lock actuator, cruise control, brake press limit, console, integrated contol panel, rear blower relay 7.5amp 11. radio, dimmer relay, inst cluster, autolamps 2 7.5 amp 12. liftgate wiper washer, front washer relay 10amps 13. brake on off switch 15 amps 14. antilock brakes 10amps 15. airbag diagnostic 7.5 amps 16. wiper main 30amps 17. cig lighter 25 amps 18. heater-a/c eatc module 15 amps 19. radio noise cap, ign coil, PCM power diode 25 amps 20. radio, powr ant 7.5 amps 21. turn /hazards 15 amps 22. turn hazards 10 amps 23. rear wiper relay, 10 amps 24. anti theft 10 amps 25. cluster 7.5 amps 26. rear window defrost, overdrive trans, backup lamps 10 amps 27. interior lighting 10 amps 28. GEM, mem seat 2 , 7.5 amp 29. radio CD changer 10amps 30. not used 31. rear blower relay, RH heated mirror, 7.5 amp 32. heated rear window switch RH heated mirror 7.5 amp 33. DRL module, RH LH daytime running lamp 15 amp 34. power antenna module, remote chassis unit 7.5 35. not used 36. not used
Jan 07, 2010 | 1997 Mercury Mountaineer
Garmin 350 cannot charge and nav at the same time
Your battery is faulty. Did it come with an AC Charger? Ac chargers do a better job than the car Dc which really only manages to maintain a reasonable level of input. i suspect your internal batter is critical and either needs a thorough charge or replacement
Jul 25, 2009 | Garmin Nuvi 350 Car GPS Receiver
My car wont start, i have tried everything. i put the key in the ignition and when i try to start it, nothing happens. all it does is a click from one of the relays? does anyone have any ideas??
Batter is probably down.. Try putting a charger on the battery.. Or take it out & have it tested..
Hope this helps !!
Please rate me good ;o)
Jul 11, 2009 | 1995 Chevrolet Camaro
Alpine MRP-M1000 Car Audio Amplifier Logo
29 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
