Question about Peg Perego Vespa Scooter
Lml Star 125 Auto wont start first time
Scooter wont start first time using electric start. am i doing something wrong?When i pump the kickstart, without turning over , then pressing the electric it seems to work
2 Suggested Answers
SOURCE: LML star scooter problem, Indicators
loose wire in the switch mine gone twice now
Posted on Jan 16, 2013
Would a scooter/motorbike run ok if i done away with the kickstart and just use the electric start
Yes, but wouldn't it be better to have it work? Get a knowledgeable biker or mechanic to work out what goes where. I can't imagine its that difficult for someone with mechanical bias.
Nov 14, 2014 | Motorcycles
I have a piaggio typhoon 50 cc (1999) it starts on the kickstart and ticks over but dies when you try and rev it,It wont fire on the electric start but turns over fine.The carb is clean and the fuel...
Hi, Steviethemas before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
https://www.reddit.com/r/scooters/comments/3d1r2j/help_please_piaggio_typhoon_wont_start
Scooter Troubleshooting Scooter won start All about Scooters
http://www.49ccscoot.com/manuals/Piaggio_Tech_Manual.pdf
https://www.oemmotorparts.com/oem2.asp?M=piaggio
PIAGGIO ZIP 50 2T User Manual
May 16, 2017 | 2005 Piaggio Typhoon 50
Kickstart slips and only returns half way
kickstart quadrant possibly worn or kickstart on wrong teeth(outside)
Apr 16, 2010 | Peg Perego Vespa Scooter
I had a scooter accident a while ago, and snapped my kickstart off. My scooter still works ok with the electric start but i want to get my kickstart fixed. I wanted to know how much at the most it could...
If it is just the kick arm, that is simple. If the shaft that it connects to is bent, this is very difficult to access. Please have your Honda Shop take a look at it. If the electric works, you might want to consider using it that way. If there is internal damage, it might not be worth repairing this 10 year old scooter.
Feb 11, 2010 | 2001 Honda Cityfly
Peugeot Vivacity 50cc Kickstart broken, but engine fine
the kick stater machanism has a spring on it
which may be brocken
Cheers Rob
Sep 17, 2009 | 2001 Honda Cityfly
Scooter does not start with button,but start with the kick
what does it do when you push the start button?? click or just does nothing??
is there power to the starter when you push the start button??
May 05, 2009 | Tomos Se 125 F Motorcycles
I have a vespa px and the electric start wont work ? can ya help
The electric starts are very hit and miss. Probably why they still came fitted with a kickstart. It's more reliable !
Apr 17, 2009 | Peg Perego Vespa Scooter
My brother's Vespa scooter fell over and won't start up again.
If it falls over and wont start it just gets flooded.
Simply remove the spark plug (inspection panel is behind your feet) and leave it sit for a half hour or so. Use the kickstart every now and then (with the scooter turned off). The excess fuel will eveporate and when the sparkplug is replaced it will start up but it will be smokey for a few minutes. Just leave it sit idling for a while to clear out.
Feb 28, 2009 | Peg Perego Vespa Scooter
Peg Perego Vespa Scooter Logo
243 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
