Question about Sharp ER-A450T Electronic Cash Register
All it does is beep
EVERY BUTTON I PUSH ALL IT WILL DO IS BEEP
  • Sharp Expert
  • 592 Answers
Do an initial reset
Posted on Nov 26, 2013
How do I turn off the beep chime signal on casio f91w?
In a few words, here is how:
1 - Push button C to get to the ALARM mode
2 - Push button A to cycle through the options:
First, you will get daily alarm activated only,
then, only hourly beep signal,
then both daily and hourly signal chime
and finally both hourly signal and daily alarm turned off
3 - Push button C to return to the Time Mode
I try to make it short and straight to the point,
I hope you find it helpful!
Phil
Sep 28, 2017 | Casio Watches
Lights flashing when turned on, replaced batteries,fuse, in drive position
the amount of flashing lights will give you a Flash code. If the the lights are going up and down, you may have a locked joystick. one method is to turn on and (within 10 sec.) push the horn button twice. Push the power button then push the joystick forward until there is a beep sound then back until you hear a beep sound to unlock.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Mar 30, 2016 | Pride Go Chair Power Chair
Push start and fill button just beeps and blinks.
after making sure switch is clean then follow your users manual , if you don't have one you can download from web .
Dec 07, 2015 | GE GTWN5050MWS Washer
My playststion will turn on but no picture on my tv
try doing this when it is off (red light is glowing on power button) push and hold down the power button when you first push it you hear a beep while you hold it down you will hear another beep when you do release the button and see if it comes on, I had the same problem with my nephews ps3 and that solved it
Aug 12, 2015 | Sony Playstation 3 (PS3) Console
Cp200
can you increase the volume? did you try the morse code button beep beep? are both units on? 10-4 big daddy truck nuts Over and Out
Mar 22, 2014 | Radio Communications
PS3 won't reset
are you trying to get to the safe mode menu?...if so unplug for 1 minute...replug...hold power button (beep) 5 secs next beep is 1...next beep is 2 after 5 secs and power off. let go of button...repush power button(hold)...(beep)...then beep again after 5 secs...then 2 fast beeps...let go of power button. it will ask you to connect your USB to your controller then push the PS button on your controller. you should be in the menu for safe mode.(research your options there thru sony and understand what they are first before running them!)
Nov 18, 2013 | Sony Playstation 3 (PS3) Console
My beep quit! Beep used to work when the oven came up to temp, the timer timed out, or a button was touched. Can it be reset or will I need to replace it? Where's the control board located and how do I...
We have a Kitchenaid Superba gas stove and the beeps would not sound. We thought the control panel was shot, but we have a WONDERFUL repair man. Here was his re-set.....open oven door, push the cancel button, push stop-time button and hold that button for about 5 seconds. When the beep sounds let go and the panel is re-set. WOW!!!!
Oct 23, 2010 | KitchenAid KGRT607 Gas Kitchen Range
Umbro junior sports watch
Push and hold the reset button on the bottom right of the watch and then push the mode button on the bottom left. When you push the mode button, all the days of thge week should no longer be illuminated. This is the same to turn the beep on, only you need to see the days of the week on not off.
Aug 01, 2010 | Watches
The lock is installed need to know how to program
First make sure you have the door handing set properly. Retract the bolt manually if extended. Now press the lock button... If the unit extends the bolt, then you're good. If not, switch the jumper position on the control board. If it's covering pins 1&2, move it to cover 2&3 or vice versa.
To program code #1..
Push the program button on the control board once. Enter your 4-8 digit code. Push the lock button to end the entry. The unit will emit a 2-second long beep. If it doesn't beep, you were too slow. Try again.
To program code #2, press the program button on the control board TWICE. Enter your 4-8 digit code. Push the lock button to end the entry. As before, the unit will emit a 2-second long beep when a successful entry is made.
Test your codes with the door open just to be sure.
Dec 16, 2009 | Weiser Lock Powerbolt 1000 Lock
PS3 has no picture, have sound, holding power button doesn't fix
did you do the steps right, push and hold, the push is one beep and hold is one beep
Jan 21, 2009 | Sony Playstation 3 (PS3) Console
Sharp ER-A450T Electronic Cash Register Logo
218 people viewed this question
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Patrick Tinashe...
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
